Ir para o conteúdo principal
iPhone 16 Taptic Engine Removal
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 16 Taptic Engine Removal, Before you begin: passo 1, imagem 1 %32 iPhone 16 Taptic Engine Removal, Before you begin: passo 1, imagem 2 %32
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Taptic Engine Removal, Tape over any cracks: passo 2, imagem 1 %32 iPhone 16 Taptic Engine Removal, Tape over any cracks: passo 2, imagem 2 %32
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Taptic Engine Removal, Remove the pentalobe screws: passo 3, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the pentalobe screws: passo 3, imagem 2 %32
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 Taptic Engine Removal, Mark your opening picks: passo 4, imagem 1 %32 iPhone 16 Taptic Engine Removal, Mark your opening picks: passo 4, imagem 2 %32 iPhone 16 Taptic Engine Removal, Mark your opening picks: passo 4, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  5. iPhone 16 Taptic Engine Removal, Secure the screen: passo 5, imagem 1 %32 iPhone 16 Taptic Engine Removal, Secure the screen: passo 5, imagem 2 %32 iPhone 16 Taptic Engine Removal, Secure the screen: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
    • Make sure the tape is only securing the screen and not the back glass.
  6. iPhone 16 Taptic Engine Removal, Secure an Anti-Clamp: passo 6, imagem 1 %32 iPhone 16 Taptic Engine Removal, Secure an Anti-Clamp: passo 6, imagem 2 %32 iPhone 16 Taptic Engine Removal, Secure an Anti-Clamp: passo 6, imagem 3 %32
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 16 Taptic Engine Removal, Create a gap under the back glass: passo 7, imagem 1 %32 iPhone 16 Taptic Engine Removal, Create a gap under the back glass: passo 7, imagem 2 %32 iPhone 16 Taptic Engine Removal, Create a gap under the back glass: passo 7, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 16 Taptic Engine Removal, Insert an opening pick: passo 8, imagem 1 %32 iPhone 16 Taptic Engine Removal, Insert an opening pick: passo 8, imagem 2 %32
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti‑Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 16 Taptic Engine Removal, Heat the bottom edge: passo 9, imagem 1 %32
    iOpener
    $12.99
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  10. iPhone 16 Taptic Engine Removal, Insert an opening pick: passo 10, imagem 1 %32 iPhone 16 Taptic Engine Removal, Insert an opening pick: passo 10, imagem 2 %32 iPhone 16 Taptic Engine Removal, Insert an opening pick: passo 10, imagem 3 %32
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 16 Taptic Engine Removal, Back glass information: passo 11, imagem 1 %32
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  12. iPhone 16 Taptic Engine Removal, Heat the right edge: passo 12, imagem 1 %32
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  13. iPhone 16 Taptic Engine Removal, Separate the bottom right adhesive: passo 13, imagem 1 %32 iPhone 16 Taptic Engine Removal, Separate the bottom right adhesive: passo 13, imagem 2 %32 iPhone 16 Taptic Engine Removal, Separate the bottom right adhesive: passo 13, imagem 3 %32
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  14. iPhone 16 Taptic Engine Removal, Heat the left edge: passo 14, imagem 1 %32
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  15. iPhone 16 Taptic Engine Removal, Separate the left adhesive: passo 15, imagem 1 %32 iPhone 16 Taptic Engine Removal, Separate the left adhesive: passo 15, imagem 2 %32 iPhone 16 Taptic Engine Removal, Separate the left adhesive: passo 15, imagem 3 %32
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  16. iPhone 16 Taptic Engine Removal, Heat the top edge: passo 16, imagem 1 %32
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  17. iPhone 16 Taptic Engine Removal, Separate the top right adhesive: passo 17, imagem 1 %32 iPhone 16 Taptic Engine Removal, Separate the top right adhesive: passo 17, imagem 2 %32 iPhone 16 Taptic Engine Removal, Separate the top right adhesive: passo 17, imagem 3 %32
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  18. iPhone 16 Taptic Engine Removal, Reposition the back glass: passo 18, imagem 1 %32 iPhone 16 Taptic Engine Removal, Reposition the back glass: passo 18, imagem 2 %32 iPhone 16 Taptic Engine Removal, Reposition the back glass: passo 18, imagem 3 %32
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  19. iPhone 16 Taptic Engine Removal, Remove the middle connector cover screws: passo 19, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the middle connector cover screws: passo 19, imagem 2 %32
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  20. iPhone 16 Taptic Engine Removal, Remove the middle connector cover: passo 20, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the middle connector cover: passo 20, imagem 2 %32 iPhone 16 Taptic Engine Removal, Remove the middle connector cover: passo 20, imagem 3 %32
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  21. iPhone 16 Taptic Engine Removal, Disconnect the battery: passo 21, imagem 1 %32 iPhone 16 Taptic Engine Removal, Disconnect the battery: passo 21, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  22. iPhone 16 Taptic Engine Removal, Disconnect the wireless charging coil: passo 22, imagem 1 %32 iPhone 16 Taptic Engine Removal, Disconnect the wireless charging coil: passo 22, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  23. iPhone 16 Taptic Engine Removal, Remove the back glass: passo 23, imagem 1 %32
    • Lift the back glass off the frame and remove it.
  24. iPhone 16 Taptic Engine Removal, Remove the Taptic Engine bracket screws: passo 24, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the Taptic Engine bracket screws: passo 24, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 1.8 mm‑long screws securing the Taptic Engine bracket.
  25. iPhone 16 Taptic Engine Removal, Remove the bracket: passo 25, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the bracket: passo 25, imagem 2 %32
    • Use tweezers, or your fingers, to remove the Taptic Engine bracket.
  26. iPhone 16 Taptic Engine Removal, Disconnect the Taptic Engine: passo 26, imagem 1 %32 iPhone 16 Taptic Engine Removal, Disconnect the Taptic Engine: passo 26, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
  27. iPhone 16 Taptic Engine Removal, Remove the Taptic Engine screws: passo 27, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the Taptic Engine screws: passo 27, imagem 2 %32
    • Use a Phillips screwdriver to remove the two screws securing the Taptic Engine:
    • One 2.2 mm‑long screw
    • One 1.7 mm‑long screw
  28. iPhone 16 Taptic Engine Removal, Remove the Taptic Engine: passo 28, imagem 1 %32 iPhone 16 Taptic Engine Removal, Remove the Taptic Engine: passo 28, imagem 2 %32 iPhone 16 Taptic Engine Removal, Remove the Taptic Engine: passo 28, imagem 3 %32
    • Use the point of a spudger to lift the Taptic Engine out of the frame.
    • Remove the Taptic Engine.
Linha de Chegada
Alex Diaz-Kokaisl
Membro desde: 01/16/22
162.011 Reputação
Autoria de 769 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 42
