Ir para o conteúdo principal
iPad 9 LCD Replacement
O que você precisa
  1. iPad 9 LCD Replacement, Heat the left edge: passo 1, imagem 1 %32
    • Be sure to power off your iPad before you begin your repair.
    • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
  2. iPad 9 LCD Replacement, Screen removal information: passo 2, imagem 1 %32 iPad 9 LCD Replacement, Screen removal information: passo 2, imagem 2 %32 iPad 9 LCD Replacement, Screen removal information: passo 2, imagem 3 %32
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
    • Ambient light sensors
  3. iPad 9 LCD Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPad 9 LCD Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPad 9 LCD Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 9 LCD Replacement: passo 4, imagem 1 %32 iPad 9 LCD Replacement: passo 4, imagem 2 %32 iPad 9 LCD Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 9 LCD Replacement: passo 5, imagem 1 %32 iPad 9 LCD Replacement: passo 5, imagem 2 %32
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 9 LCD Replacement, Insert an opening pick: passo 6, imagem 1 %32 iPad 9 LCD Replacement, Insert an opening pick: passo 6, imagem 2 %32 iPad 9 LCD Replacement, Insert an opening pick: passo 6, imagem 3 %32
    • This step shows how to open the iPad using a suction handle.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 9 LCD Replacement, Separate the left adhesive: passo 7, imagem 1 %32 iPad 9 LCD Replacement, Separate the left adhesive: passo 7, imagem 2 %32 iPad 9 LCD Replacement, Separate the left adhesive: passo 7, imagem 3 %32
    • Insert a second opening pick into the gap you just created.
    • Slide the pick towards the bottom-left corner of the iPad to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 9 LCD Replacement: passo 8, imagem 1 %32 iPad 9 LCD Replacement: passo 8, imagem 2 %32 iPad 9 LCD Replacement: passo 8, imagem 3 %32
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 9 LCD Replacement: passo 9, imagem 1 %32 iPad 9 LCD Replacement: passo 9, imagem 2 %32 iPad 9 LCD Replacement: passo 9, imagem 3 %32
    • Slide the first opening pick towards the top-left corner of the iPad to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 9 LCD Replacement, Heat the top edge: passo 10, imagem 1 %32
    • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
  11. iPad 9 LCD Replacement, Separate the top left adhesive: passo 11, imagem 1 %32 iPad 9 LCD Replacement, Separate the top left adhesive: passo 11, imagem 2 %32 iPad 9 LCD Replacement, Separate the top left adhesive: passo 11, imagem 3 %32
    • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
  12. iPad 9 LCD Replacement, Separate the top adhesive: passo 12, imagem 1 %32 iPad 9 LCD Replacement, Separate the top adhesive: passo 12, imagem 2 %32 iPad 9 LCD Replacement, Separate the top adhesive: passo 12, imagem 3 %32
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 9 LCD Replacement: passo 13, imagem 1 %32 iPad 9 LCD Replacement: passo 13, imagem 2 %32 iPad 9 LCD Replacement: passo 13, imagem 3 %32
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 9 LCD Replacement: passo 14, imagem 1 %32 iPad 9 LCD Replacement: passo 14, imagem 2 %32 iPad 9 LCD Replacement: passo 14, imagem 3 %32
    • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 9 LCD Replacement, Heat the right edge: passo 15, imagem 1 %32
    • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
  16. iPad 9 LCD Replacement, Separate the top right adhesive: passo 16, imagem 1 %32 iPad 9 LCD Replacement, Separate the top right adhesive: passo 16, imagem 2 %32 iPad 9 LCD Replacement, Separate the top right adhesive: passo 16, imagem 3 %32
    • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
  17. iPad 9 LCD Replacement, Separate the right adhesive: passo 17, imagem 1 %32 iPad 9 LCD Replacement, Separate the right adhesive: passo 17, imagem 2 %32 iPad 9 LCD Replacement, Separate the right adhesive: passo 17, imagem 3 %32
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach 3 inches from the bottom of the iPad.
  18. iPad 9 LCD Replacement, Heat the bottom edge: passo 18, imagem 1 %32
    • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
  19. iPad 9 LCD Replacement, Separate the bottom left adhesive: passo 19, imagem 1 %32 iPad 9 LCD Replacement, Separate the bottom left adhesive: passo 19, imagem 2 %32 iPad 9 LCD Replacement, Separate the bottom left adhesive: passo 19, imagem 3 %32
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • The third image shows the bottom-left antenna underneath the digitizer.
    • Leave the pick in the corner before moving to the next step.
  20. iPad 9 LCD Replacement, Separate the bottom adhesive: passo 20, imagem 1 %32 iPad 9 LCD Replacement, Separate the bottom adhesive: passo 20, imagem 2 %32 iPad 9 LCD Replacement, Separate the bottom adhesive: passo 20, imagem 3 %32
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 9 LCD Replacement: passo 21, imagem 1 %32 iPad 9 LCD Replacement: passo 21, imagem 2 %32 iPad 9 LCD Replacement: passo 21, imagem 3 %32
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
  22. iPad 9 LCD Replacement: passo 22, imagem 1 %32 iPad 9 LCD Replacement: passo 22, imagem 2 %32 iPad 9 LCD Replacement: passo 22, imagem 3 %32
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 9 LCD Replacement, Heat the right edge: passo 23, imagem 1 %32
  24. iPad 9 LCD Replacement: passo 24, imagem 1 %32 iPad 9 LCD Replacement: passo 24, imagem 2 %32
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 9 LCD Replacement: passo 25, imagem 1 %32 iPad 9 LCD Replacement: passo 25, imagem 2 %32
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
    • Throughout the remaining steps, try not to touch the back side of the glass or the surface of the LCD with your fingers—any fingerprints can be tough to clean off.
  26. iPad 9 LCD Replacement, Separate the right adhesive: passo 26, imagem 1 %32 iPad 9 LCD Replacement, Separate the right adhesive: passo 26, imagem 2 %32 iPad 9 LCD Replacement, Separate the right adhesive: passo 26, imagem 3 %32
  27. iPad 9 LCD Replacement: passo 27, imagem 1 %32 iPad 9 LCD Replacement: passo 27, imagem 2 %32
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 9 LCD Replacement, Remove the LCD: passo 28, imagem 1 %32 iPad 9 LCD Replacement, Remove the LCD: passo 28, imagem 2 %32
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.2 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPad.
  29. iPad 9 LCD Replacement, Flip the LCD over: passo 29, imagem 1 %32 iPad 9 LCD Replacement, Flip the LCD over: passo 29, imagem 2 %32 iPad 9 LCD Replacement, Flip the LCD over: passo 29, imagem 3 %32
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
  30. iPad 9 LCD Replacement, Disconnect the battery: passo 30, imagem 1 %32 iPad 9 LCD Replacement, Disconnect the battery: passo 30, imagem 2 %32
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 9 LCD Replacement, Battery connector information: passo 31, imagem 1 %32 iPad 9 LCD Replacement, Battery connector information: passo 31, imagem 2 %32 iPad 9 LCD Replacement, Battery connector information: passo 31, imagem 3 %32
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 9 LCD Replacement, Disconnect the battery: passo 32, imagem 1 %32 iPad 9 LCD Replacement, Disconnect the battery: passo 32, imagem 2 %32 iPad 9 LCD Replacement, Disconnect the battery: passo 32, imagem 3 %32
    • Follow the instructions carefully if you're isolating the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 9 LCD Replacement, Unfasten the display cable bracket: passo 33, imagem 1 %32 iPad 9 LCD Replacement, Unfasten the display cable bracket: passo 33, imagem 2 %32
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 9 LCD Replacement, Remove the display cable bracket: passo 34, imagem 1 %32 iPad 9 LCD Replacement, Remove the display cable bracket: passo 34, imagem 2 %32
    • Remove the display cable bracket.
  35. iPad 9 LCD Replacement, Disconnect the LCD: passo 35, imagem 1 %32 iPad 9 LCD Replacement, Disconnect the LCD: passo 35, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 9 LCD Replacement, Remove the LCD: passo 36, imagem 1 %32 iPad 9 LCD Replacement, Remove the LCD: passo 36, imagem 2 %32
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
14 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
213.425 Reputação
Autoria de 1.040 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.648 guias
2Comentários do guia
I love you guys and what you do here, but this is not an iPad 9 in your photos. Although there are similarities with the 7th and 8th Gen, there are also some minor differences between those and the 9th gen. The front camera retention bracket (which is why I wanted to view this tear down. The replacement screen I was sent from a different vendor (not from ifixit, I'll clarify) as a 9th gen did not have the proper orientation of the camera retention bracket, nor the openings for the dual ambient light sensors. The adhesive cutout is also different on the 9th gen to accommodate these things) is not the same as the 7th and 8th gen. As a matter of fact, many part suppliers are selling 7th gen screens as compatible with 9th gen iPads. The connectors may be the same, but the location of the ambient light sensors as well as the camera retention bracket and home button flex hold down are NOT the same. I know for the basic repair technique they are similar, but there does seem to be some confusion in the industry about these minor (but important) differences.
Chad McCollister - Responder
Hi Chad!
Thanks for your response and feedback. Yes, you're right—the top half of the iPad 9 is quite different from previous generations. This is actually why we haven't posted any guides for the front-facing camera or other top components—we're currently writing the specific guides! This guide is specifically for replacing the LCD panel. We decided to use existing content because the procedure is the same, and the new changes shouldn't affect the LCD replacement procedure.
Arthur Shi -
Comentar
Visualizações:
Últimas 24 horas: 42
Últimos 7 dias: 282
Últimos 30 dias: 1,301
Ao todo: 49,615
