Introdução
Prerequisite only! Use this guide to disconnect the battery in your Xiaomi Redmi Note 8T.
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Passo 9 Xiaomi Redmi Note 8T Motherboard Cover Removal
Cuidado: as etapas de 9 a 11 são provenientes de um guia marcado como em andamento.
Remove the eleven Phillips #00 screws (3.9 mm length).
Use a spudger to pry up and disconnect the battery flex cable.
