Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Is your battery running out way too fast? Are you forced to recharge your S7 more than once a day? This guide will show you how to remove the tired old battery in your S7 and replace it with a new one.
Note that the video guide recommends removing the SIM card. This is not necessary, but won't negatively affect repair if you do remove it.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
If your battery is swollen, take appropriate precautions. Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
O que você precisa
Vídeo de Apresentação
Use the flat end of a spudger to disconnect the battery connector.
Prepare an iOpener and apply it directly to the battery.
Apply the iOpener for at least a minute to soften the battery adhesive.
Alternatively, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
To reassemble your device, apply adhesive to the back glass and follow these instructions in reverse order.
After completing this guide, calibrate your newly-installed battery.
254 outras pessoas executaram este guia.
57 comentários
After this is it still waterproof?
In theory, if you applied the replacement adhesive 100% correctly, it will retain its water resistant properties. However, I would never deliberately expose any device to water, as you can never be completely sure that all the seals are perfectly intact.
That is actually covered in the video. Did you actually watch it? If water resistant is important to you then what you would do is purchase new gasket material so that after you have opened up the phone and removed all the existing gasket you would apply the new gasket and then finish up and re-seal your phone. As to how water resistant it is after re-sealing the phone all depends on how careful you are and how exact your work is.
Sooooooooo why exactly did Samsung make it impossible to open the phone?
Because screws are unsightly :P… and repairing your old phone makes you not want to buy a new phone.
