Ir para o conteúdo principal
MacBook Pro 16" 2019 Screen Replacement
O que você precisa
  1. MacBook Pro 16" 2019 Screen Replacement, Disable Auto Boot: passo 1, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disable Auto Boot: passo 1, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement, Disable Auto Boot: passo 1, imagem 3 %32
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Pergunte ao FixBot
    Comentar
  2. MacBook Pro 16" 2019 Screen Replacement, Remove lower case screws: passo 2, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove lower case screws: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 3.7 mm screws
    • Two 7.3 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Pergunte ao FixBot
    Comentar
  3. MacBook Pro 16" 2019 Screen Replacement, Unclip lower case: passo 3, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Unclip lower case: passo 3, imagem 2 %32
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
    Pergunte ao FixBot
    Comentar
  4. MacBook Pro 16" 2019 Screen Replacement: passo 4, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 4, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 4, imagem 3 %32
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
    Pergunte ao FixBot
    Comentar
  5. MacBook Pro 16" 2019 Screen Replacement: passo 5, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 5, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 5, imagem 3 %32
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
    Pergunte ao FixBot
    Comentar
  6. MacBook Pro 16" 2019 Screen Replacement: passo 6, imagem 1 %32
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
    Pergunte ao FixBot
    Comentar
  7. MacBook Pro 16" 2019 Screen Replacement: passo 7, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 7, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 7, imagem 3 %32
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    Pergunte ao FixBot
    Comentar
  8. MacBook Pro 16" 2019 Screen Replacement, Remove lower case: passo 8, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove lower case: passo 8, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement, Remove lower case: passo 8, imagem 3 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    Pergunte ao FixBot
    Comentar
  9. MacBook Pro 16" 2019 Screen Replacement, Remove battery board sticker: passo 9, imagem 1 %32
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
    Pergunte ao FixBot
    Comentar
  10. MacBook Pro 16" 2019 Screen Replacement: passo 10, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 10, imagem 2 %32
    • Peel back any tape covering the battery board data cable connector.
    Pergunte ao FixBot
    Comentar
  11. MacBook Pro 16" 2019 Screen Replacement, Disconnect battery board data cable: passo 11, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect battery board data cable: passo 11, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
    Pergunte ao FixBot
    Comentar
  12. MacBook Pro 16" 2019 Screen Replacement: passo 12, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 12, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board. Don't pull up.
    Pergunte ao FixBot
    Comentar
  13. MacBook Pro 16" 2019 Screen Replacement: passo 13, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 13, imagem 2 %32
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
    Pergunte ao FixBot
    Comentar
  14. MacBook Pro 16" 2019 Screen Replacement, Remove battery board data cable: passo 14, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove battery board data cable: passo 14, imagem 2 %32
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to reinstall this cable backwards or upside-down.
    Pergunte ao FixBot
    Comentar
  15. MacBook Pro 16" 2019 Screen Replacement, Disconnect the battery: passo 15, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect the battery: passo 15, imagem 2 %32
    • Use a T5 Torx driver to remove the 6.7 mm pancake screw securing the battery power connector.
    Pergunte ao FixBot
    Comentar
  16. MacBook Pro 16" 2019 Screen Replacement: passo 16, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 16, imagem 2 %32
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
    Pergunte ao FixBot
    Comentar
  17. MacBook Pro 16" 2019 Screen Replacement, Disconnect the display board cable: passo 17, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect the display board cable: passo 17, imagem 2 %32
    • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
    • Remove the display board flex cover.
    Pergunte ao FixBot
    Comentar
  18. MacBook Pro 16" 2019 Screen Replacement: passo 18, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 18, imagem 2 %32
    • Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
    • Remove the display board cable connector bracket.
    Pergunte ao FixBot
    Comentar
  19. MacBook Pro 16" 2019 Screen Replacement: passo 19, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 19, imagem 2 %32
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
    Pergunte ao FixBot
    Comentar
  20. MacBook Pro 16" 2019 Screen Replacement, Remove the hinge covers: passo 20, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the hinge covers: passo 20, imagem 2 %32
    • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
    Pergunte ao FixBot
    Comentar
  21. MacBook Pro 16" 2019 Screen Replacement: passo 21, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 21, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 21, imagem 3 %32
    • Remove both hinge covers.
    Pergunte ao FixBot
    Comentar
  22. MacBook Pro 16" 2019 Screen Replacement, Disconnect the antenna bundle: passo 22, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect the antenna bundle: passo 22, imagem 2 %32
    • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
    Pergunte ao FixBot
    Comentar
  23. MacBook Pro 16" 2019 Screen Replacement: passo 23, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 23, imagem 2 %32
    • Disconnect all three antenna cables by prying each one straight up from its socket.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
    Pergunte ao FixBot
    Comentar
  24. MacBook Pro 16" 2019 Screen Replacement, Disconnect the display board: passo 24, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect the display board: passo 24, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect the display board: passo 24, imagem 3 %32
    • Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
    • Before reinstalling these screws:
    • Make sure the display board flex cable lies on top of the board, not trapped underneath.
    Pergunte ao FixBot
    Comentar
  25. MacBook Pro 16" 2019 Screen Replacement, Remove the antenna assembly: passo 25, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the antenna assembly: passo 25, imagem 2 %32
    • Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly (eight on each side).
    • These small screws can strip easily, so apply firm, consistent pressure when removing.
    Pergunte ao FixBot
    Comentar
  26. MacBook Pro 16" 2019 Screen Replacement: passo 26, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 26, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 26, imagem 3 %32
    • Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro.
    • Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
    Pergunte ao FixBot
    Comentar
  27. MacBook Pro 16" 2019 Screen Replacement: passo 27, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 27, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 27, imagem 3 %32
    • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
    Pergunte ao FixBot
    Comentar
  28. MacBook Pro 16" 2019 Screen Replacement, Disconnect the display cable cover springs: passo 28, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Disconnect the display cable cover springs: passo 28, imagem 2 %32
    • Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
    Pergunte ao FixBot
    Comentar
  29. MacBook Pro 16" 2019 Screen Replacement, Remove some of the hinge screws: passo 29, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove some of the hinge screws: passo 29, imagem 2 %32
    • Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total).
    • Each hinge has a third screw, which you should leave in place for now.
    Pergunte ao FixBot
    Comentar
  30. MacBook Pro 16" 2019 Screen Replacement, Disconnect the lid angle sensor: passo 30, imagem 1 %32
    • Using a T3 Torx driver, remove the two 1.5 mm screws securing the cover bracket for the Touch Bar digitizer and lid angle sensor connectors.
    Pergunte ao FixBot
    Comentar
  31. MacBook Pro 16" 2019 Screen Replacement: passo 31, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 31, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement: passo 31, imagem 3 %32
    • Using your tweezers, slide the bracket toward the side edge of the MacBook Pro until it clears the slotted retaining tab on the logic board.
    • Remove the bracket.
    Pergunte ao FixBot
    Comentar
  32. MacBook Pro 16" 2019 Screen Replacement: passo 32, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 32, imagem 2 %32
    • Disconnect the lid angle sensor cable by prying it straight up from the logic board.
    Pergunte ao FixBot
    Comentar
  33. MacBook Pro 16" 2019 Screen Replacement, Unfasten the lid angle sensor: passo 33, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Unfasten the lid angle sensor: passo 33, imagem 2 %32
    • Use a P2 Pentalobe driver to remove the 1.9 mm-long screw securing the lid angle sensor.
    Pergunte ao FixBot
    Comentar
  34. MacBook Pro 16" 2019 Screen Replacement, Remove the lid angle sensor: passo 34, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the lid angle sensor: passo 34, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the lid angle sensor: passo 34, imagem 3 %32
    • Use tweezers, or your fingers, to pull the lid angle sensor up from the frame and release it from its metal peg.
    • Remove the lid angle sensor.
    Pergunte ao FixBot
    Comentar
  35. MacBook Pro 16" 2019 Screen Replacement: passo 35, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement: passo 35, imagem 2 %32
    • During reassembly, first install the hinge screws without tightening them. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
    • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
    • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
    Pergunte ao FixBot
    Comentar
  36. MacBook Pro 16" 2019 Screen Replacement, Protect the MacBook: passo 36, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Protect the MacBook: passo 36, imagem 2 %32
    • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
    • Fully open the screen and stand your MacBook Pro up on one side.
    Pergunte ao FixBot
    Comentar
  37. MacBook Pro 16" 2019 Screen Replacement, Remove the remaining hinge screws: passo 37, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the remaining hinge screws: passo 37, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the remaining hinge screws: passo 37, imagem 3 %32
    • Use a T8 Torx driver to remove the two remaining 5.0 mm hinge screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
    Pergunte ao FixBot
    Comentar
  38. MacBook Pro 16" 2019 Screen Replacement, Remove the screen: passo 38, imagem 1 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the screen: passo 38, imagem 2 %32 MacBook Pro 16" 2019 Screen Replacement, Remove the screen: passo 38, imagem 3 %32
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
    Pergunte ao FixBot
    Comentar
  39. MacBook Pro 16" 2019 Screen Replacement: passo 39, imagem 1 %32
    • Remove the screen.
    Pergunte ao FixBot
    Comentar
Conclusão
66 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
166.168 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.593 guias
28Comentários do guia
Anybody know the screen part# or where to find it?
Macrepair SF - Responder Compartilhar
Ou est ce qu’on trouve l’écran ?
haddad biadja - Responder Compartilhar
Jean Christophe BOURBON - Responder Compartilhar
Is it possible to boot up the machine without the screen attached (and use external displays only)?
Pravin Jayasinghe - Responder Compartilhar
yes USBC to HDMI
jim - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 49
Últimos 7 dias: 612
Últimos 30 dias: 1,902
Ao todo: 172,311
