Introdução
Use this guide to replace a worn-out or dead battery in your Xiaomi Redmi Note 8T.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Passo 9 Xiaomi Redmi Note 8T Motherboard Cover Removal
Cuidado: as etapas de 9 a 11 são provenientes de um guia marcado como em andamento.
Remove the eleven Phillips #00 screws (3.9 mm length).
Passo 12 Xiaomi Redmi Note 8T Battery Disconnect
Cuidado: a etapa 12 é proveniente de um guia marcado como em andamento.
Use a spudger to pry up and disconnect the battery flex cable.
Use a pair of tweezers to pull out the adhesive tabs from underneath the battery.
If you manage to pull out both of the adhesive strips without ripping you can jump to Step 21 in order to remove the battery. If one of your adhesive strips rips during the removal, continue with the following step.
Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Slide the plastic card underneath the battery and cut the adhesive with it. Work your way along the left edge of the battery until you've loosened all adhesive.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, '''calibrate your newly installed battery''': Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
12 outras pessoas executaram este guia.
2 comentários
Vielen Dank Spitze gut geführte Anleitung
