Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Nintendo Switch Shield Plate Replacement
O que você precisa
  1. Nintendo Switch Shield Plate Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 1 %32 Nintendo Switch Shield Plate Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 2 %32 Nintendo Switch Shield Plate Replacement, Release the Joy Con controller locking tabs: passo 1, imagem 3 %32
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Shield Plate Replacement, Remove the Joy Con controllers: passo 2, imagem 1 %32 Nintendo Switch Shield Plate Replacement, Remove the Joy Con controllers: passo 2, imagem 2 %32 Nintendo Switch Shield Plate Replacement, Remove the Joy Con controllers: passo 2, imagem 3 %32
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Shield Plate Replacement, Remove the back-side screws: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Shield Plate Replacement, Remove the top and bottom screws: passo 4, imagem 1 %32 Nintendo Switch Shield Plate Replacement, Remove the top and bottom screws: passo 4, imagem 2 %32
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Shield Plate Replacement: passo 5, imagem 1 %32 Nintendo Switch Shield Plate Replacement: passo 5, imagem 2 %32
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Shield Plate Replacement: passo 6, imagem 1 %32 Nintendo Switch Shield Plate Replacement: passo 6, imagem 2 %32
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Shield Plate Replacement: passo 7, imagem 1 %32
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Shield Plate Replacement: passo 8, imagem 1 %32 Nintendo Switch Shield Plate Replacement: passo 8, imagem 2 %32 Nintendo Switch Shield Plate Replacement: passo 8, imagem 3 %32
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Shield Plate Replacement, Remove the microSD card reader: passo 9, imagem 1 %32
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Shield Plate Replacement: passo 10, imagem 1 %32 Nintendo Switch Shield Plate Replacement: passo 10, imagem 2 %32
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
  11. Nintendo Switch Shield Plate Replacement, Remove the shield plate: passo 11, imagem 1 %32
    • Use a JIS 000 screwdriver to remove the six 3 mm screws securing the shield plate to the device.
  12. Nintendo Switch Shield Plate Replacement: passo 12, imagem 1 %32 Nintendo Switch Shield Plate Replacement: passo 12, imagem 2 %32
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
  13. Nintendo Switch Shield Plate Replacement: passo 13, imagem 1 %32 Nintendo Switch Shield Plate Replacement: passo 13, imagem 2 %32 Nintendo Switch Shield Plate Replacement: passo 13, imagem 3 %32
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate up.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. For best results, whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro during reassembly.
Conclusão
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
21 outras pessoas executaram este guia.
Craig Lloyd
Membro desde: 02/10/16
35.418 Reputação
Autoria de 82 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 270
Duração total: 16,066
