Ir para o conteúdo principal
Petcube Play 2 Microphone Replacement
O que você precisa
  1. Petcube Play 2 Microphone Replacement, Motherboard: passo 1, imagem 1 %32 Petcube Play 2 Microphone Replacement, Motherboard: passo 1, imagem 2 %32 Petcube Play 2 Microphone Replacement, Motherboard: passo 1, imagem 3 %32
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
    Pergunte ao FixBot
    Comentar
  2. Petcube Play 2 Microphone Replacement: passo 2, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 2, imagem 2 %32
    • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
    • The glue may cause slight resistance, but the screws should come out with minimal effort.
    Pergunte ao FixBot
    Comentar
  3. Petcube Play 2 Microphone Replacement: passo 3, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 3, imagem 2 %32
    • Carefully pry off the glass front panel using an opening pick or a spudger.
    • Do not force the front panel off, as it may crack and break.
    Pergunte ao FixBot
    Comentar
  4. Petcube Play 2 Microphone Replacement: passo 4, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 4, imagem 2 %32 Petcube Play 2 Microphone Replacement: passo 4, imagem 3 %32
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum casing.
    Pergunte ao FixBot
    Comentar
  5. Petcube Play 2 Microphone Replacement: passo 5, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 5, imagem 2 %32 Petcube Play 2 Microphone Replacement: passo 5, imagem 3 %32
    • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
    • Remove the screw with a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Petcube Play 2 Microphone Replacement: passo 6, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 6, imagem 2 %32 Petcube Play 2 Microphone Replacement: passo 6, imagem 3 %32
    • Flip the cube onto its side to locate the pull tabs.
    • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
    Pergunte ao FixBot
    Comentar
  7. Petcube Play 2 Microphone Replacement: passo 7, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 7, imagem 2 %32 Petcube Play 2 Microphone Replacement: passo 7, imagem 3 %32
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Avoid pulling on the wires to prevent damage to the connectors.
    Pergunte ao FixBot
    Comentar
  8. Petcube Play 2 Microphone Replacement: passo 8, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 8, imagem 2 %32 Petcube Play 2 Microphone Replacement: passo 8, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
    • Be gentle with the tabs. They will break under too much pressure.
    Pergunte ao FixBot
    Comentar
  9. Petcube Play 2 Microphone Replacement, Microphone: passo 9, imagem 1 %32 Petcube Play 2 Microphone Replacement, Microphone: passo 9, imagem 2 %32 Petcube Play 2 Microphone Replacement, Microphone: passo 9, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the screws from the plates behind the motherboard, separating the two plates.
    Pergunte ao FixBot
    Comentar
  10. Petcube Play 2 Microphone Replacement: passo 10, imagem 1 %32 Petcube Play 2 Microphone Replacement: passo 10, imagem 2 %32
    • Detach the PCB with the microphones from the plastic.
    • Using a soldering iron, desolder the microphones from the PCB.
    • Be careful! The soldering iron becomes hot! Avoid touching the device for too long, as this may damage the components.
    • To Avoid burning yourself or damaging the device, follow the IFixit soldering instructions
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Jacob Branco
Membro desde: 03/18/24
291 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 354
