Introdução
Learn how to replace your iPhone 6 screen. This part comes with the front-facing camera, earpiece speaker and LCD shield plate already installed, making for an easier repair.
All you need to do is remove the old screen and transfer the home button to the new screen.
You can also use this guide to replace the front panel assembly cable bracket.
O que você precisa
VÃdeo de Apresentação
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
Ferramenta utilizada neste passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Ferramenta utilizada neste passo:Magnetic Project Mat$19.95
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Ferramenta utilizada neste passo:iOpener$17.99
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
Cancelar: não concluà este guia.
2446 outras pessoas executaram este guia.
186 comentários
Its a good advice to remove the battery power before mounting the flex-cables.
There is power on the second logic-board (even if the phone is turned off) connector from top, misplacing it while assembly can cause short circuit.
Will the short circuit damage the logic board or the camera / earpiece assembly? I'm worried just encountered this very issue even though the phone was off. FF camera and earpiece not functioning.
Battery assembly is one of the important procedures working with manual is the best way to repair an iphone 6 screen
Good advice two: When removing the LCD back shield plate have in mind that the home button connector attached to the shield plate is Very fragile. Its adhered to the screen. Use very little force and do not heat the adhesive too much because then it become even More fragile.
I use ifixits metal spudger without heat but one small mistake and it can be teared.
I have now changed two of these on my phone from different suppliers and both haven't worked!
Could it be that both have been defective products or am I doing something wrong!?!?
Kieran -
