Ir para o conteúdo principal
Samsung Watch Active Screen Replacement
O que você precisa
    1. Samsung Watch Active Screen Replacement, Turn off the watch: passo 1, imagem 1 %32 Samsung Watch Active Screen Replacement, Turn off the watch: passo 1, imagem 2 %32
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Pergunte ao FixBot
      Comentar
    2. Samsung Watch Active Screen Replacement, Remove the rear screws: passo 2, imagem 1 %32
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Pergunte ao FixBot
      Comentar
    3. Samsung Watch Active Screen Replacement, Separate the back cover from the housing: passo 3, imagem 1 %32 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: passo 3, imagem 2 %32 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: passo 3, imagem 3 %32
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Samsung Watch Active Screen Replacement, Disconnect the sensor array: passo 4, imagem 1 %32 Samsung Watch Active Screen Replacement, Disconnect the sensor array: passo 4, imagem 2 %32
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Pergunte ao FixBot
      Comentar
    5. Samsung Watch Active Screen Replacement, Remove the back cover: passo 5, imagem 1 %32
      • Remove the back cover.
      Pergunte ao FixBot
      Comentar
    1. Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: passo 6, imagem 1 %32 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: passo 6, imagem 2 %32 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: passo 6, imagem 3 %32
      • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
      Pergunte ao FixBot
      Comentar
    2. Samsung Watch Active Screen Replacement, Undo the mic tape: passo 7, imagem 1 %32 Samsung Watch Active Screen Replacement, Undo the mic tape: passo 7, imagem 2 %32 Samsung Watch Active Screen Replacement, Undo the mic tape: passo 7, imagem 3 %32
      • Use an opening pick to peel back the thin tape belonging to the microphone array.
      • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
      Pergunte ao FixBot
      Comentar
    3. Samsung Watch Active Screen Replacement, Lift the core assembly: passo 8, imagem 1 %32 Samsung Watch Active Screen Replacement, Lift the core assembly: passo 8, imagem 2 %32
      • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
      Pergunte ao FixBot
      Comentar
    4. Samsung Watch Active Screen Replacement, Remove the core assembly: passo 9, imagem 1 %32 Samsung Watch Active Screen Replacement, Remove the core assembly: passo 9, imagem 2 %32 Samsung Watch Active Screen Replacement, Remove the core assembly: passo 9, imagem 3 %32
      • Lift out and remove the core assembly.
      Pergunte ao FixBot
      Comentar
    1. Samsung Watch Active Screen Replacement, Loosen the mic: passo 10, imagem 1 %32 Samsung Watch Active Screen Replacement, Loosen the mic: passo 10, imagem 2 %32
      • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
      Pergunte ao FixBot
      Comentar
    2. Samsung Watch Active Screen Replacement, Free the barometric sensor: passo 11, imagem 1 %32 Samsung Watch Active Screen Replacement, Free the barometric sensor: passo 11, imagem 2 %32
      • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
      Pergunte ao FixBot
      Comentar
    3. Samsung Watch Active Screen Replacement, Remove the mic array: passo 12, imagem 1 %32
      • Carefully remove the microphone and barometric sensor array from the frame.
      Pergunte ao FixBot
      Comentar
    1. Samsung Watch Active Screen Replacement, Loosen the screen adhesive: passo 13, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    2. Samsung Watch Active Screen Replacement, Separate the screen and frame: passo 14, imagem 1 %32 Samsung Watch Active Screen Replacement, Separate the screen and frame: passo 14, imagem 2 %32 Samsung Watch Active Screen Replacement, Separate the screen and frame: passo 14, imagem 3 %32
      • Insert the opening tool under the frame where the sensor array was located.
      • Pry upwards to separate the screen from the frame.
      Pergunte ao FixBot
      Comentar
    3. Samsung Watch Active Screen Replacement, Remove the screen: passo 15, imagem 1 %32 Samsung Watch Active Screen Replacement, Remove the screen: passo 15, imagem 2 %32 Samsung Watch Active Screen Replacement, Remove the screen: passo 15, imagem 3 %32
      • Use your fingers to pull the frame off the remaining screen adhesive.
      • Clean any remaining adhesive from the frame using isopropyl alcohol (>90%) before installing the new screen.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
134.498 Reputação
Autoria de 189 guias
Equipe
3Comentários do guia
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Rosalie E. Morgan - Responder Compartilhar
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
Colm O'Sullivan - Responder Compartilhar
How do I put the mic array back in?
Mason Thomas - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 146
Ao todo: 6,653
