Ir para o conteúdo principal
Ajuda
HP Compaq 6730b Display Replacement
Editando passo 7 —
Tipo de Passo:
Arraste para reorganizar
Close the computer and position it with the rear panel toward you. Remove the four Torx T8 M2.5×9.0 screws that secure the display assembly to the computer.
There are two on the left side,
Notice cracked bottom case from impact, no sequela from it.
and two screws on the right. Note the slots in the screw heads. these screws can also be removed with a flat tip screwdriver.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
