Ir para o conteúdo principal
Spy Net Ultra Vision Goggles Infrared Lights Replacement
O que você precisa
  1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Device: passo 1, imagem 1 %32
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    Pergunte ao FixBot
    Comentar
  2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: passo 2, imagem 1 %32 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: passo 2, imagem 2 %32 Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: passo 2, imagem 3 %32
    • Find the infrared light assemblies, which are located at the front end of the device on either side of the lens.
    • The process is the same regardless of which light you are replacing.
    • Lift the light assembly away from the rest of the device.
    Pergunte ao FixBot
    Comentar
  3. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Light Assembly: passo 3, imagem 1 %32
    • Use the plastic opening tools to pry open the light assembly.
    Pergunte ao FixBot
    Comentar
  4. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Disconnect the Lights: passo 4, imagem 1 %32
    • Use the soldering iron and desoldering braid to de-solder the wires from the lights.
    • Check out This Guide for tips on soldering and de-soldering connections.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 4-5, Brown Fall 2014 Membro de USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Membros
Autoria de 6 guias
1Comentário do guia
thanks for the help
vincentarriesgado - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 1,327
