Ir para o conteúdo principal
iPad Pro 12.9" 3rd Gen Logic Board Replacement
O que você precisa
  1. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Prepare your iPad for disassembly: passo 1, imagem 1 %32
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Heat the right edge: passo 2, imagem 1 %32
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
  3. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 4, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 4, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 5, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 5, imagem 2 %32
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Insert an opening pick: passo 6, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Insert an opening pick: passo 6, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
  7. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Right edge information: passo 7, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Right edge information: passo 7, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Right edge information: passo 7, imagem 3 %32
    • There are two 2 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
    • The first magnet begins about 3 cm from the top of the iPad.
    • The second magnet begins about 3 cm from the bottom of the iPad.
    • Everywhere else, don't insert your opening pick more than 5 mm.
  8. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the right adhesive: passo 8, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the right adhesive: passo 8, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the right adhesive: passo 8, imagem 3 %32
    • Slide your opening pick along the right edge of the screen to separate the adhesive.
    • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
    • Leave the pick inserted in the bottom right corner before continuing.
  9. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the corner adhesive: passo 9, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the corner adhesive: passo 9, imagem 2 %32
    • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
  10. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Heat the bottom edge: passo 10, imagem 1 %32
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  11. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the bottom adhesive: passo 11, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the bottom adhesive: passo 11, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the bottom adhesive: passo 11, imagem 3 %32
    • Insert a second opening pick under the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to separate the bottom adhesive.
  12. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the corner adhesive: passo 12, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the corner adhesive: passo 12, imagem 2 %32
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
  13. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Heat the left edge: passo 13, imagem 1 %32
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  14. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Left edge information: passo 14, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Left edge information: passo 14, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Left edge information: passo 14, imagem 3 %32
    • There are three cutouts along the left edge of the screen where the adhesive is very thin. Don't insert your opening pick more than 2 mm to avoid damaging the screen at these cutouts:
    • The upper cutout begins 4 cm from the top of the frame and is 3 cm long.
    • The middle cutout begins 12 cm from the top of the frame and is 3 cm long.
    • The bottom cutout is 4 cm from the bottom of the frame and is 3 cm long.
  15. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the left adhesive: passo 15, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the left adhesive: passo 15, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the left adhesive: passo 15, imagem 3 %32
    • Insert a third opening pick under the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
    • Leave the pick inserted in the top left corner before continuing.
  16. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the corner adhesive: passo 16, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Slice the corner adhesive: passo 16, imagem 2 %32
    • Slide your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Heat the top edge: passo 17, imagem 1 %32
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Top edge information: passo 18, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Top edge information: passo 18, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Top edge information: passo 18, imagem 3 %32
    • While the top edge adhesive softens, note the following:
    • There are two ambient light sensors near the corners. Don't insert your pick more than 1 mm here.
    • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
    • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
  19. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the top adhesive: passo 19, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the top adhesive: passo 19, imagem 2 %32
    • Slide your opening pick 9 cm toward the top right edge, stopping just before the camera assembly.
    • If you slide any farther, you risk damaging the camera's sensors.
    • Leave your pick inserted before continuing.
  20. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 20, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 20, imagem 2 %32
    • Insert a new opening pick on the other side of the camera assembly, 4 cm from the previous pick.
    • Slide your pick to the top right corner to slice the remaining adhesive.
  21. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the screen: passo 21, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the screen: passo 21, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the screen: passo 21, imagem 3 %32
    • Don't fully remove the screen, as it's attached to the frame by several cables.
    • Grab two opposing corners of the screen and lift up to separate it from the frame.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
  22. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Unfasten the upper cable shield: passo 22, imagem 1 %32
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 2.0 mm-long screw
    • One 1.8 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  23. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the upper cable shield: passo 23, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the upper cable shield: passo 23, imagem 2 %32
    • Use tweezers, or your fingers, to grab and remove the upper cable shield.
  24. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the upper sensors: passo 24, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the upper sensors: passo 24, imagem 2 %32
    • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  25. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the screen: passo 25, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the screen: passo 25, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the screen: passo 25, imagem 3 %32
    • Grip the right edge of the screen and open it like a book.
    • Don't pull up on the screen—the display cables are still attached.
    • Lay the screen down over the left edge of the iPad.
    • Be careful not to strain the display cables.
  26. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Unfasten the display cable bracket: passo 26, imagem 1 %32
    • Use a Phillips screwdriver to remove the five screws securing the display cable bracket:
    • Four 1.1 mm-long screws
  27. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the display cable bracket: passo 27, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the display cable bracket: passo 27, imagem 2 %32
    • Use tweezers, or your fingers, to remove the display cable bracket.
  28. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the SIM card reader: passo 28, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the SIM card reader: passo 28, imagem 2 %32
    • Use a spudger to pry up and disconnect the SIM card reader cable press connector.
  29. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the SIM card reader cable: passo 29, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the SIM card reader cable: passo 29, imagem 2 %32
    • The SIM card reader cable is lightly adhered to the battery.
    • Use tweezers, or your fingers, to peel the SIM card reader cable away from the battery connector.
  30. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Unfasten the battery connector: passo 30, imagem 1 %32
    • Use a Phillips screwdriver to remove the 1.7 mm-long screw securing the battery connector to the logic board.
  31. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top display cables: passo 31, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top display cables: passo 31, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top display cables: passo 31, imagem 3 %32
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
  32. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom display cables: passo 32, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom display cables: passo 32, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom display cables: passo 32, imagem 3 %32
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
  33. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the screen: passo 33, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the screen: passo 33, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the screen: passo 33, imagem 3 %32
    • Remove the screen.
  34. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board tape: passo 34, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board tape: passo 34, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board tape: passo 34, imagem 3 %32
    • Metal tape conceals three screws that secure the logic board cover.
    • Use an opening tool to scrape the metal tape off the logic board enough to grab it with tweezers.
  35. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 35, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 35, imagem 2 %32
    • Use tweezers to peel up the tape at the screw locations.
  36. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Unfasten the logic board cover: passo 36, imagem 1 %32
    • Use a Phillips screwdriver to remove the eight screws securing the logic board cover:
    • Five 2.0 mm-long screws
    • Three 1.1 mm-long screws
  37. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board cover: passo 37, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board cover: passo 37, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board cover: passo 37, imagem 3 %32
    • Peel back the logic board cover and remove it.
  38. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the front camera assembly: passo 38, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the front camera assembly: passo 38, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the front camera assembly: passo 38, imagem 3 %32
    • Use a spudger to pry up and disconnect the three front camera assembly cable press connectors.
  39. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 39, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 39, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 39, imagem 3 %32
    • The left front camera cable is lightly adhered to the logic board.
    • Use tweezers, or your fingers, to peel the left cable off the logic board.
  40. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 40, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 40, imagem 2 %32
    • The middle front camera cable is lightly adhered to the logic board.
    • Use tweezers, or your fingers, to peel the middle cable off the logic board.
  41. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Unfasten the front camera assembly: passo 41, imagem 1 %32
    • Use a T-3 screwdriver to remove the two 2.2 mm-long screws securing the front camera assembly.
  42. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the front camera: passo 42, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the front camera: passo 42, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the front camera: passo 42, imagem 3 %32
    • The front camera is strongly adhered to the frame with heat-resistant epoxy. Work slowly to avoid damaging surrounding components.
    • Insert the flat end of a spudger underneath the front camera, between the middle and right cables.
    • Twist the spudger to separate the epoxy securing the front camera.
    • This may require significant force.
    • Remove the front camera.
    • During reassembly, use a spudger to scrape off any remaining epoxy before reinstalling the front camera.
  43. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Unfasten the bottom speaker bracket: passo 43, imagem 1 %32
    • Use a Phillips screwdriver to remove the 2.0 mm-long screw securing the bottom speaker bracket to the logic board.
  44. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the bottom speaker bracket: passo 44, imagem 1 %32
    • Use tweezers, or your fingers, to remove the bottom speaker bracket.
  45. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom speakers: passo 45, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom speakers: passo 45, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom speakers: passo 45, imagem 3 %32
    • Use the tip of a spudger to pry up and disconnect the four bottom speaker connectors.
    • Pry up under the cables, as close to the connector head as possible.
  46. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Smart Connector: passo 46, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Smart Connector: passo 46, imagem 2 %32
    • Use a spudger to pry up and disconnect the Smart Connector press connector at the bottom of the logic board.
  47. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top speakers: passo 47, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top speakers: passo 47, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top speakers: passo 47, imagem 3 %32
    • Use the tip of a spudger to pry up and disconnect the four top speaker connectors.
  48. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the rear camera: passo 48, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the rear camera: passo 48, imagem 2 %32
    • Use a spudger to pry up and disconnect the rear camera cable press connector.
  49. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top microphone: passo 49, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top microphone: passo 49, imagem 2 %32
    • Use a spudger to pry up and disconnect the top microphone press connector.
  50. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 50, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the 5G mmWave antenna: passo 50, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the 5G mmWave antenna by prying as close to its coaxial connector as possible.
  51. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top antenna: passo 51, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the top antenna: passo 51, imagem 2 %32
    • Use a spudger to pry up and disconnect the top antenna press connector.
    • Don't bend this cable more than needed, as it might break.
  52. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom antenna: passo 52, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the bottom antenna: passo 52, imagem 2 %32
    • Use a spudger to pry up and disconnect the bottom antenna press connector.
  53. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Wi-Fi antenna cable: passo 53, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Wi-Fi antenna cable: passo 53, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the Wi-Fi antenna cable by prying as close to its coaxial connector as possible.
  54. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the Wi-Fi cable: passo 54, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the Wi-Fi cable: passo 54, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Reposition the Wi-Fi cable: passo 54, imagem 3 %32
    • Peel the Wi-Fi cable toward the right edge of the iPad.
  55. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 55, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 55, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 55, imagem 3 %32
    • Continue peeling the cable toward the bottom edge of the iPad to separate it from the logic board.
  56. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Apple Pencil charger: passo 56, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Apple Pencil charger: passo 56, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Disconnect the Apple Pencil charger: passo 56, imagem 3 %32
    • Use a spudger to pry up and disconnect the left microphone and Apple Pencil charger cable press connectors.
  57. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Apply isopropyl alcohol: passo 57, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Apply isopropyl alcohol: passo 57, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Apply isopropyl alcohol: passo 57, imagem 3 %32
    • Apply high concentration (over 90%) isopropyl alcohol to the right edge of the logic board.
  58. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 58, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 58, imagem 2 %32
    • Tilt the right edge of the iPad upward to allow the isopropyl alcohol to work its way underneath the logic board.
    • Wait for one minute to allow the isopropyl alcohol to weaken the adhesive.
  59. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the top adhesive: passo 59, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the top adhesive: passo 59, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the top adhesive: passo 59, imagem 3 %32
    • At this point, you can remove the battery blocker card strips.
    • Slide an opening pick under the top edge of the logic board to separate the bottom adhesive.
    • If you're having trouble inserting the pick, apply isopropyl alcohol directly to the top edge.
    • Leave the opening pick inserted to prevent the adhesive from resealing.
  60. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the logic board adhesive: passo 60, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the logic board adhesive: passo 60, imagem 2 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Separate the logic board adhesive: passo 60, imagem 3 %32
    • Insert an opening pick under the top right edge of the logic board.
    • Slide the opening pick toward the battery connector to separate the right adhesive.
    • Leave the opening pick inserted next to the battery connector to prevent the adhesive from resealing.
  61. iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 61, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement: passo 61, imagem 2 %32
    • Insert a new opening pick under the logic board across from the battery connector.
    • Slide the opening pick toward the bottom of the iPad to separate the remaining adhesive.
    • At this point, the logic board should be fully separated from the frame. If the logic board still feels stuck, slide an opening pick around its perimeter to slice any remaining adhesive.
  62. iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board: passo 62, imagem 1 %32 iPad Pro 12.9" 3rd Gen Logic Board Replacement, Remove the logic board: passo 62, imagem 2 %32
    • Remove the logic board.
    • During reassembly, make sure all of the connectors are above the logic board before securing it back to the frame.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 3rd Generation Answers community for help.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
219.726 Reputação
Autoria de 1.064 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.153 guias
1Comentário do guia
How do I get a motherboard for this 3rd gen iPad series?
Marc Gouather (Anzaman) - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 32
Últimos 30 dias: 197
Ao todo: 5,505
