Ir para o conteúdo principal
iPhone 14 Front-Facing Camera Assembly Replacement
O que você precisa
  1. iPhone 14 Front-Facing Camera Assembly Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    PLEASE remove back first and disconnect battery before taking cables off!! as per Apple instructions
    PC Technology Group - Responder
  2. iPhone 14 Front-Facing Camera Assembly Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Responder
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Responder
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Responder
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Responder
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Responder
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Responder
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Responder
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Responder
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Responder
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Responder
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Responder
  3. iPhone 14 Front-Facing Camera Assembly Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Tape over any cracks: passo 3, imagem 2 %32
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Front-Facing Camera Assembly Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Follow this guide to secure your screen with the included tape.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 14 Front-Facing Camera Assembly Replacement: passo 5, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement: passo 5, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 14 Front-Facing Camera Assembly Replacement: passo 6, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement: passo 6, imagem 2 %32
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The glass should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the rear glass when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 14 Front-Facing Camera Assembly Replacement, Heat the bottom edge: passo 7, imagem 1 %32
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 14 Front-Facing Camera Assembly Replacement, Insert an opening pick: passo 8, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Insert an opening pick: passo 8, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Insert an opening pick: passo 8, imagem 3 %32
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  9. iPhone 14 Front-Facing Camera Assembly Replacement, Heat the left edge: passo 9, imagem 1 %32
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  10. iPhone 14 Front-Facing Camera Assembly Replacement, Slice the left edge adhesive: passo 10, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Slice the left edge adhesive: passo 10, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Slice the left edge adhesive: passo 10, imagem 3 %32
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 14 Front-Facing Camera Assembly Replacement, Rear glass information: passo 11, imagem 1 %32
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
  12. iPhone 14 Front-Facing Camera Assembly Replacement, Heat the right edge: passo 12, imagem 1 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
    This is the side with the volume buttons
    Jace - Responder
  13. iPhone 14 Front-Facing Camera Assembly Replacement, Slice the right edge adhesive: passo 13, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Slice the right edge adhesive: passo 13, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Slice the right edge adhesive: passo 13, imagem 3 %32
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  14. iPhone 14 Front-Facing Camera Assembly Replacement, Heat the top edge: passo 14, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  15. iPhone 14 Front-Facing Camera Assembly Replacement, Slice the top edge adhesive: passo 15, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Slice the top edge adhesive: passo 15, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Slice the top edge adhesive: passo 15, imagem 3 %32
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  16. iPhone 14 Front-Facing Camera Assembly Replacement: passo 16, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement: passo 16, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement: passo 16, imagem 3 %32
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  17. iPhone 14 Front-Facing Camera Assembly Replacement, Open the iPhone: passo 17, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Open the iPhone: passo 17, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Open the iPhone: passo 17, imagem 3 %32
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  18. iPhone 14 Front-Facing Camera Assembly Replacement, Unfasten the battery connector cover screws: passo 18, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Unfasten the battery connector cover screws: passo 18, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 14 Front-Facing Camera Assembly Replacement, Remove the battery connector cover: passo 19, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the battery connector cover: passo 19, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the battery connector cover: passo 19, imagem 3 %32
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  20. iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the battery: passo 20, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the battery: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 14 Front-Facing Camera Assembly Replacement, Unfasten the charging coil connector cover screw: passo 21, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Unfasten the charging coil connector cover screw: passo 21, imagem 2 %32
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  22. iPhone 14 Front-Facing Camera Assembly Replacement, Remove the charging coil connector bracket: passo 22, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the charging coil connector bracket: passo 22, imagem 2 %32
    • Use a pair of tweezers to remove the charging coil connector cover.
  23. iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the charging coil: passo 23, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the charging coil: passo 23, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
    I disconnected this one before the battery. Now the phone keeps turning off itself every five minutes.
    tanner85 - Responder
  24. iPhone 14 Front-Facing Camera Assembly Replacement, Remove the rear glass assembly: passo 24, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the rear glass assembly: passo 24, imagem 2 %32
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  25. iPhone 14 Front-Facing Camera Assembly Replacement, Unfasten the front camera assembly cable bracket screws: passo 25, imagem 1 %32
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the front camera assembly cable bracket.
  26. iPhone 14 Front-Facing Camera Assembly Replacement, Remove the front camera assembly cable bracket: passo 26, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the front camera assembly cable bracket: passo 26, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the front camera assembly cable bracket.
  27. iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the camera and sensor cable: passo 27, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the camera and sensor cable: passo 27, imagem 2 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Disconnect the camera and sensor cable: passo 27, imagem 3 %32
    • Use a spudger to disconnect the camera and the sensor cables by prying the connectors straight up from their sockets.
  28. iPhone 14 Front-Facing Camera Assembly Replacement, Remove the front-facing camera assembly: passo 28, imagem 1 %32 iPhone 14 Front-Facing Camera Assembly Replacement, Remove the front-facing camera assembly: passo 28, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the front-facing camera and sensor assembly.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Uma outra pessoa concluiu este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
228.969 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
2 comentários
I replaced the Front Cameras on my iPhone 14 and now it just freezes my camera app when i try to switch from rear to front and use them. I've tired all the trouble shooting I'm able to. Any ideas on what can fix this. I know the part is good its almost as the phone does not want to register it
kai aas - Responder
Do a forced update on itunes and should get camera working
NativemanFTW -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 81
Últimos 30 dias: 326
Duração total: 7,233
