Ir para o conteúdo principal
Opening Procedure
O que você precisa
  1. Opening Procedure, Power down the watch: passo 1, imagem 1 %32 Opening Procedure, Power down the watch: passo 1, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  2. Opening Procedure, Safety Requirements: passo 2, imagem 1 %32 Opening Procedure, Safety Requirements: passo 2, imagem 2 %32 Opening Procedure, Safety Requirements: passo 2, imagem 3 %32
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
    Pergunte ao FixBot
    Comentar
  3. Opening Procedure, Soften the display adhesive: passo 3, imagem 1 %32
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
    • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
    Pergunte ao FixBot
    Comentar
  4. Opening Procedure, Display opening: passo 4, imagem 1 %32 Opening Procedure, Display opening: passo 4, imagem 2 %32 Opening Procedure, Display opening: passo 4, imagem 3 %32
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    Pergunte ao FixBot
    Comentar
  5. Opening Procedure: passo 5, imagem 1 %32 Opening Procedure: passo 5, imagem 2 %32 Opening Procedure: passo 5, imagem 3 %32
    • Insert an opening pick in the gap your created.
    • Slide the opening pick along the short edge of the watch to cut the adhesive.
    Pergunte ao FixBot
    Comentar
  6. Opening Procedure: passo 6, imagem 1 %32 Opening Procedure: passo 6, imagem 2 %32
    • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to cut the display adhesive.
    Pergunte ao FixBot
    Comentar
  7. Opening Procedure: passo 7, imagem 1 %32 Opening Procedure: passo 7, imagem 2 %32
    • Slide the opening pick around the corner to cut the remaining adhesive on the short edge of the watch next to the watch crown.
    Pergunte ao FixBot
    Comentar
  8. Opening Procedure: passo 8, imagem 1 %32 Opening Procedure: passo 8, imagem 2 %32
    • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
    • Try not to slice near the watch crown to prevent damaging the display cables. If you must slice near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
    • Slide an opening pick under the opposite display edge of the watch crown.
    • Twist the opening pick to loosen the display off the watch case.
    • Don't try to remove the display. It is still connected to the watch assembly.
    Pergunte ao FixBot
    Comentar
  9. Opening Procedure: passo 9, imagem 1 %32 Opening Procedure: passo 9, imagem 2 %32 Opening Procedure: passo 9, imagem 3 %32
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it towards the watch crown.
    • Swing the display open to an upward position.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your Apple Watch Series 6, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
5 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
260.167 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 26.591 guias
2Comentários do guia
Where are the instructions for installing the new adhesive? Also, it's not listed in the tools/parts list.
Joseph Wisniewski - Responder Compartilhar
Here's the guide for resealing the watch
How to Reseal an Apple Watch
TurianSniper - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 33
Últimos 30 dias: 154
Ao todo: 7,853
