Ir para o conteúdo principal
iPhone 12 mini Display Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 12 mini Display Assembly Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
  2. iPhone 12 mini Display Assembly Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Tape over any cracks: passo 2, imagem 2 %32 iPhone 12 mini Display Assembly Replacement, Tape over any cracks: passo 2, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone 12 mini Display Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPhone 12 mini Display Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 12 mini Display Assembly Replacement: passo 4, imagem 1 %32 iPhone 12 mini Display Assembly Replacement: passo 4, imagem 2 %32 iPhone 12 mini Display Assembly Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 12 mini Display Assembly Replacement: passo 5, imagem 1 %32 iPhone 12 mini Display Assembly Replacement: passo 5, imagem 2 %32 iPhone 12 mini Display Assembly Replacement: passo 5, imagem 3 %32
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • Make sure the opening pick is placed properly between the plastic bezel and the frame to avoid damaging your screen.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 12 mini Display Assembly Replacement, Heat the bottom edge of the phone: passo 6, imagem 1 %32
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • Heating the bottom edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
  7. iPhone 12 mini Display Assembly Replacement, Apply a suction handle: passo 7, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Apply a suction handle: passo 7, imagem 2 %32
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  8. iPhone 12 mini Display Assembly Replacement, Lift the screen slightly: passo 8, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Lift the screen slightly: passo 8, imagem 2 %32 iPhone 12 mini Display Assembly Replacement, Lift the screen slightly: passo 8, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
    • A plastic bezel is secured to the underside of the display, and needs to lift up with the display. Inserting a pick between the bezel and the display will damage the panel.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • Make sure the opening pick is placed under the plastic bezel (against the frame) to avoid damaging your screen.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 12 mini Display Assembly Replacement, Heat the right edge: passo 9, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Heat the right edge: passo 9, imagem 2 %32
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 12 mini Display Assembly Replacement, Separate the screen adhesive: passo 10, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Separate the screen adhesive: passo 10, imagem 2 %32 iPhone 12 mini Display Assembly Replacement, Separate the screen adhesive: passo 10, imagem 3 %32
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 12 mini Display Assembly Replacement, Heat the top edge: passo 11, imagem 1 %32
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 12 mini Display Assembly Replacement: passo 12, imagem 1 %32 iPhone 12 mini Display Assembly Replacement: passo 12, imagem 2 %32 iPhone 12 mini Display Assembly Replacement: passo 12, imagem 3 %32
    • The top edge of the display is secured with both glue and clips.
    • Insert your pick underneath the top-right corner of the display panel.
    • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
    • Slide the pick along the top edge and cut any remaining adhesive securing the display.
  13. iPhone 12 mini Display Assembly Replacement, Heat the left edge: passo 13, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Heat the left edge: passo 13, imagem 2 %32
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  14. iPhone 12 mini Display Assembly Replacement, Screen information: passo 14, imagem 1 %32
    • There are two delicate cables along the left edge of your iPhone, one near the top and one slightly below the middle. Don't insert your pick here, as you may damage the cable.
  15. iPhone 12 mini Display Assembly Replacement, Separate the left adhesive: passo 15, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Separate the left adhesive: passo 15, imagem 2 %32
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 12 mini Display Assembly Replacement, Open the iPhone: passo 16, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Open the iPhone: passo 16, imagem 2 %32 iPhone 12 mini Display Assembly Replacement, Open the iPhone: passo 16, imagem 3 %32
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 12 mini Display Assembly Replacement, Unscrew the battery and display connector cover: passo 17, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Unscrew the battery and display connector cover: passo 17, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 12 mini Display Assembly Replacement, Remove the battery and display connector cover: passo 18, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Remove the battery and display connector cover: passo 18, imagem 2 %32
    • Use a pair of tweezers to remove the battery & display connector bracket.
    • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
  19. iPhone 12 mini Display Assembly Replacement, Disconnect the battery: passo 19, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Disconnect the battery: passo 19, imagem 2 %32
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 12 mini Display Assembly Replacement, Disconnect the OLED display cable: passo 20, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Disconnect the OLED display cable: passo 20, imagem 2 %32
    • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone 12 mini Display Assembly Replacement, Unscrew the front sensor assembly cover: passo 21, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Unscrew the front sensor assembly cover: passo 21, imagem 2 %32
    • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
  22. iPhone 12 mini Display Assembly Replacement: passo 22, imagem 1 %32 iPhone 12 mini Display Assembly Replacement: passo 22, imagem 2 %32
    • Use a pair of tweezers to remove the front sensor assembly bracket.
  23. iPhone 12 mini Display Assembly Replacement, Disconnect the front sensors: passo 23, imagem 1 %32 iPhone 12 mini Display Assembly Replacement, Disconnect the front sensors: passo 23, imagem 2 %32
    • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
  24. iPhone 12 mini Display Assembly Replacement, Remove the display assembly: passo 24, imagem 1 %32
Conclusão
Dominik Schnabelrauch
Membro desde: 11/23/16
228.969 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 11
Duração total: 83
