Ir para o conteúdo principal
Samsung Galaxy Note20 Ultra USB-C Port Replacement
O que você precisa
  1. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Heat the rear cover: passo 1, imagem 1 %32
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Insert an opening pick: passo 2, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Insert an opening pick: passo 2, imagem 2 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Begin to cut the adhesive: passo 3, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Begin to cut the adhesive: passo 3, imagem 2 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Begin to cut the adhesive: passo 3, imagem 3 %32
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Cut along the perimeter of the rear cover: passo 4, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Cut along the perimeter of the rear cover: passo 4, imagem 2 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Cut along the perimeter of the rear cover: passo 4, imagem 3 %32
    • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the rear cover: passo 5, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the rear cover: passo 5, imagem 2 %32
    • Lift the rear cover straight up to remove it.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the wireless charging coil: passo 6, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the wireless charging coil: passo 6, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the white press connector: passo 7, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the white press connector: passo 7, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the motherboard shield screws: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the wireless charging coil: passo 9, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the wireless charging coil: passo 9, imagem 2 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the wireless charging coil: passo 9, imagem 3 %32
    • Use a pair of tweezers to lift up the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
    • Use your fingers to grip the motherboard shield.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 10, imagem 2 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 10, imagem 3 %32
    • Peel the wireless charging coil up and away from the device to remove it.
    • The wireless charging coil is secured to the device with light adhesive.
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the battery: passo 11, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the battery: passo 11, imagem 2 %32
    • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
    Pergunte ao FixBot
    Comentar
  12. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the loudspeaker screws: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 4.0 mm screws securing the loudspeaker to the frame.
    Pergunte ao FixBot
    Comentar
  13. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the loudspeaker: passo 13, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the loudspeaker: passo 13, imagem 2 %32
    • Insert the pointed end of a spudger into the hole marked by a triangle on the left side of the loudspeaker.
    • Use the spudger to pry up and loosen the left side of the loudspeaker.
    Pergunte ao FixBot
    Comentar
  14. Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 14, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 14, imagem 2 %32
    • Insert the pointed end of a spudger into the hole marked by a triangle on the right side of the loudspeaker.
    • Use the spudger to pry up and detach the loudspeaker from the frame.
    • The loudspeaker is secured to the frame by clips along its bottom edge.
    Pergunte ao FixBot
    Comentar
  15. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the loudspeaker: passo 15, imagem 1 %32
    • Use a pair of tweezers to lift and remove the loudspeaker.
    Pergunte ao FixBot
    Comentar
  16. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the interconnect cables from the daughterboard: passo 16, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the interconnect cables from the daughterboard: passo 16, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
    Pergunte ao FixBot
    Comentar
  17. Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 17, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement: passo 17, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    Pergunte ao FixBot
    Comentar
  18. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the daughterboard screw: passo 18, imagem 1 %32
    • Use a Phillips screwdriver to remove the 3.0 mm screw securing the daughterboard to the frame.
    Pergunte ao FixBot
    Comentar
  19. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the daughterboard: passo 19, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the daughterboard: passo 19, imagem 2 %32
    • The daughterboard is fitted to the frame by three spring connectors along its bottom edge.
    • Insert the pointed end of a spudger under the right side of the daughterboard near the screw boss.
    • Use the spudger to pry up and detach the daughterboard from the frame.
    • There are small surface-mounted components underneath the daughterboard. Only insert the spudger as far as necessary to avoid damaging the components.
    Pergunte ao FixBot
    Comentar
  20. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the daughterboard: passo 20, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the daughterboard: passo 20, imagem 2 %32
    • Use a pair of tweezers to lift and remove the daughterboard.
    Pergunte ao FixBot
    Comentar
  21. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the main interconnect cable from the motherboard: passo 21, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Disconnect the main interconnect cable from the motherboard: passo 21, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  22. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Unscrew the USB-C port: passo 22, imagem 1 %32
    • Use a Phillips screwdriver to remove the two 3.0 mm screws securing the USB-C port to the phone.
    Pergunte ao FixBot
    Comentar
  23. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the USB-C port: passo 23, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Loosen the USB-C port: passo 23, imagem 2 %32
    • Insert the pointed end of a spudger under the left side screw hole on the USB-C port.
    • Pry up the USB-C port to loosen it from the frame.
    • The USB-C port may fling out of its slot while it is being pried.
    • Avoid scratching the USB-C port's copper pad with your pry tool.
    • The USB-C port is held in place by a red rubber gasket. Prying up with a steady force will gradually loosen the USB-C port from its slot.
    Pergunte ao FixBot
    Comentar
  24. Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the USB-C port: passo 24, imagem 1 %32 Samsung Galaxy Note20 Ultra USB-C Port Replacement, Remove the USB-C port: passo 24, imagem 2 %32
    • Grip the USB-C ribbon cable with your fingers close to the USB-C port.
    • Remove the USB-C port by pulling it up and away from the bottom of the phone.
    • Avoid bending the ribbon cable more than necessary to prevent damage.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
13 outras pessoas executaram este guia.
Kyle Smith
Membro desde: 02/01/21
52.502 Reputação
Autoria de 124 guias
3Comentários do guia
I would like to also add to this tutorial for the last step after you remove the USB-C Charging port and once you reinstall the port, rather its a new one or the same stock oem port that you took out. You should be extremely cautious to how tight you tighten these screws as the LED Touch Display actually lays flat against the frame and if you over tighten these screws that hold this port down, you will figure out quite easily that 1. the screens are very fragile and 2. these screws are able to be tightened and will not stop causing unwanted pressure onto the screen and will destroy the screen which will make it useless as the phone will work just without a display or touch interactions with the phone until buying a new display to replace it.
Jay - Responder Compartilhar
Big rule of thumb for smartphones, tighten only until it feels snug, don't crank things as tightly as they can go. This was also a problem for iPhone repair, some were cranking as tight as possible and killing their screens. The screws have loctite, they're not going anywhere.
Zack is Back - Responder Compartilhar
This is an excellent article! Many Thanks For Sharing
GBENGA JOSHUA BOLARINWA - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 50
Últimos 30 dias: 242
Ao todo: 23,488
