Ir para o conteúdo principal
Xiaomi Redmi Note 10S Battery Replacement
O que você precisa
  1. Xiaomi Redmi Note 10S Battery Replacement, Heat the back cover: passo 1, imagem 1 %32
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 10S Battery Replacement, Insert an opening pick: passo 2, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Insert an opening pick: passo 2, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 3, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 3, imagem 2 %32
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 4, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 4, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 4, imagem 3 %32
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • You can remove the suction cup now.
  5. Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 5, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 5, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 5, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 6, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 6, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 6, imagem 3 %32
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  7. Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 7, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 7, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Slice the adhesive: passo 7, imagem 3 %32
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  8. Xiaomi Redmi Note 10S Battery Replacement, Remove the back cover: passo 8, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the back cover: passo 8, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the back cover: passo 8, imagem 3 %32
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. Xiaomi Redmi Note 10S Battery Replacement, Unfasten the camera cover screws: passo 9, imagem 1 %32
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the camera cover.
    • One of the screws is hidden beneath an orange sticker.
  10. Xiaomi Redmi Note 10S Battery Replacement, Pry up the camera cover: passo 10, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Pry up the camera cover: passo 10, imagem 2 %32
    • Insert an opening pick into the gap beneath the bottom edge of the camera cover.
    • Pry up the camera cover with your opening pick.
  11. Xiaomi Redmi Note 10S Battery Replacement, Remove the camera cover: passo 11, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the camera cover: passo 11, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use your fingers or a pair of tweezers to remove the camera cover.
  12. Xiaomi Redmi Note 10S Battery Replacement, Unfasten the midframe screws: passo 12, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Unfasten the midframe screws: passo 12, imagem 2 %32
    • Use a Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the midframe.
  13. Xiaomi Redmi Note 10S Battery Replacement, Eject the SIM card tray: passo 13, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Eject the SIM card tray: passo 13, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Eject the SIM card tray: passo 13, imagem 3 %32
    • Insert a SIM card eject tool into the small hole in the SIM card tray, located at the left edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  14. Xiaomi Redmi Note 10S Battery Replacement, Disconnect the power and volume button flex cable: passo 14, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Disconnect the power and volume button flex cable: passo 14, imagem 2 %32
    • Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
  15. Xiaomi Redmi Note 10S Battery Replacement, Insert an opening pick: passo 15, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Insert an opening pick: passo 15, imagem 2 %32
    • The midframe of the Xiaomi Redmi Note 10S is held in place by plastic clips.
    • Insert an opening pick between the midframe and display assembly on the left edge of the phone where the SIM tray slot is located.
    • Make sure to insert the opening pick between the midframe and the display frame to avoid separating the screen from the frame.
  16. Xiaomi Redmi Note 10S Battery Replacement, Release the plastic clips: passo 16, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Release the plastic clips: passo 16, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Release the plastic clips: passo 16, imagem 3 %32
    • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
    • Slide the opening pick along the left edge of the phone to release the plastic clips.
  17. Xiaomi Redmi Note 10S Battery Replacement: passo 17, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement: passo 17, imagem 2 %32
    • Slide the opening pick along the bottom edge of the phone to release the plastic clips.
  18. Xiaomi Redmi Note 10S Battery Replacement: passo 18, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement: passo 18, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement: passo 18, imagem 3 %32
    • Slide the opening pick along the right edge of the phone to release the plastic clips.
  19. Xiaomi Redmi Note 10S Battery Replacement: passo 19, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement: passo 19, imagem 2 %32
    • Slide the opening pick along the top edge of the phone to release the remaining plastic clips.
  20. Xiaomi Redmi Note 10S Battery Replacement, Remove the midframe: passo 20, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the midframe: passo 20, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the midframe: passo 20, imagem 3 %32
    • Before removing the midframe make sure the power and volume button flex cable is freed and not tangled with the motherboard to avoid tearing it.
    • Remove the midframe.
  21. Xiaomi Redmi Note 10S Battery Replacement, Disconnect the battery cable: passo 21, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Disconnect the battery cable: passo 21, imagem 2 %32
    • Use a spudger to disconnect the battery flex cable by prying the connector straight up from its socket.
  22. Xiaomi Redmi Note 10S Battery Replacement, Disconnect the daughterboard connection cable: passo 22, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Disconnect the daughterboard connection cable: passo 22, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Disconnect the daughterboard connection cable: passo 22, imagem 3 %32
    • Use a spudger to disconnect both ends of the daughterboard connection cable.
    • Remove the daughterboard connection cable.
  23. Xiaomi Redmi Note 10S Battery Replacement, Peel off the pull-tabs: passo 23, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Peel off the pull-tabs: passo 23, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Peel off the pull-tabs: passo 23, imagem 3 %32
    Comprar
    • The battery is secured to the rear case with two pieces of stretch-release adhesive.
    • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel off both battery adhesive pull-tabs to unstick them from the top edge of the battery.
  24. Xiaomi Redmi Note 10S Battery Replacement, Remove the pull-tab: passo 24, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the pull-tab: passo 24, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the pull-tab: passo 24, imagem 3 %32
    • Grab the first pull-tab with a pair of blunt nose tweezers or your fingers and slowly pull it away from the battery towards the top edge of your phone.
    • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and unstick from under the battery.
    • Don't press down on the battery. Hold the phone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling in the middle or on one side.
    • Pull at a low angle so the strip doesn't snag on the edge of the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  25. Xiaomi Redmi Note 10S Battery Replacement: passo 25, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement: passo 25, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement: passo 25, imagem 3 %32
    • Repeat the previous pull-tab removal procedure on the second pull-tab.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  26. Xiaomi Redmi Note 10S Battery Replacement, Remove the battery: passo 26, imagem 1 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the battery: passo 26, imagem 2 %32 Xiaomi Redmi Note 10S Battery Replacement, Remove the battery: passo 26, imagem 3 %32
    • Remove the battery.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard before you press it into place to help align it correctly. Disconnect the battery after it's seated.
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 outras pessoas executaram este guia.
Manuel Haeussermann
Membro desde: 07/13/22
16.286 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.086 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 74
Últimos 30 dias: 334
Duração total: 3,264
