Ir para o conteúdo principal
ThinkPad T420 Keyboard Replacement
O que você precisa
    1. ThinkPad T420 Keyboard Replacement, Change note: passo 1, imagem 1 %32 ThinkPad T420 Keyboard Replacement, Change note: passo 1, imagem 2 %32
      Ferramenta utilizada neste passo:
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Pergunte ao FixBot
      Comentar
    1. ThinkPad T420 Keyboard Replacement, Keyboard FRU: passo 2, imagem 1 %32
      • If the label on the back of the keyboard is not worn, that can be used to reference which keyboard is needed.
      • IMPORTANT: Each country has a different keyboard FRU part number. To match the keyboard you have and which one you need to purchase, check the back label or refer to the Lenovo HMM.
      Pergunte ao FixBot
      Comentar
    1. ThinkPad T420 Keyboard Replacement, Unlock the battery: passo 3, imagem 1 %32 ThinkPad T420 Keyboard Replacement, Unlock the battery: passo 3, imagem 2 %32 ThinkPad T420 Keyboard Replacement, Unlock the battery: passo 3, imagem 3 %32
      • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
      • Unlock the latch locking the battery in the laptop.
      • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
      Pergunte ao FixBot
      Comentar
    2. ThinkPad T420 Keyboard Replacement, Release the battery: passo 4, imagem 1 %32 ThinkPad T420 Keyboard Replacement, Release the battery: passo 4, imagem 2 %32 ThinkPad T420 Keyboard Replacement, Release the battery: passo 4, imagem 3 %32
      • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
      Pergunte ao FixBot
      Comentar
    1. ThinkPad T420 Keyboard Replacement, Remove the RAM door: passo 5, imagem 1 %32 ThinkPad T420 Keyboard Replacement, Remove the RAM door: passo 5, imagem 2 %32 ThinkPad T420 Keyboard Replacement, Remove the RAM door: passo 5, imagem 3 %32
      • EET owners: Your kit has this bit. No purchase needed.
      • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
      • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
      • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
      • Pull the cover up with a fingernail or a nonmarring pry tool.
      • Remove the screw retaining the keyboard.
      Pergunte ao FixBot
      Comentar
    2. ThinkPad T420 Keyboard Replacement, Remove the keyboard: passo 6, imagem 1 %32 ThinkPad T420 Keyboard Replacement, Remove the keyboard: passo 6, imagem 2 %32 ThinkPad T420 Keyboard Replacement, Remove the keyboard: passo 6, imagem 3 %32
      • Open the laptop.
      • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
      • Once the keyboard is loose, remove it from the chassis.
      Pergunte ao FixBot
      Comentar
    3. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: passo 7, imagem 1 %32 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: passo 7, imagem 2 %32 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: passo 7, imagem 3 %32
      • To reinstall the keyboard, refer to the steps in this guide.
      • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
      • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
      • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
10 outras pessoas executaram este guia.
Nick
Membro desde: 11/10/09
105.431 Reputação
Autoria de 72 guias
3Comentários do guia
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - Responder Compartilhar
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - Responder Compartilhar
I love how simply disassemby are in those old ThinkPads <3
Ziobro - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 40
Últimos 30 dias: 187
Ao todo: 16,191
