Ir para o conteúdo principal
Sonos Roam Speaker Module Replacement
O que você precisa
  1. Sonos Roam Speaker Module Replacement, End Caps: passo 1, imagem 1 %32 Sonos Roam Speaker Module Replacement, End Caps: passo 1, imagem 2 %32 Sonos Roam Speaker Module Replacement, End Caps: passo 1, imagem 3 %32
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
    Pergunte ao FixBot
    Comentar
  2. Sonos Roam Speaker Module Replacement: passo 2, imagem 1 %32 Sonos Roam Speaker Module Replacement: passo 2, imagem 2 %32
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
    Pergunte ao FixBot
    Comentar
  3. Sonos Roam Speaker Module Replacement, Speaker Grille: passo 3, imagem 1 %32 Sonos Roam Speaker Module Replacement, Speaker Grille: passo 3, imagem 2 %32
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
    Pergunte ao FixBot
    Comentar
  4. Sonos Roam Speaker Module Replacement: passo 4, imagem 1 %32 Sonos Roam Speaker Module Replacement: passo 4, imagem 2 %32
    • Flip the device.
    Pergunte ao FixBot
    Comentar
  5. Sonos Roam Speaker Module Replacement: passo 5, imagem 1 %32 Sonos Roam Speaker Module Replacement: passo 5, imagem 2 %32 Sonos Roam Speaker Module Replacement: passo 5, imagem 3 %32
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
    Pergunte ao FixBot
    Comentar
  6. Sonos Roam Speaker Module Replacement, Speaker Module: passo 6, imagem 1 %32 Sonos Roam Speaker Module Replacement, Speaker Module: passo 6, imagem 2 %32
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
    Pergunte ao FixBot
    Comentar
  7. Sonos Roam Speaker Module Replacement: passo 7, imagem 1 %32 Sonos Roam Speaker Module Replacement: passo 7, imagem 2 %32 Sonos Roam Speaker Module Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Lauren Young
Membro desde: 09/20/23
884 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 1,813
