Ir para o conteúdo principal
Sony DualSense Controller Battery Replacement
O que você precisa
  1. Sony DualSense Controller Battery Replacement, Unclip the right end of the middle trim: passo 1, imagem 1 %32 Sony DualSense Controller Battery Replacement, Unclip the right end of the middle trim: passo 1, imagem 2 %32
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
    Pergunte ao FixBot
    Comentar
  2. Sony DualSense Controller Battery Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 1 %32 Sony DualSense Controller Battery Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 2 %32 Sony DualSense Controller Battery Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 3 %32
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
    Pergunte ao FixBot
    Comentar
  3. Sony DualSense Controller Battery Replacement, Unclip the left end of the middle trim: passo 3, imagem 1 %32 Sony DualSense Controller Battery Replacement, Unclip the left end of the middle trim: passo 3, imagem 2 %32
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
    Pergunte ao FixBot
    Comentar
  4. Sony DualSense Controller Battery Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 1 %32 Sony DualSense Controller Battery Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 2 %32 Sony DualSense Controller Battery Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 3 %32
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
    Pergunte ao FixBot
    Comentar
  5. Sony DualSense Controller Battery Replacement, Remove the middle trim: passo 5, imagem 1 %32 Sony DualSense Controller Battery Replacement, Remove the middle trim: passo 5, imagem 2 %32 Sony DualSense Controller Battery Replacement, Remove the middle trim: passo 5, imagem 3 %32
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    Pergunte ao FixBot
    Comentar
  6. Sony DualSense Controller Battery Replacement, Remove the L1 button: passo 6, imagem 1 %32 Sony DualSense Controller Battery Replacement, Remove the L1 button: passo 6, imagem 2 %32 Sony DualSense Controller Battery Replacement, Remove the L1 button: passo 6, imagem 3 %32
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
    Pergunte ao FixBot
    Comentar
  7. Sony DualSense Controller Battery Replacement, Remove the R1 button: passo 7, imagem 1 %32 Sony DualSense Controller Battery Replacement, Remove the R1 button: passo 7, imagem 2 %32 Sony DualSense Controller Battery Replacement, Remove the R1 button: passo 7, imagem 3 %32
    • Repeat the previous step to remove the R1 button.
    Pergunte ao FixBot
    Comentar
  8. Sony DualSense Controller Battery Replacement, Remove the rear case screws: passo 8, imagem 1 %32 Sony DualSense Controller Battery Replacement, Remove the rear case screws: passo 8, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
    Pergunte ao FixBot
    Comentar
  9. Sony DualSense Controller Battery Replacement: passo 9, imagem 1 %32 Sony DualSense Controller Battery Replacement: passo 9, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
    Pergunte ao FixBot
    Comentar
  10. Sony DualSense Controller Battery Replacement, Separate the rear case: passo 10, imagem 1 %32 Sony DualSense Controller Battery Replacement, Separate the rear case: passo 10, imagem 2 %32 Sony DualSense Controller Battery Replacement, Separate the rear case: passo 10, imagem 3 %32
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
    Pergunte ao FixBot
    Comentar
  11. Sony DualSense Controller Battery Replacement: passo 11, imagem 1 %32 Sony DualSense Controller Battery Replacement: passo 11, imagem 2 %32 Sony DualSense Controller Battery Replacement: passo 11, imagem 3 %32
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
    Pergunte ao FixBot
    Comentar
  12. Sony DualSense Controller Battery Replacement: passo 12, imagem 1 %32 Sony DualSense Controller Battery Replacement: passo 12, imagem 2 %32 Sony DualSense Controller Battery Replacement: passo 12, imagem 3 %32
    • Repeat the previous step on the right edge to release its clips.
    Pergunte ao FixBot
    Comentar
  13. Sony DualSense Controller Battery Replacement: passo 13, imagem 1 %32 Sony DualSense Controller Battery Replacement: passo 13, imagem 2 %32
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
    Pergunte ao FixBot
    Comentar
  14. Sony DualSense Controller Battery Replacement, Remove the rear case: passo 14, imagem 1 %32
    • Remove the rear case.
    Pergunte ao FixBot
    Comentar
  15. Sony DualSense Controller Battery Replacement, Disconnect the battery: passo 15, imagem 1 %32 Sony DualSense Controller Battery Replacement, Disconnect the battery: passo 15, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
    Pergunte ao FixBot
    Comentar
  16. Sony DualSense Controller Battery Replacement, Remove the battery: passo 16, imagem 1 %32 Sony DualSense Controller Battery Replacement, Remove the battery: passo 16, imagem 2 %32
    • Lift the battery straight out of the battery bracket.
    Pergunte ao FixBot
    Comentar
Conclusão
116 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
99.285 Reputação
Autoria de 290 guias
19Comentários do guia
Is there a better battery that can be used rather than the standard battery? This controller dies so fast that I don’t bother disconnecting it ever. I’m pretty sure that’s bad, but It’s frustrating having it die midgame in my second game.
Anthony Ramirez - Responder Compartilhar
Yes. You can purchase a 2000mah battery replacement. It’s not much of a difference, but lowering your led settings and controller vibration also works wonders for prolonging the battery life.
John Jevitz - Responder Compartilhar
Any chance you could figure out why the %#*@ thing won't work USB powered with no battery? I shouldn't have to keep replacing a battery when I don't actually want to play wireless.
NoLife - Responder Compartilhar
@NoLife
If you bridge the pins for the red and white battery wires, the controller will power on properly without a battery. This will be easiest with a soldering iron.
Amboy Scout - Responder Compartilhar
I need a new battery for my Dualsense controller, Sony is saying to just buy a new one while I'm not gonna take broken for a answer. So if anyone knows a reliable site where I can get a battery replacement for my dualsense, do recommend
Diaper Fixer 360 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 165
Últimos 7 dias: 1,439
Últimos 30 dias: 6,084
Ao todo: 232,040
