Ir para o conteúdo principal
Nexus 6 Front Facing Camera Replacement
O que você precisa
  1. Nexus 6 Front Facing Camera Replacement, SIM Card: passo 1, imagem 1 %32
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
    Pergunte ao FixBot
    Comentar
  2. Nexus 6 Front Facing Camera Replacement, Rear Case: passo 2, imagem 1 %32 Nexus 6 Front Facing Camera Replacement, Rear Case: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    iOpener
    $14.95
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
    Pergunte ao FixBot
    Comentar
  3. Nexus 6 Front Facing Camera Replacement: passo 3, imagem 1 %32
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Nexus 6 Front Facing Camera Replacement: passo 4, imagem 1 %32 Nexus 6 Front Facing Camera Replacement: passo 4, imagem 2 %32 Nexus 6 Front Facing Camera Replacement: passo 4, imagem 3 %32
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
    Pergunte ao FixBot
    Comentar
  5. Nexus 6 Front Facing Camera Replacement, Front Facing Camera: passo 5, imagem 1 %32
    • Use a spudger to gently detach the front facing camera connector.
    • Remove the front facing camera using the tweezers.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Marina Moore
Membro desde: 01/13/15
4.302 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 70-3, Forte Winter 2015 Membro de Cal Poly, Team 70-3, Forte Winter 2015
CPSU-FORTE-W15S70G3
4 Membros
Autoria de 39 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 45
Ao todo: 3,041
