Ir para o conteúdo principal
Voluas VL001 USB Replacement
O que você precisa
    1. Voluas VL001 USB Replacement, Storage Tank: passo 1, imagem 1 %32 Voluas VL001 USB Replacement, Storage Tank: passo 1, imagem 2 %32 Voluas VL001 USB Replacement, Storage Tank: passo 1, imagem 3 %32
      • Remove the lid to the storage tank by using the latch and lifting off.
      • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
      Pergunte ao FixBot
      Comentar
    1. Voluas VL001 USB Replacement, Battery: passo 2, imagem 1 %32 Voluas VL001 USB Replacement, Battery: passo 2, imagem 2 %32 Voluas VL001 USB Replacement, Battery: passo 2, imagem 3 %32
      • Place your pet feeder upside down.
      • Squeeze the lock and remove the battery cover.
      • Remove the three 1.5V D alkaline batteries.
      Pergunte ao FixBot
      Comentar
    1. Voluas VL001 USB Replacement, Housing: passo 3, imagem 1 %32 Voluas VL001 USB Replacement, Housing: passo 3, imagem 2 %32 Voluas VL001 USB Replacement, Housing: passo 3, imagem 3 %32
      • Insert a metal spudger under the adhesive part of each rubber foot.
      • Pry the foot off.
      Pergunte ao FixBot
      Comentar
    2. Voluas VL001 USB Replacement: passo 4, imagem 1 %32 Voluas VL001 USB Replacement: passo 4, imagem 2 %32
      • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
      • These holes were previously covered by the rubber feet.
      • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
      Pergunte ao FixBot
      Comentar
    3. Voluas VL001 USB Replacement: passo 5, imagem 1 %32
      • Turn the device over so it is oriented right-side up.
      • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
      Pergunte ao FixBot
      Comentar
    1. Voluas VL001 USB Replacement, USB: passo 6, imagem 1 %32 Voluas VL001 USB Replacement, USB: passo 6, imagem 2 %32
      • Using a Phillips #2 screwdriver, carefully remove the two 11.2 mm screws on either side of the USB port.
      Pergunte ao FixBot
      Comentar
    2. Voluas VL001 USB Replacement: passo 7, imagem 1 %32 Voluas VL001 USB Replacement: passo 7, imagem 2 %32
      • Using your wire strippers/pliers, cut the three wires that are connected to the USB port.
      Pergunte ao FixBot
      Comentar
    3. Voluas VL001 USB Replacement: passo 8, imagem 1 %32 Voluas VL001 USB Replacement: passo 8, imagem 2 %32 Voluas VL001 USB Replacement: passo 8, imagem 3 %32
      • Using your wire strippers/pliers, gently crimp the plastic insulation on the wire. Do this several times around the wire to make sure that you can pull it off.
      • Because the wire is so thin, it can be easy to accidentally cut all the way through the wire on this step. Take care to only cut through the insulation.
      • You will want to see a score line in the insulation all around the wire like this.
      • Pull the end of the insulation off, exposing the wire.
      Pergunte ao FixBot
      Comentar
    4. Voluas VL001 USB Replacement: passo 9, imagem 1 %32 Voluas VL001 USB Replacement: passo 9, imagem 2 %32
      • Put the exposed wire on the solder patch, making sure it has good contact with the metal.
      • Solder the wire on to the solder patch.
      • Repeat steps 8 and 9 for the other two wires.
      Pergunte ao FixBot
      Comentar
Conclusão
Merari Aniga
Membro desde: 01/30/24
459 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 556
