Ir para o conteúdo principal
« Voltar para Todas as Histórias
"No user replaceable parts inside"
mike -
MacBook Pro 15" Retina Display Mid 2012
Imagem da história
MacBook Pro 15" Retina Display Mid 2012 Battery Replacement
40 minutos
Difficult
Meu Problema
Battery was below 75% factory capacity, and I wanted to send the laptop to Mom, out of state. It was time to replace and ought to keep her from calling me in a year with battery issues.
Minha Solução
Repair went very well... But I didn't use any adhesive remover, nor did I remove most of the innards as your guides stated.
Meu Conselho
I was just extremely careful not to puncture the battery (used your plastic shims and a stiff metal putty knife), and very careful not to press on anything important (always aware that there's a trackpad I didn't want to replace). Pulled the plug, covered it in tape, two screws, and time pushing the plastic card between the case and battery.
Performed a test fit and power up before sticking down and reassembling. No harm, no foul.
I hate when people sound superior and brag... If you know how much you can pry, you may not need to do all the stuff the guides recommend.
Imagem de MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
$89.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Ao todo: 100
