Ir para o conteúdo principal
iPhone 14 Earpiece Speaker Replacement
O que você precisa
  1. iPhone 14 Earpiece Speaker Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Earpiece Speaker Replacement, Mark your opening picks: passo 2, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Mark your opening picks: passo 2, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Mark your opening picks: passo 2, imagem 3 %32
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 14 Earpiece Speaker Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Tape over any cracks: passo 3, imagem 2 %32
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
  4. iPhone 14 Earpiece Speaker Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Clamp
    $24.95
    Comprar
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Follow this guide to secure your screen with the included tape.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 14 Earpiece Speaker Replacement: passo 5, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement: passo 5, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 14 Earpiece Speaker Replacement: passo 6, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement: passo 6, imagem 2 %32
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The glass should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the rear glass when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 14 Earpiece Speaker Replacement, Heat the bottom edge: passo 7, imagem 1 %32
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 14 Earpiece Speaker Replacement, Insert an opening pick: passo 8, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Insert an opening pick: passo 8, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Insert an opening pick: passo 8, imagem 3 %32
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  9. iPhone 14 Earpiece Speaker Replacement, Heat the left edge: passo 9, imagem 1 %32
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  10. iPhone 14 Earpiece Speaker Replacement, Slice the left edge adhesive: passo 10, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Slice the left edge adhesive: passo 10, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Slice the left edge adhesive: passo 10, imagem 3 %32
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 14 Earpiece Speaker Replacement, Screen information: passo 11, imagem 1 %32
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 14 Earpiece Speaker Replacement, Heat the right edge: passo 12, imagem 1 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
  13. iPhone 14 Earpiece Speaker Replacement, Slice the right edge adhesive: passo 13, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Slice the right edge adhesive: passo 13, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Slice the right edge adhesive: passo 13, imagem 3 %32
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
  14. iPhone 14 Earpiece Speaker Replacement, Heat the top edge: passo 14, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
  15. iPhone 14 Earpiece Speaker Replacement, Slice the top edge adhesive: passo 15, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Slice the top edge adhesive: passo 15, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Slice the top edge adhesive: passo 15, imagem 3 %32
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  16. iPhone 14 Earpiece Speaker Replacement: passo 16, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement: passo 16, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement: passo 16, imagem 3 %32
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  17. iPhone 14 Earpiece Speaker Replacement, Open the iPhone: passo 17, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Open the iPhone: passo 17, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Open the iPhone: passo 17, imagem 3 %32
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
  18. iPhone 14 Earpiece Speaker Replacement, Unfasten the battery connector cover screws: passo 18, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Unfasten the battery connector cover screws: passo 18, imagem 2 %32
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 14 Earpiece Speaker Replacement, Remove the battery connector cover: passo 19, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the battery connector cover: passo 19, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Remove the battery connector cover: passo 19, imagem 3 %32
    Comprar
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  20. iPhone 14 Earpiece Speaker Replacement, Disconnect the battery: passo 20, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Disconnect the battery: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 14 Earpiece Speaker Replacement, Unfasten the charging coil connector cover screw: passo 21, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Unfasten the charging coil connector cover screw: passo 21, imagem 2 %32
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  22. iPhone 14 Earpiece Speaker Replacement, Remove the charging coil connector bracket: passo 22, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the charging coil connector bracket: passo 22, imagem 2 %32
    • Use a pair of tweezers to remove the charging coil connector cover.
  23. iPhone 14 Earpiece Speaker Replacement, Disconnect the charging coil: passo 23, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Disconnect the charging coil: passo 23, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  24. iPhone 14 Earpiece Speaker Replacement, Remove the rear glass assembly: passo 24, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the rear glass assembly: passo 24, imagem 2 %32
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  25. iPhone 14 Earpiece Speaker Replacement, Unfasten the front camera assembly cable bracket screws: passo 25, imagem 1 %32
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the front camera assembly cable bracket.
  26. iPhone 14 Earpiece Speaker Replacement, Remove the front camera assembly cable bracket: passo 26, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the front camera assembly cable bracket: passo 26, imagem 2 %32
    Comprar
    • Use a pair of tweezers or your fingers to remove the front camera assembly cable bracket.
  27. iPhone 14 Earpiece Speaker Replacement, Disconnect the camera and sensor cable: passo 27, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Disconnect the camera and sensor cable: passo 27, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Disconnect the camera and sensor cable: passo 27, imagem 3 %32
    • Use a spudger to disconnect the camera and the sensor cables by prying the connectors straight up from their sockets.
  28. iPhone 14 Earpiece Speaker Replacement, Remove the front-facing camera assembly: passo 28, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the front-facing camera assembly: passo 28, imagem 2 %32
    • Use a pair of tweezers or your fingers to remove the front-facing camera and sensor assembly.
  29. iPhone 14 Earpiece Speaker Replacement, Disconnect the antenna: passo 29, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Disconnect the antenna: passo 29, imagem 2 %32
    • The next two steps show how to remove an antenna that's in some models. If you don't have this antenna, skip these steps.
    • Use a spudger to disconnect the antenna cable by prying the connector straight up from its socket.
  30. iPhone 14 Earpiece Speaker Replacement, Remove the antenna: passo 30, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the antenna: passo 30, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Remove the antenna: passo 30, imagem 3 %32
    • The antenna is lightly adhered to the earpiece speaker.
    • Insert the tip of a spudger under the top left corner of the antenna.
    • Pry up to separate the adhesive under the antenna.
    • Remove the antenna
  31. iPhone 14 Earpiece Speaker Replacement, Disconnect the earpiece speaker: passo 31, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Disconnect the earpiece speaker: passo 31, imagem 2 %32
    • Use a spudger to disconnect the earpiece cable by prying the connector straight up from its socket.
  32. iPhone 14 Earpiece Speaker Replacement, Unfasten the earpiece speaker screws: passo 32, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 1.4 mm-long screws securing the earpiece speaker.
  33. iPhone 14 Earpiece Speaker Replacement: passo 33, imagem 1 %32
    • Use a Phillips screwdriver to remove the 1.1 mm-long screw securing the earpiece speaker to the frame.
  34. iPhone 14 Earpiece Speaker Replacement, Remove the earpiece speaker: passo 34, imagem 1 %32 iPhone 14 Earpiece Speaker Replacement, Remove the earpiece speaker: passo 34, imagem 2 %32 iPhone 14 Earpiece Speaker Replacement, Remove the earpiece speaker: passo 34, imagem 3 %32
    Comprar
    • Use a pair of tweezers or your fingers to remove the earpiece speaker.
    • The top left edge of the earpiece speaker is equipped with a rubber gasket. During reassembly, make sure the gasket lines up with its recess in the frame correctly.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
Membro desde: 11/23/16
205.247 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.430 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 42
Últimos 30 dias: 225
Duração total: 3,355
