Ir para o conteúdo principal
Motorola Moto G 5G (2022) Display Panel Replacement
O que você precisa
  1. Motorola Moto G 5G (2022) Display Panel Replacement, Eject the SIM card tray: passo 1, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Eject the SIM card tray: passo 1, imagem 2 %32
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the SIM card tray: passo 2, imagem 1 %32
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G 5G (2022) Display Panel Replacement, Back cover removal information: passo 3, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Back cover removal information: passo 3, imagem 2 %32
    • Discharge your battery to 25% or less and completely power off your phone before you begin.
    • Take note of the following seams along the edge of the phone:
    • Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
    • Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
  4. Motorola Moto G 5G (2022) Display Panel Replacement, Insert an opening pick: passo 4, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Insert an opening pick: passo 4, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Insert an opening pick: passo 4, imagem 3 %32
    • Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
    • Insert an opening pick in the gap you just created.
  5. Motorola Moto G 5G (2022) Display Panel Replacement, Release the right clips: passo 5, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Release the right clips: passo 5, imagem 2 %32
    • Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
    • As each clip releases, you will hear and feel a pop.
    • Don't slide the opening pick near the power or volume buttons.
  6. Motorola Moto G 5G (2022) Display Panel Replacement, Release the bottom clips: passo 6, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Release the bottom clips: passo 6, imagem 2 %32
    • Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
  7. Motorola Moto G 5G (2022) Display Panel Replacement, Release the left clips: passo 7, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Release the left clips: passo 7, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Release the left clips: passo 7, imagem 3 %32
    • Slide your opening pick toward the top left corner to unclip the left side of the back cover.
  8. Motorola Moto G 5G (2022) Display Panel Replacement, Release the top clips: passo 8, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Release the top clips: passo 8, imagem 2 %32
    • Slide your pick around the top left corner and along the top edge to release the clips.
  9. Motorola Moto G 5G (2022) Display Panel Replacement: passo 9, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement: passo 9, imagem 2 %32
    • Slide your pick around the top right corner to release the last clips securing the back cover.
    • Stop before reaching the volume buttons. Your pick may damage their cables.
  10. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the back cover: passo 10, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the back cover: passo 10, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the back cover: passo 10, imagem 3 %32
    • Don't try to remove the back cover all the way yet, as it's still connected to the frame by the power button cable.
    • With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
    • Rest the cover parallel to the frame.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the power button cable.
  11. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the power button: passo 11, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the power button: passo 11, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • A small rubber arm connects the power button to its recess. Use caution to avoid tearing this piece.
    • Use tweezers or your fingers to unhook the power button's rubber arm from its recess and remove it.
  12. Motorola Moto G 5G (2022) Display Panel Replacement, Only the back cover remains: passo 12, imagem 1 %32
    • You're now left with the back cover.
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
  13. Motorola Moto G 5G (2022) Display Panel Replacement, Unfasten the power button cable bracket: passo 13, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Unfasten the power button cable bracket: passo 13, imagem 2 %32
    • Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
  14. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the power button cable bracket: passo 14, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the power button cable bracket: passo 14, imagem 2 %32
    Comprar
    • Use your fingers or a pair of blunt nose tweezers to grab and remove the bracket from the power button cable.
  15. Motorola Moto G 5G (2022) Display Panel Replacement, Disconnect the power button: passo 15, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Disconnect the power button: passo 15, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
  16. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the power button: passo 16, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the power button: passo 16, imagem 2 %32
    • Grab and remove the power button.
    • If you're using tweezers, take care not to puncture the battery—a punctured battery may leak dangerous chemicals or cause a fire.
  17. Motorola Moto G 5G (2022) Display Panel Replacement, Unfasten the motherboard cover: passo 17, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Unfasten the motherboard cover: passo 17, imagem 2 %32
    • Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
  18. Motorola Moto G 5G (2022) Display Panel Replacement, Pry the motherboard cover: passo 18, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Pry the motherboard cover: passo 18, imagem 2 %32
    • Insert an opening pick between the bottom-left corner of the cover and the motherboard.
    • Pry up to release the cover's small clips securing it to the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • Work your way around the perimeter to free the cover if it feels stuck.
  19. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the motherboard cover: passo 19, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the motherboard cover: passo 19, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the motherboard cover: passo 19, imagem 3 %32
    Comprar
    • Grab and remove the motherboard cover from the phone.
  20. Motorola Moto G 5G (2022) Display Panel Replacement, Disconnect the battery: passo 20, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Disconnect the battery: passo 20, imagem 2 %32
    • Use the pointed end of a spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Motorola Moto G 5G (2022) Display Panel Replacement, Soften the adhesive with heat: passo 21, imagem 1 %32
    • Heat an iOpener and apply it to the left edge of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  22. Motorola Moto G 5G (2022) Display Panel Replacement, Soften the adhesive with isopropyl alcohol: passo 22, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Soften the adhesive with isopropyl alcohol: passo 22, imagem 2 %32
    • Additionally, you may use highly-concentrated isopropyl alcohol (over 90%) to further loosen the adhesive securing the battery.
    • Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
  23. Motorola Moto G 5G (2022) Display Panel Replacement, Pry the battery: passo 23, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Pry the battery: passo 23, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Pry the battery: passo 23, imagem 3 %32
    • Apply a suction cup to the battery, as close to the center of the right edge as possible.
    • Insert an opening pick between the right edge of the battery and the frame.
    • Pull on the suction cup and pry the battery upward.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that is required to free it from the frame.
    • Use two opening picks, side-by-side, if the first pick does not provide enough leverage, like this.
    • Apply more isopropyl alcohol if the battery becomes stuck.
  24. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the battery: passo 24, imagem 1 %32
    • Lift the battery out of its recess and remove it.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Use this guide to install a battery with custom-cut adhesives, or use this guide to install a battery with an adhesive sheet.
  25. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the foam strip: passo 25, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the foam strip: passo 25, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the foam strip: passo 25, imagem 3 %32
    • Peel and remove the foam strip from the bottom of the battery.
    • Apply the foam strip onto your new battery.
  26. Motorola Moto G 5G (2022) Display Panel Replacement, Peel the graphite film: passo 26, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Peel the graphite film: passo 26, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Peel the graphite film: passo 26, imagem 3 %32
    Comprar
    • Use your tweezers to grab and peel the graphite film off the display cable's press connector.
  27. Motorola Moto G 5G (2022) Display Panel Replacement, Disconnect the display: passo 27, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Disconnect the display: passo 27, imagem 2 %32
    • Use the pointed end of your spudger to pry and disconnect the display cable's press connector.
  28. Motorola Moto G 5G (2022) Display Panel Replacement, Soften the display cable's adhesive: passo 28, imagem 1 %32
    • Heat an iOpener and apply it to the display cable for two minutes.
    • The iOpener may stick to the residue left over from the battery. Clean the surrounding surface to prevent this.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  29. Motorola Moto G 5G (2022) Display Panel Replacement, Loosen the display cable: passo 29, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Loosen the display cable: passo 29, imagem 2 %32
    • Grab the display's ribbon cable near the connector.
    • Peel the cable toward the bottom of the phone until it's completely separated from the frame.
  30. Motorola Moto G 5G (2022) Display Panel Replacement, Reinstall the back cover: passo 30, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Reinstall the back cover: passo 30, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Reinstall the back cover: passo 30, imagem 3 %32
    • The remaining steps risk damaging exposed parts, such as the motherboard and cameras. Temporarily installing the back cover protects these parts from damage.
    • Place the back cover over the frame of the phone
    • Press around the perimeter to re-engage the clips securing the cover.
    • During reassembly, refer to steps 4 through 9 to remove the back cover and continue with the reassembly process.
  31. Motorola Moto G 5G (2022) Display Panel Replacement, Heat the top edge: passo 31, imagem 1 %32
    • Heat an iOpener and apply it to the top of the screen for two minutes.
  32. Motorola Moto G 5G (2022) Display Panel Replacement, Insert an opening pick: passo 32, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Insert an opening pick: passo 32, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Insert an opening pick: passo 32, imagem 3 %32
    • Apply a suction cup to the screen, as close to the center of the top edge as possible.
    • Insert an opening pick vertically into the shallow cutout in the top of the glass, as far right as possible.
  33. Motorola Moto G 5G (2022) Display Panel Replacement, Separate the top adhesive: passo 33, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Separate the top adhesive: passo 33, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Separate the top adhesive: passo 33, imagem 3 %32
    • Pull up on the suction cup with a strong, steady force.
    • Angle the opening pick to about 30 degrees, firmly slide it toward the right corner of the display, and separate the adhesive.
    • This step requires significant force. Hold the pick securely to avoid breaking it or slipping it out of the display.
    • Be mindful of the angle of your pick. If it's steeper than 30 degrees, it may slip and separate the bezel from the frame.
    • If you're having trouble separating the adhesive, apply more heat and repeat the process.
  34. Motorola Moto G 5G (2022) Display Panel Replacement, Slice the adhesive: passo 34, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Slice the adhesive: passo 34, imagem 2 %32
    • Don't insert the pick deeper than 2 mm, as you may de-laminate the display panel.
    • Slide the opening pick toward the bottom right corner to separate the right edge's adhesive.
  35. Motorola Moto G 5G (2022) Display Panel Replacement: passo 35, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement: passo 35, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement: passo 35, imagem 3 %32
    • Slide the opening pick toward the bottom left corner to separate the bottom edge's adhesive.
  36. Motorola Moto G 5G (2022) Display Panel Replacement: passo 36, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement: passo 36, imagem 2 %32
    • Slide the pick along the left edge to completely separate the display panel from the frame.
  37. Motorola Moto G 5G (2022) Display Panel Replacement, Remove the display panel: passo 37, imagem 1 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the display panel: passo 37, imagem 2 %32 Motorola Moto G 5G (2022) Display Panel Replacement, Remove the display panel: passo 37, imagem 3 %32
    • Grab and pull the bottom of the display panel down and away from the frame, making sure to thread the display cable through its slot.
    • Once the display cable is free, remove the panel from the frame.
Conclusão
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Clay Eickemeyer
Membro desde: 09/19/22
67.297 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.420 guias
2 comentários
How do I replace the edge of my phone just need some help trying to do that
Johnny Boy - Responder
Hi Johnny,
If you're looking to replace the border around the perimeter of your phone, then this would be a back cover replacement. The back cover includes the edge of the case, right up to the screen bezel.
Clay Eickemeyer -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 140
Duração total: 2,417
