Ir para o conteúdo principal
Ajuda
HP Compaq 6730b Display Replacement
Editando passo 9 —
Tipo de Passo:
Arraste para reorganizar
Remove one of the two T8 M2.5×9.0 screws that secure the display assembly to the computer. The screw on the left display assembly hinge secures a display panel cable ground loop.
The second screw on the left side is only 3mm in length but must be removed as well
Pull the two antenna cables out from the bottom of the case.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
