Introdução
Follow this guide to replace a faulty left speaker in the Nintendo Switch Lite.
The Switch Lite uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
Note: This procedure requires disconnecting the battery for safety. In order to do this, the shield plate must be removed. The shield plate is bonded to the heat sink with thermal paste, which will need to be cleaned off and reapplied before reinstalling the shield plate.
O que você precisa
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
Two 3.6 mm-long screws on the top of the device
Two 3.6 mm-long screws on the bottom of the device
Insert an opening tool into the left speaker grille on the bottom of the device.
Twist the opening tool to release the clips securing the back panel.
Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
Insert an opening tool into the right speaker grille on the bottom of the device.
Twist the opening tool to release the clips.
Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
Lift the bottom edge of the back panel, opening it like a book.
Remove the back panel.
Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
Three 3.1 mm screws
One 4.5 mm screw
Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
Um comentário
Est-ce que les haut parleur des la switch classique et de la lite son pareil et compatible ?
