Ir para o conteúdo principal
Ajuda
MacBook Pro 16" 2019 Screen Replacement
Editando passo 19 —
Tipo de Passo:
Arraste para reorganizar
During reassembly, first install the hinge screws without tightening them. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
