Ir para o conteúdo principal
Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement
O que você precisa
  1. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Open the Device: passo 1, imagem 1 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Open the Device: passo 1, imagem 2 %32
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the device shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    Pergunte ao FixBot
    Comentar
  2. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Foam Covering the Main Circuit Board: passo 2, imagem 1 %32
    • Use your fingers to peel off the foam pad that covers the main circuit board.
    • Be careful not to tear the foam pad.
    Pergunte ao FixBot
    Comentar
  3. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Circuit Board: passo 3, imagem 1 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Circuit Board: passo 3, imagem 2 %32
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and lift it out of its place.
    • Be careful not to put too much tension on the various wires.
    Pergunte ao FixBot
    Comentar
  4. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the MicroSD Card Reader: passo 4, imagem 1 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the MicroSD Card Reader: passo 4, imagem 2 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the MicroSD Card Reader: passo 4, imagem 3 %32
    • Remove the one black 7.2 mm Phillips #0 screw from the plastic piece that holds down the microSD card reader wires.
    • Remove the two black 7.2 mm Phillips #0 screws that hold the microSD card reader in place.
    • You should now be able to lift the microSD card reader out of place.
    Pergunte ao FixBot
    Comentar
  5. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Camera & Display Screen Assembly: passo 5, imagem 1 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Camera & Display Screen Assembly: passo 5, imagem 2 %32
    • Remove the two black Phillips #0 screws that hold down the camera & display screen assembly.
    • Pull the camera & display screen assembly up from its slot in the device.
    Pergunte ao FixBot
    Comentar
  6. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Detach the Screen Assembly: passo 6, imagem 1 %32
    • Remove the four black 7.2 mm Phillips #0 screws that hold the screen assembly in place.
    Pergunte ao FixBot
    Comentar
  7. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Lens & Filter Assembly: passo 7, imagem 1 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Lens & Filter Assembly: passo 7, imagem 2 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Remove the Lens & Filter Assembly: passo 7, imagem 3 %32
    • Turn the device around to the other side and lift up the screen assembly.
    • Remove the four black 7.2 mm Phillips #00 screws that hold the lens & filter assembly in place.
    • Pull the lens & filter assembly away from the circuit board.
    Pergunte ao FixBot
    Comentar
  8. Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Detach the Wires: passo 8, imagem 1 %32 Spy Net Ultra Vision Goggles Camera & Display Screen Assembly Replacement, Detach the Wires: passo 8, imagem 2 %32
    • Using the soldering iron, de-solder the various wires from the front and back of the circuit board.
    • There are three pairs of wires on the front side, along with a set of 7 leads for the main circuit board connector.
    • On the back side, there is a set of 9 leads for the microSD card connector.
    • Check out This Guide for tips on soldering and de-soldering.
    Pergunte ao FixBot
    Comentar
Conclusão
Andrew Gittens
Membro desde: 09/22/14
143 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 4-5, Brown Fall 2014 Membro de USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Membros
Autoria de 6 guias
2Comentários do guia
Boa tarde , na verdade não um comentario, meu spy ney esta com defeito( LCD display)gostaria quem pode me ajudar a me fornecer outro LCD com a placa, nome da loja, site, para exportar pro Brasil.
ribeiro928 - Responder Compartilhar
I’ve just bought one of these for £3, wondered if it’d be too risky to experiment with if I was to circuit bend it? I create visuals & if I added a couple of potentiometers to it, I’d be interested to see if I could get any wild effects from it. It’d be great if I could achieve it with this as I’d hopefully be able to save the videos too in order to put into my animations. Do you think I should avoid it, or has anyone attempted circuit bending one of these? Cheers
Neil Beil - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 44
Ao todo: 1,601
