Ir para o conteúdo principal
Nintendo Switch Pro Controller Battery Replacement
O que você precisa
  1. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: passo 1, imagem 1 %32
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
  2. Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: passo 2, imagem 1 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: passo 2, imagem 2 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the handle covers: passo 2, imagem 3 %32
    • Carefully remove the handle covers by pulling them away from the main body.
  3. Nintendo Switch Pro Controller Battery Replacement, Remove the screws: passo 3, imagem 1 %32
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
  4. Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: passo 4, imagem 1 %32 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: passo 4, imagem 2 %32 Nintendo Switch Pro Controller Battery Replacement, Unclip the plastic cover: passo 4, imagem 3 %32
    • Carefully pry away the clear plastic cover using your fingernail.
  5. Nintendo Switch Pro Controller Battery Replacement, Remove the clear plastic cover: passo 5, imagem 1 %32
    • Remove the clear plastic cover.
  6. Nintendo Switch Pro Controller Battery Replacement, Remove the battery: passo 6, imagem 1 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: passo 6, imagem 2 %32 Nintendo Switch Pro Controller Battery Replacement, Remove the battery: passo 6, imagem 3 %32
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
42 outras pessoas executaram este guia.
Daniel Tagalog
Membro desde: 10/10/19
2.036 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S11-G2, Regan Fall 2019 Membro de Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Membros
Autoria de 45 guias
13Comentários do guia
now what after taking the battery out
Seani M - Responder
Install the replacement battery and follow the steps in reverse order…
frzno72 -
easy peasy only have to recycle battery
Dan Carroll - Responder
Where can I buy genuine ctr-003 batteries in germany/europe?
smol_tsukiko - Responder
You can buy them directly in the iFixit Europe or in your case in the Germany store.
Henrynaja -
Comentar
Visualizações:
Últimas 24 horas: 46
Últimos 7 dias: 244
Últimos 30 dias: 1,180
Ao todo: 90,065
