Ir para o conteúdo principal
Ajuda
Opening Procedure
Editando passo 3 —
Aviso: Você está editando um guia tipo pré-requisito. Todas as alterações que você fizer afetarão todos os 73 guias que incluem este passo.
Tipo de Passo:
Arraste para reorganizar
The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
For complete instructions on how to use the Anti-Clamp, check out this guide.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
