Ir para o conteúdo principal
Samsung Galaxy S22 Battery Replacement
O que você precisa
  1. Samsung Galaxy S22 Battery Replacement, Heat the bottom edge: passo 1, imagem 1 %32
    • Let your phone's battery to drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S22 Battery Replacement, Adhesive information: passo 2, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Adhesive information: passo 2, imagem 2 %32
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S22 Battery Replacement, Insert an opening pick: passo 3, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Insert an opening pick: passo 3, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Apply a suction handle to the back cover, as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S22 Battery Replacement, Slice the bottom adhesive: passo 4, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Slice the bottom adhesive: passo 4, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Slice the bottom adhesive: passo 4, imagem 3 %32
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S22 Battery Replacement, Heat the left edge: passo 5, imagem 1 %32
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  6. Samsung Galaxy S22 Battery Replacement, Slice the left adhesive: passo 6, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Slice the left adhesive: passo 6, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Slice the left adhesive: passo 6, imagem 3 %32
    • Insert a second opening pick at the bottom left corner.
    • Slide the pick to the bottom of the camera bezel to slice the left adhesive.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in to prevent the adhesive from resealing.
  7. Samsung Galaxy S22 Battery Replacement, Heat the right edge: passo 7, imagem 1 %32
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
  8. Samsung Galaxy S22 Battery Replacement, Slice the right adhesive: passo 8, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Slice the right adhesive: passo 8, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Slice the right adhesive: passo 8, imagem 3 %32
    • Insert a third opening pick at the bottom right corner.
    • If the adhesive has resealed, insert the pick closer to the bottom edge.
    • Slide the pick to the top right corner to slice the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  9. Samsung Galaxy S22 Battery Replacement, Heat the top edge: passo 9, imagem 1 %32
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  10. Samsung Galaxy S22 Battery Replacement, Slice the remaining adhesive: passo 10, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Slice the remaining adhesive: passo 10, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Slice the remaining adhesive: passo 10, imagem 3 %32
    • Insert an opening pick in the gap at the top right edge.
    • Slide the pick across the top edge and around the top left corner to slice the remaining adhesive.
    • Only insert the pick up to 4 mm, as you may damage the rear cameras or flash.
  11. Samsung Galaxy S22 Battery Replacement, Remove the back cover: passo 11, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Remove the back cover: passo 11, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Remove the back cover: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • To apply new adhesive, follow this guide.
  12. Samsung Galaxy S22 Battery Replacement, Disconnect the wireless charging coil: passo 12, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the wireless charging coil: passo 12, imagem 2 %32
    • Use the pointed end of a spudger to pry and disconnect the wireless charging coil from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  13. Samsung Galaxy S22 Battery Replacement, Unfasten the wireless charging coil: passo 13, imagem 1 %32
    • Use your Phillips screwdriver to remove the six 3.5 mm-long screws securing the wireless charging coil.
  14. Samsung Galaxy S22 Battery Replacement, Unfasten the loudspeaker: passo 14, imagem 1 %32
    • Use your Phillips screwdriver to remove the seven 3.5 mm screws securing the loudspeaker.
  15. Samsung Galaxy S22 Battery Replacement, Unclip the loudspeaker: passo 15, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Unclip the loudspeaker: passo 15, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Unclip the loudspeaker: passo 15, imagem 3 %32
    • Insert the pointed end of your spudger between the upper left corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to engage the clips.
  16. Samsung Galaxy S22 Battery Replacement, Remove the charging coil and loudspeaker assembly: passo 16, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Remove the charging coil and loudspeaker assembly: passo 16, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Remove the charging coil and loudspeaker assembly: passo 16, imagem 3 %32
    • Grab and remove the wireless charging coil and loudspeaker from the frame.
    • Do not separate the charging coil from the loudspeaker.
  17. Samsung Galaxy S22 Battery Replacement, Disconnect the battery: passo 17, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the battery: passo 17, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  18. Samsung Galaxy S22 Battery Replacement, Disconnect the interconnect cables: passo 18, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the interconnect cables: passo 18, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the interconnect cables: passo 18, imagem 3 %32
    • Use the pointed end of your spudger to pry up and disconnect both interconnect cables from the motherboard.
  19. Samsung Galaxy S22 Battery Replacement: passo 19, imagem 1 %32 Samsung Galaxy S22 Battery Replacement: passo 19, imagem 2 %32 Samsung Galaxy S22 Battery Replacement: passo 19, imagem 3 %32
    • Use the pointed end of your spudger to pry up and disconnect both interconnect cables from the charging board.
  20. Samsung Galaxy S22 Battery Replacement, Remove the interconnect cables: passo 20, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Remove the interconnect cables: passo 20, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Remove the interconnect cables: passo 20, imagem 3 %32
    • Grab and remove the two interconnect cables from the frame.
    • During reassembly, orient the cables so the "main" ends are toward the top of the phone and the "sub" ends are toward the bottom.
  21. Samsung Galaxy S22 Battery Replacement, Disconnect the power and volume buttons: passo 21, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the power and volume buttons: passo 21, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect the power and volume button press connector.
  22. Samsung Galaxy S22 Battery Replacement, Disconnect the left 5G mmWave antenna: passo 22, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the left 5G mmWave antenna: passo 22, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
    • During reassembly, make sure this cable and the power and volume button cable are under the battery cable.
  23. Samsung Galaxy S22 Battery Replacement, Unfasten the antenna: passo 23, imagem 1 %32
    • Use your Phillips screwdriver to remove the two 3.5 mm‑long screws securing the left 5G mmWave antenna.
  24. Samsung Galaxy S22 Battery Replacement, Remove the antenna: passo 24, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Remove the antenna: passo 24, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Remove the antenna: passo 24, imagem 3 %32
    • Insert the pointed end of your spudger between the lower screw mount of the antenna bracket and the frame.
    • Pry up on the bracket until you can grab it with blunt nose tweezers or your fingers.
    • Remove the left 5G mmWave antenna.
  25. Samsung Galaxy S22 Battery Replacement, Disconnect the screen cable: passo 25, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Disconnect the screen cable: passo 25, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect the screen press connector from the motherboard.
  26. Samsung Galaxy S22 Battery Replacement: passo 26, imagem 1 %32 Samsung Galaxy S22 Battery Replacement: passo 26, imagem 2 %32
    • Use the pointed end of your spudger to pry up and disconnect the screen press connector from the bottom left corner of the phone.
  27. Samsung Galaxy S22 Battery Replacement, Remove the screen cable: passo 27, imagem 1 %32
    • Remove the screen cable.
  28. Samsung Galaxy S22 Battery Replacement, Apply isopropyl alcohol: passo 28, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Apply isopropyl alcohol: passo 28, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Apply isopropyl alcohol: passo 28, imagem 3 %32
    • Strong adhesive secures the battery to the frame.
    • Use a pipette or syringe to apply 1-2 drops of high-concentration isopropyl alcohol (greater than 90%) between the right edge of the battery and frame.
    • Using too much alcohol can damage the display.
    • Elevate the right edge of the phone for one minute to allow the isopropyl alcohol to flow under the battery and soften the adhesive.
  29. Samsung Galaxy S22 Battery Replacement, Separate the battery adhesive: passo 29, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Separate the battery adhesive: passo 29, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Separate the battery adhesive: passo 29, imagem 3 %32
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
    • Apply a suction cup to the battery, as close to the center of the right edge as possible.
    • Insert the tip of an opening pick between the right edge of the battery and frame.
    • Push the opening pick down and rotate it so the long end is between the battery and frame.
  30. Samsung Galaxy S22 Battery Replacement: passo 30, imagem 1 %32 Samsung Galaxy S22 Battery Replacement: passo 30, imagem 2 %32 Samsung Galaxy S22 Battery Replacement: passo 30, imagem 3 %32
    • Take care not to crease or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Pull up on the suction cup with strong, steady force while prying the battery up with the opening pick.
    • Maintain constant pressure on the pick and suction cup until the battery separates from the frame.
    • Be patient and allow time for the adhesive to separate. If the battery doesn't budge, apply a few more drops of isopropyl alcohol and try again.
  31. Samsung Galaxy S22 Battery Replacement, Remove the battery: passo 31, imagem 1 %32 Samsung Galaxy S22 Battery Replacement, Remove the battery: passo 31, imagem 2 %32 Samsung Galaxy S22 Battery Replacement, Remove the battery: passo 31, imagem 3 %32
    • Remove the battery.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
    • Follow this guide to install your new battery.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
10 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
94.530 Reputação
Autoria de 662 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.415 guias
7 comentários
Very good article, but could not print out which would have been useful.
Dennis Stenstrom - Responder
Hi Dennis! At the top of the page next to the Edit button there is a down arrow (⌄). If you click it, you should see an option that says Download as PDF. This should give you a version that's printable.
Spencer Day -
If one were to open the back panel using a hot air station, how much temperature for how long will do the job without damaging the phone?
Eligio Budde - Responder
The guide was very useful, the only problem was opening the phone. It took me two days, but it's just a matter of applying plenty of heat around the edges without exceeding 2 minutes. Once you open one side, the rest is easy. Now, removing the battery can be very challenging. It was very stressful. Apply isopropyl alcohol both to the sides and underneath, but you have to move the battery aside so that it can reach underneath it. I couldn't remove the battery with those plastic things from the iOpener, luckily I had a thin metal tool that I bought from AliExpress a long time ago in a kit, and that helped me a lot. It looks like the thing JerryRig uses (or used to use) when he does a teardown. I just inserted it on the sides and started prying. Even though it bent, I could hear the glue coming off, so I took advantage and added more 99% isopropyl alcohol until it finally came out. The rest is just putting in the new battery and reconnecting everything.
Norman Garcia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 114
Últimos 7 dias: 816
Últimos 30 dias: 3,176
Duração total: 45,490
