Ir para o conteúdo principal
Samsung Galaxy Note20 Rear Camera Module Replacement
O que você precisa
  1. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the SIM card tray: passo 1, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the SIM card tray: passo 1, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the SIM card tray: passo 1, imagem 3 %32
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the top edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Note20 Rear Camera Module Replacement, Heat the rear cover: passo 2, imagem 1 %32
    • Completely power off your phone before you begin disassembly.
    • Heat an iOpener and apply it to the left side of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen, internal battery, and the plastic rear cover are susceptible to heat damage.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Note20 Rear Camera Module Replacement, Insert an opening pick: passo 3, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Insert an opening pick: passo 3, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy Note20 Rear Camera Module Replacement, Begin to cut the adhesive: passo 4, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Begin to cut the adhesive: passo 4, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Begin to cut the adhesive: passo 4, imagem 3 %32
    • As you cut through the adhesive around the perimeter of the phone, don't insert the pick more than 5 mm to avoid damaging internal components.
    • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy Note20 Rear Camera Module Replacement, Cut along the perimeter of the rear cover: passo 5, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Cut along the perimeter of the rear cover: passo 5, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Cut along the perimeter of the rear cover: passo 5, imagem 3 %32
    • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
    • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
    • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
    • If the rear cover is still attached to the frame after cutting through all four sides, try slicing through the adhesive again with an opening pick.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the rear cover: passo 6, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the rear cover: passo 6, imagem 2 %32
    • Lift the rear cover straight up to remove it.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the motherboard shield: passo 7, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
    • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 8, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 8, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 8, imagem 3 %32
    • Use a pair of tweezers to lift up and flip back the motherboard shield.
    • Be careful when handling the motherboard shield because its edges are thin and sharp.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the battery: passo 9, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the battery: passo 9, imagem 2 %32
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the wireless charging coil: passo 10, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the wireless charging coil: passo 10, imagem 2 %32
    • While using a pair of tweezers to hold the motherboard shield out of the way, use the pointed end of a spudger to pry up the wireless charging coil press connector.
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the wireless charging coil: passo 11, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the wireless charging coil: passo 11, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the wireless charging coil: passo 11, imagem 3 %32
    • Grip the motherboard shield with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the device with light adhesive.
    • Remove the wireless charging coil.
    Pergunte ao FixBot
    Comentar
  12. Samsung Galaxy Note20 Rear Camera Module Replacement, Unscrew the loudspeaker: passo 12, imagem 1 %32
    • Use a Phillips screwdriver to unscrew the five 4.0 mm screws securing the loudspeaker to the frame.
    Pergunte ao FixBot
    Comentar
  13. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the loudspeaker: passo 13, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the loudspeaker: passo 13, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the loudspeaker: passo 13, imagem 3 %32
    • Insert the pointed end of a spudger underneath the loudspeaker near its top left screw hole.
    • Use the spudger to pry up and detach the loudspeaker from the frame.
    • Use a pair of tweezers to lift and remove the loudspeaker.
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    Pergunte ao FixBot
    Comentar
  14. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the earpiece speaker screws: passo 14, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 4.0 mm screws securing the earpiece speaker to the frame.
    Pergunte ao FixBot
    Comentar
  15. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the earpiece speaker: passo 15, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the earpiece speaker: passo 15, imagem 2 %32
    • Insert the flat end of a spudger underneath the bottom edge of the earpiece speaker.
    • Pry up the earpiece speaker to loosen it from the frame.
    • The earpiece speaker clips to the frame along the top edge.
    Pergunte ao FixBot
    Comentar
  16. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 16, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 16, imagem 2 %32
    • Lift and remove the earpiece speaker.
    Pergunte ao FixBot
    Comentar
  17. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the front-facing camera: passo 17, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the front-facing camera: passo 17, imagem 2 %32
    • Use the pointed end of a spudger to pry up the front-facing camera press connector.
    • Because the front-facing camera is only attached to the motherboard by the press connector, it may fling out when you pry up the connector.
    Pergunte ao FixBot
    Comentar
  18. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the front-facing camera: passo 18, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the front-facing camera: passo 18, imagem 2 %32
    • Use a pair of tweezers to remove the front-facing camera.
    Pergunte ao FixBot
    Comentar
  19. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the daughterboard interconnect cables: passo 19, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the daughterboard interconnect cables: passo 19, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the daughterboard.
    Pergunte ao FixBot
    Comentar
  20. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 20, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    Pergunte ao FixBot
    Comentar
  21. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the display cable: passo 21, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the display cable: passo 21, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  22. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the motherboard interconnect cables: passo 22, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the motherboard interconnect cables: passo 22, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  23. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 23, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 23, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the secondary interconnect cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  24. Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the remaining motherboard connectors: passo 24, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Disconnect the remaining motherboard connectors: passo 24, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the S-Pen press connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  25. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 25, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 25, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the green press connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  26. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 26, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 26, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the touch layer press connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  27. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the motherboard: passo 27, imagem 1 %32
    • Use a Phillips screwdriver to remove the 4.0 mm screw securing the motherboard to the frame.
    Pergunte ao FixBot
    Comentar
  28. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 28, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 28, imagem 2 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 28, imagem 3 %32
    • Insert the pointed end of a spudger under the bottom left corner of the motherboard.
    • Pry straight up to loosen the motherboard from the frame.
    • Lift the motherboard out of the phone.
    Pergunte ao FixBot
    Comentar
  29. Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the rear camera module: passo 29, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement, Remove the rear camera module: passo 29, imagem 2 %32
    • Turn the motherboard over so that the rear camera module's press connectors are facing upward.
    • Use the pointed end of a spudger to pry up the upper camera's press connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  30. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 30, imagem 1 %32
    • Use a pair of tweezers to lift and remove the upper camera from the motherboard.
    Pergunte ao FixBot
    Comentar
  31. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 31, imagem 1 %32 Samsung Galaxy Note20 Rear Camera Module Replacement: passo 31, imagem 2 %32
    • Use the pointed end of a spudger to pry up the lower cameras' press connector from the motherboard.
    Pergunte ao FixBot
    Comentar
  32. Samsung Galaxy Note20 Rear Camera Module Replacement: passo 32, imagem 1 %32
    • Lift and remove the lower cameras from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Answers community for help.
Uma outra pessoa concluiu este guia.
Kyle Smith
Membro desde: 02/01/21
52.475 Reputação
Autoria de 124 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 77
Ao todo: 2,412
