Ir para o conteúdo principal
iPhone 6s Plus Lightning Connector and Headphone Jack Replacement
O que você precisa
  1. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, SIM Tray: passo 1, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, SIM Tray: passo 1, imagem 2 %32
    • Insert a SIM eject tool into the hole in the SIM tray.
    • Press to eject the SIM tray.
  2. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 2, imagem 1 %32
    • Remove the SIM tray.
    • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
  3. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Pentalobe Screws: passo 3, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  4. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 5, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 5, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Opening Procedure: passo 6, imagem 1 %32
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  7. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 7, imagem 1 %32
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  8. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 8, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 8, imagem 2 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  9. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 9, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 9, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 9, imagem 3 %32
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  10. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 10, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 10, imagem 2 %32
    • Twist the spudger to widen the gap between the front panel and the rear case.
  11. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 11, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 11, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 11, imagem 3 %32
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  12. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 12, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 12, imagem 2 %32
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  13. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 13, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 13, imagem 2 %32
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  14. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 14, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 14, imagem 2 %32
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  15. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 15, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 15, imagem 2 %32
    • Pull up on the small nub on the suction cup to remove it from the display.
  16. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 16, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 16, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 16, imagem 3 %32
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  17. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Battery Connector: passo 17, imagem 1 %32
    Magnetic Project Mat
    $19.95
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  18. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 18, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 18, imagem 2 %32
    • Remove the battery connector bracket.
  19. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 19, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 19, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 19, imagem 3 %32
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  20. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 20, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 20, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 20, imagem 3 %32
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  21. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Display Assembly: passo 21, imagem 1 %32
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  22. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 22, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 22, imagem 2 %32
    • Remove the display cable bracket.
  23. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 23, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 23, imagem 2 %32
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  24. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 24, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 24, imagem 2 %32
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  25. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 25, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 25, imagem 2 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  26. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 26, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 26, imagem 2 %32
  27. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Speaker: passo 27, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Speaker: passo 27, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
  28. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 28, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 28, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
  29. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 29, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 29, imagem 2 %32
    • Remove the three Phillips screws securing the Lightning connector bracket:
    • Two 3.5 mm screws
    • One 2.7 mm screw
    • Remove the bracket.
  30. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 30, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 30, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
  31. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 31, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 31, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
  32. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 32, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 32, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 32, imagem 3 %32
    • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
    • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
    • Be sure to re-tighten this screw during re-installation.
    • If the cable snags near the SIM reader, it's likely caught on the SIM tray ejection mechanism. Use the point of a spudger to slide the plastic rod out of the way.
    • During re-installation, be sure to route the antenna cable underneath the logic board corner.
    • During reassembly, you can also re-insert the SIM card tray after re-routing the antenna cable.
    • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
  33. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 33, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 33, imagem 2 %32
    • Remove the six Phillips screws securing the speaker to the rear case:
    • One 2.5 mm screw
    • Two 2.7 mm screws
    • One 1.5 mm screw
    • One 1.7 mm screw
    • One 2.6 mm screw securing the speaker to the bottom edge of the rear case.
  34. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 34, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 34, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 34, imagem 3 %32
    • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
    • Pry gently to loosen the speaker module.
    • Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
  35. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Lightning Connector and Headphone Jack: passo 35, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement, Lightning Connector and Headphone Jack: passo 35, imagem 2 %32
    • Use the point of a spudger to disconnect the Taptic Engine flex cable from the lower flex cable.
  36. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 36, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 36, imagem 2 %32
    • Remove the two Phillips screws securing the Taptic Engine to the rear case:
    • One 3.1 mm screw
    • One 2.1 mm screw
    • Remove the Taptic Engine.
  37. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 37, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 37, imagem 2 %32
    • Peel back the tape over the screw securing the Lightning connector flex cable to the lip of the phone.
  38. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 38, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 38, imagem 2 %32
    • Remove the following five Phillips screws:
    • One 2.9 mm screw
    • One 1.9 mm screw
    • One 1.5 mm screw
    • One 1.6 mm screw
    • One 1.3 mm screw set in the bottom edge of the rear case
  39. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 39, imagem 1 %32
    • Prepare an iOpener and lay it across the bottom of the phone to soften the adhesive holding the Lightning connector flex cable in place.
    • Wait about a minute for the adhesive to soften before removing the iOpener and continuing.
  40. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 40, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 40, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 40, imagem 3 %32
    • Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
  41. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 41, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 41, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 41, imagem 3 %32
    • Continue sliding the opening pick underneath the flex cable.
  42. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 42, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 42, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 42, imagem 3 %32
    • Use an opening pick to pry the left microphone off the edge of the rear case.
  43. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 43, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 43, imagem 2 %32
    • Insert the point of a spudger into the headphone jack and wiggle it slightly to loosen the headphone jack from the bottom edge of the case.
  44. iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 44, imagem 1 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 44, imagem 2 %32 iPhone 6s Plus Lightning Connector and Headphone Jack Replacement: passo 44, imagem 3 %32
    • Remove the Lightning connector assembly.
    • If your replacement part did not come with a headphone jack gasket, use tweezers to remove the gasket from the old part and transfer it to the replacement part.
    • Before re-installation, use a spudger to scour any remaining adhesive residue from the rear case. You can use high concentration isopropyl alcohol to help with the process.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 6s Plus Answers community for troubleshooting help.
167 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
334.358 Reputação
Autoria de 847 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.546 guias
24Comentários do guia
Hardest thing I have every done!! But well worth it. Now I know I need to go up on my labor price!!! :-) Thanks a ton from South Carolina!!
apriltanner1975 - Responder Compartilhar
Just did this. Agree with everyone else, just flip the speaker over to get to the lightning connector assembly. Changes the repair time drastically
ztune - Responder Compartilhar
I just completed this repair, replacing the Headphone Jack/Lightening port, battery and iSight camera all at the same time. I removed everything as it explained in the guide, but can totally see how not removing the logic board would save time and isn't 100% necessary. I imagine that peeling the upper portion of the headphone/lighting port is slightly easier with the logic board removed, and you don't have to worry about that antenna cable. If I did it again, I would probably still remove the logic board.
Michael Cornforth - Responder Compartilhar
you would have to be crazy to remove the board. just flip the speaker up on its back and rest against logic board. 20 mins should complete this . i cant stress enough that board or camera does not need removed . PERIOD
Smartfone NI - Responder Compartilhar
I completed this and it starts charging, but the home button stop working. It still sense my finger print, but it does not respond when i click on it.
Any help?
Poh Chun Hou - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 82
Últimos 30 dias: 246
Ao todo: 138,125
