Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
iPhone 6s Plus Logic Board Replacement
O que você precisa
  1. iPhone 6s Plus Logic Board Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Logic Board Replacement, Opening Procedure: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Anti-Clamp
    $24.95
    Comprar
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. iPhone 6s Plus Logic Board Replacement: passo 3, imagem 1 %32
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 6s Plus Logic Board Replacement: passo 4, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 4, imagem 2 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  5. iPhone 6s Plus Logic Board Replacement: passo 5, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 5, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 5, imagem 3 %32
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  6. iPhone 6s Plus Logic Board Replacement: passo 6, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 6, imagem 2 %32
    • Twist the spudger to widen the gap between the front panel and the rear case.
  7. iPhone 6s Plus Logic Board Replacement: passo 7, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 7, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 7, imagem 3 %32
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  8. iPhone 6s Plus Logic Board Replacement: passo 8, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 8, imagem 2 %32
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  9. iPhone 6s Plus Logic Board Replacement: passo 9, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 9, imagem 2 %32
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  10. iPhone 6s Plus Logic Board Replacement: passo 10, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  11. iPhone 6s Plus Logic Board Replacement: passo 11, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 11, imagem 2 %32
    • Pull up on the small nub on the suction cup to remove it from the display.
  12. iPhone 6s Plus Logic Board Replacement: passo 12, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 12, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 12, imagem 3 %32
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  13. iPhone 6s Plus Logic Board Replacement, Battery Connector: passo 13, imagem 1 %32
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  14. iPhone 6s Plus Logic Board Replacement: passo 14, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 14, imagem 2 %32
    • Remove the battery connector bracket.
  15. iPhone 6s Plus Logic Board Replacement: passo 15, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 15, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 15, imagem 3 %32
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  16. iPhone 6s Plus Logic Board Replacement: passo 16, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 16, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 16, imagem 3 %32
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  17. iPhone 6s Plus Logic Board Replacement, Display Assembly: passo 17, imagem 1 %32
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  18. iPhone 6s Plus Logic Board Replacement: passo 18, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 18, imagem 2 %32
    • Remove the display cable bracket.
  19. iPhone 6s Plus Logic Board Replacement: passo 19, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 19, imagem 2 %32
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  20. iPhone 6s Plus Logic Board Replacement: passo 20, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 20, imagem 2 %32
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  21. iPhone 6s Plus Logic Board Replacement: passo 21, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 21, imagem 2 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  22. iPhone 6s Plus Logic Board Replacement: passo 22, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 22, imagem 2 %32
  23. iPhone 6s Plus Logic Board Replacement, iSight Camera: passo 23, imagem 1 %32 iPhone 6s Plus Logic Board Replacement, iSight Camera: passo 23, imagem 2 %32 iPhone 6s Plus Logic Board Replacement, iSight Camera: passo 23, imagem 3 %32
    • Peel up any tape covering the iSight camera bracket screws.
  24. iPhone 6s Plus Logic Board Replacement: passo 24, imagem 1 %32
    • Remove the following Phillips screws over the camera bracket:
    • One 1.9 mm screw
    • One 2.4 mm screw
  25. iPhone 6s Plus Logic Board Replacement: passo 25, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 25, imagem 2 %32
    • Remove the iSight camera bracket.
  26. iPhone 6s Plus Logic Board Replacement: passo 26, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 26, imagem 2 %32
    • Disconnect the iSight camera connector from its socket on the logic board.
    • Be sure to pry up only the connector and not the socket on the logic board.
  27. iPhone 6s Plus Logic Board Replacement: passo 27, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 27, imagem 2 %32
    • Insert the flat end of the spudger between the iSight camera and rear casing.
    • Gently pry the camera out from its housing.
  28. iPhone 6s Plus Logic Board Replacement: passo 28, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 28, imagem 2 %32
    • Remove the iSight camera.
  29. iPhone 6s Plus Logic Board Replacement, SIM Tray: passo 29, imagem 1 %32 iPhone 6s Plus Logic Board Replacement, SIM Tray: passo 29, imagem 2 %32
    • Insert a SIM eject tool into the hole in the SIM tray.
    • Press to eject the SIM tray.
  30. iPhone 6s Plus Logic Board Replacement: passo 30, imagem 1 %32
    • Remove the SIM tray.
    • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
  31. iPhone 6s Plus Logic Board Replacement, Logic Board: passo 31, imagem 1 %32
    • Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
  32. iPhone 6s Plus Logic Board Replacement: passo 32, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 32, imagem 2 %32
    • Remove the NFC bracket.
  33. iPhone 6s Plus Logic Board Replacement: passo 33, imagem 1 %32
    • Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
  34. iPhone 6s Plus Logic Board Replacement: passo 34, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 34, imagem 2 %32
    • Remove the audio control cable bracket.
  35. iPhone 6s Plus Logic Board Replacement: passo 35, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 35, imagem 2 %32
    • Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
  36. iPhone 6s Plus Logic Board Replacement: passo 36, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 36, imagem 2 %32
    • Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
  37. iPhone 6s Plus Logic Board Replacement: passo 37, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 37, imagem 2 %32
    • Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
  38. iPhone 6s Plus Logic Board Replacement: passo 38, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 38, imagem 2 %32
    • Disconnect the power button flex cable from its socket on the logic board.
  39. iPhone 6s Plus Logic Board Replacement: passo 39, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 39, imagem 2 %32
    • Disconnect the Lightning connector interconnect antenna cable by prying it up from the logic board.
  40. iPhone 6s Plus Logic Board Replacement: passo 40, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 40, imagem 2 %32
    • Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
  41. iPhone 6s Plus Logic Board Replacement: passo 41, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 41, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 41, imagem 3 %32
    • Deroute the antenna cable from the two clips on the right edge of the logic board.
  42. iPhone 6s Plus Logic Board Replacement: passo 42, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 42, imagem 2 %32
    • Remove the following screws:
    • One 1.3 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using an [produto vinculado ausente ou desativado: IF145-343] and driver handle.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  43. iPhone 6s Plus Logic Board Replacement: passo 43, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 43, imagem 2 %32
    • Remove the bracket.
  44. iPhone 6s Plus Logic Board Replacement: passo 44, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 44, imagem 2 %32
    • Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
  45. iPhone 6s Plus Logic Board Replacement: passo 45, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 45, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 45, imagem 3 %32
    • Continue derouting the cellular antenna cable from the second and third logic board clips.
    • Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
    • Don't try to remove it by pulling on the cable, as it will tear easily.
    • In order for the cable to reach its socket on the logic board, you must route it above the logic board and underneath the audio control flex cable, as shown in the first photo.
  46. iPhone 6s Plus Logic Board Replacement: passo 46, imagem 1 %32
    • Remove the final 2.0 mm Phillips screw directly below the SIM card reader.
  47. iPhone 6s Plus Logic Board Replacement: passo 47, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 47, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 47, imagem 3 %32
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  48. iPhone 6s Plus Logic Board Replacement: passo 48, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 48, imagem 2 %32 iPhone 6s Plus Logic Board Replacement: passo 48, imagem 3 %32
    • Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
    • Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
  49. iPhone 6s Plus Logic Board Replacement: passo 49, imagem 1 %32 iPhone 6s Plus Logic Board Replacement: passo 49, imagem 2 %32
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
  50. iPhone 6s Plus Logic Board Replacement: passo 50, imagem 1 %32
    • Remove the logic board.
Conclusão
83 outras pessoas executaram este guia.
Dante Mazzanti
Membro desde: 07/13/15
36.177 Reputação
Autoria de 26 guias
24 comentários
Great guide thanks. I just want to ask: Does screw length include the head or not? If not, what's the best way to measure those tiny screws? I have digital calipers but measuring them is quite awkward.
AMT - Responder
Measurements are for the entire length of the screw, including the head. Putting the whole screw into a digital caliper should give you a reading very close to what you see here.
Jeff Suovanen -
Hi there! Great guide. Thank you. I was wondering if you ever removed the metal shields? If yes, how? I want to try to fix a water damaged phone.
Thanks!
LexiiCarrillo - Responder
Hey so I'm having a Problem with my iPhone 6s plus it won't respond to my Finger touch> i cleaned it , i Hold Lock and Home Button and nothing still same thing, i also Restored cause that what apple Suggested to do if none of those steps worked. Please Guys i need help on this one i really don't wanna pay a whole 500$ for a new iPhone.
Vick - Responder
i would replace the main logic board, make sure the board comes with the touch ID, as they are programed to work with the board. You will see main logic boards cheaper without the Touch ID. don’t buy that. I had to replace mine, and all is good now. If you are not good with working with installing the main logic board, buy one and have someone help you that knows how to do that.
Scott C -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 89
Últimos 30 dias: 253
Duração total: 88,783
