Ir para o conteúdo principal
Parrot Skycontroller 2 Buttons Replacement
O que você precisa
    1. Parrot Skycontroller 2 Buttons Replacement, Battery: passo 1, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement, Battery: passo 1, imagem 2 %32 Parrot Skycontroller 2 Buttons Replacement, Battery: passo 1, imagem 3 %32
      • Flip your controller face down.
      Pergunte ao FixBot
      Comentar
    2. Parrot Skycontroller 2 Buttons Replacement: passo 2, imagem 1 %32
      • Remove one 9mm screw using a #4 flathead screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Parrot Skycontroller 2 Buttons Replacement: passo 3, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement: passo 3, imagem 2 %32 Parrot Skycontroller 2 Buttons Replacement: passo 3, imagem 3 %32
      • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
      • Remove the cover by pulling up and out.
      Pergunte ao FixBot
      Comentar
    4. Parrot Skycontroller 2 Buttons Replacement: passo 4, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement: passo 4, imagem 2 %32 Parrot Skycontroller 2 Buttons Replacement: passo 4, imagem 3 %32
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
      Pergunte ao FixBot
      Comentar
    5. Parrot Skycontroller 2 Buttons Replacement: passo 5, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement: passo 5, imagem 2 %32
      • Remove the battery from its brackets by pulling up on the ends of the battery.
      Pergunte ao FixBot
      Comentar
    1. Parrot Skycontroller 2 Buttons Replacement, Buttons: passo 6, imagem 1 %32
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Parrot Skycontroller 2 Buttons Replacement: passo 7, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement: passo 7, imagem 2 %32 Parrot Skycontroller 2 Buttons Replacement: passo 7, imagem 3 %32
      • Remove the seven silver 4mm screws from around the edge of the top plate using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      Pergunte ao FixBot
      Comentar
    3. Parrot Skycontroller 2 Buttons Replacement: passo 8, imagem 1 %32
      • Remove the battery compartment plate by pulling up and out.
      Pergunte ao FixBot
      Comentar
    4. Parrot Skycontroller 2 Buttons Replacement: passo 9, imagem 1 %32
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      Pergunte ao FixBot
      Comentar
    5. Parrot Skycontroller 2 Buttons Replacement: passo 10, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement: passo 10, imagem 2 %32
      • Remove the face plate by pulling up and out.
      • Buttons will fall out when this plate is removed.
      Pergunte ao FixBot
      Comentar
    6. Parrot Skycontroller 2 Buttons Replacement: passo 11, imagem 1 %32 Parrot Skycontroller 2 Buttons Replacement: passo 11, imagem 2 %32 Parrot Skycontroller 2 Buttons Replacement: passo 11, imagem 3 %32
      • Use some force pull up and out on the rubber backing for the buttons.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 27
Ao todo: 660
