Ir para o conteúdo principal
iPhone 15 Logic Board Replacement
O que você precisa
  1. iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: passo 1, imagem 1 %32 iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: passo 1, imagem 2 %32
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Logic Board Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone 15 Logic Board Replacement, Tape over any cracks: passo 2, imagem 2 %32
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Logic Board Replacement, Mark your opening picks: passo 3, imagem 1 %32 iPhone 15 Logic Board Replacement, Mark your opening picks: passo 3, imagem 2 %32 iPhone 15 Logic Board Replacement, Mark your opening picks: passo 3, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Logic Board Replacement, Remove the pentalobe screws: passo 4, imagem 1 %32 iPhone 15 Logic Board Replacement, Remove the pentalobe screws: passo 4, imagem 2 %32
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Logic Board Replacement, Flip your iPhone over: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Flip your phone over and lay it on a soft surface, such as a microfiber cloth, to protect its internals as you work.
  6. iPhone 15 Logic Board Replacement, Heat the bottom edge: passo 6, imagem 1 %32
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  7. iPhone 15 Logic Board Replacement, Insert an opening pick: passo 7, imagem 1 %32 iPhone 15 Logic Board Replacement, Insert an opening pick: passo 7, imagem 2 %32 iPhone 15 Logic Board Replacement, Insert an opening pick: passo 7, imagem 3 %32
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  8. iPhone 15 Logic Board Replacement, Back glass information: passo 8, imagem 1 %32
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  9. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 9, imagem 1 %32 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 9, imagem 2 %32 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: passo 9, imagem 3 %32
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  10. iPhone 15 Logic Board Replacement, Heat the right edge: passo 10, imagem 1 %32
    • Heat the right edge of the back glass until it's hot to the touch.
  11. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: passo 11, imagem 1 %32 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: passo 11, imagem 2 %32 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: passo 11, imagem 3 %32
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  12. iPhone 15 Logic Board Replacement, Heat the left edge: passo 12, imagem 1 %32
    • Heat the left edge of the back glass until it's hot to the touch.
  13. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 13, imagem 1 %32 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 13, imagem 2 %32 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: passo 13, imagem 3 %32
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  14. iPhone 15 Logic Board Replacement, Heat the top edge: passo 14, imagem 1 %32
    • Heat the top edge of the back glass until it's hot to the touch.
  15. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: passo 15, imagem 1 %32 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: passo 15, imagem 2 %32 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: passo 15, imagem 3 %32
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  16. iPhone 15 Logic Board Replacement, Heat the top right corner: passo 16, imagem 1 %32
    • Heat the top right corner of the back glass until it's hot to the touch.
  17. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 17, imagem 1 %32 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 17, imagem 2 %32 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: passo 17, imagem 3 %32
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  18. iPhone 15 Logic Board Replacement, Swing open the back glass: passo 18, imagem 1 %32 iPhone 15 Logic Board Replacement, Swing open the back glass: passo 18, imagem 2 %32 iPhone 15 Logic Board Replacement, Swing open the back glass: passo 18, imagem 3 %32
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  19. iPhone 15 Logic Board Replacement, Unfasten the lower connector cover: passo 19, imagem 1 %32
    FixMat
    $31.41
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  20. iPhone 15 Logic Board Replacement, Remove the lower connector cover: passo 20, imagem 1 %32 iPhone 15 Logic Board Replacement, Remove the lower connector cover: passo 20, imagem 2 %32 iPhone 15 Logic Board Replacement, Remove the lower connector cover: passo 20, imagem 3 %32
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    • During reassembly, latch the top edge of the cover onto its slot on the logic board before securing it with its screw.
  21. iPhone 15 Logic Board Replacement, Disconnect the battery: passo 21, imagem 1 %32 iPhone 15 Logic Board Replacement, Disconnect the battery: passo 21, imagem 2 %32 iPhone 15 Logic Board Replacement, Disconnect the battery: passo 21, imagem 3 %32
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  22. iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: passo 22, imagem 1 %32 iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: passo 22, imagem 2 %32
    • Use the tip of an opening pick to pry up and disconnect the earpiece speaker press connector.
  23. iPhone 15 Logic Board Replacement, Unfasten the earpiece speaker: passo 23, imagem 1 %32
    • Use a Phillips #000 driver to remove the five screws securing the earpiece speaker:
    • Two 1.1 mm‑long screws
    • Three 1.6 mm‑long screws
  24. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: passo 24, imagem 1 %32 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: passo 24, imagem 2 %32 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: passo 24, imagem 3 %32
    • Use tweezers or your fingers to lift and pull the earpiece speaker away from the top of the phone to free the gasket from the frame.
    • Remove the earpiece speaker.
  25. iPhone 15 Logic Board Replacement, Separate the battery cable: passo 25, imagem 1 %32 iPhone 15 Logic Board Replacement, Separate the battery cable: passo 25, imagem 2 %32 iPhone 15 Logic Board Replacement, Separate the battery cable: passo 25, imagem 3 %32
    • Light adhesive secures the battery cable to the logic board.
    • Slide an opening pick under the battery cable to separate it from the logic board.
    • Be careful not to crease the cable or dent the battery with your tool.
  26. iPhone 15 Logic Board Replacement, Disconnect the volume buttons: passo 26, imagem 1 %32 iPhone 15 Logic Board Replacement, Disconnect the volume buttons: passo 26, imagem 2 %32
    • Use the tip of an opening pick to pry up and disconnect the volume buttons press connector.
  27. iPhone 15 Logic Board Replacement, Disconnect the power button: passo 27, imagem 1 %32 iPhone 15 Logic Board Replacement, Disconnect the power button: passo 27, imagem 2 %32
    • Disconnect the power button press connector.
  28. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: passo 28, imagem 1 %32 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: passo 28, imagem 2 %32 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: passo 28, imagem 3 %32
    • Disconnect the rear cameras and antenna press connectors (three connectors in total).
  29. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: passo 29, imagem 1 %32 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: passo 29, imagem 2 %32 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: passo 29, imagem 3 %32
    • Disconnect the eSIM, Taptic Engine, and charging port press connectors (three connectors in total).
  30. iPhone 15 Logic Board Replacement, Unfasten the logic board: passo 30, imagem 1 %32 iPhone 15 Logic Board Replacement, Unfasten the logic board: passo 30, imagem 2 %32
    Standoff Screwdriver for iPhones
    $5.49
    • Use your standoff driver to remove the five standoff screws securing the logic board:
    • One 2.9 mm screw
    • One 3.9 mm screw
    • Three 3.5 mm screws
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  31. iPhone 15 Logic Board Replacement, Remove the logic board: passo 31, imagem 1 %32 iPhone 15 Logic Board Replacement, Remove the logic board: passo 31, imagem 2 %32 iPhone 15 Logic Board Replacement, Remove the logic board: passo 31, imagem 3 %32
    • Grip the top edge of the logic board and gently pull it out from under the cables.
    • Remove the logic board.
    • During reassembly, make sure all nine press connectors (including the small volume buttons cable) are above the logic board.
Conclusão
To reassemble your phone, follow these instructions in reverse order.
Clay Eickemeyer
Membro desde: 09/19/22
95.626 Reputação
Autoria de 466 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 15.786 guias
1Comentário do guia
You can remove the logic board without removing the screen if you carefully flip the logic board over during removal.
Finn Hagard - Responder
Comentar
Visualizações:
Últimas 24 horas: 34
Últimos 7 dias: 284
Últimos 30 dias: 1,215
Ao todo: 15,602
