Introdução
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
O que você precisa
Camera module, ambient light sensors, proximity senor, and front microphone
Display cables
Screen magnets
LCD edges
Apply a heated iOpener to the right edge of the screen for two minutes.
Ferramenta utilizada neste passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backward to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the right edge of the display, about 5 cm from the bottom edge.
Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Insert a new opening pick in the gap you just created.
Slide the pick along the right edge to separate the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner below the existing pick.
Slide the pick around the bottom right corner to separate the adhesive.
Apply a heated iOpener to the left edge of the screen for two minutes.
The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
There are flat sections of the frame which require an opening pick to be inserted horizontally.
Insert an opening pick at a 45˚ angle just above the bottom left corner.
Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
Separate the remaining adhesive, making sure to follow the instructions exactly as written.
Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
Slide the pick horizontally and don't insert the pick more than 5 mm.
Grab two opposing corners of the screen and gently separate the rest of the adhesive.
Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
Ferramenta utilizada neste passo:FixMat$36.95
Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
One 1.3 mm screw
One 2.0 mm screw
Ferramenta utilizada neste passo:Tweezers$4.99
Use a pair of tweezers or your fingers to remove the bracket.
Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
Grip the right edge of the screen and fold it open like a book.
Lay the screen down over the left edge of the iPad.
Uma outra pessoa concluiu este guia.
