Ir para o conteúdo principal
Microsoft Surface Pro X Screen Replacement
O que você precisa
    1. Microsoft Surface Pro X Screen Replacement, Open the kickstand: passo 1, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Open the kickstand: passo 1, imagem 2 %32
      • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
      • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
      • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface Pro X Screen Replacement, Open the SSD and SIM card door: passo 2, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Open the SSD and SIM card door: passo 2, imagem 2 %32
      • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
      • Press firmly to open the door.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Surface Pro X Screen Replacement, Remove the SSD and SIM card door: passo 3, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    1. Microsoft Surface Pro X Screen Replacement, Remove the SSD screw: passo 4, imagem 1 %32
      • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface Pro X Screen Replacement, Remove the SSD: passo 5, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Remove the SSD: passo 5, imagem 2 %32 Microsoft Surface Pro X Screen Replacement, Remove the SSD: passo 5, imagem 3 %32
      • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
      • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
      • Gently pull the SSD straight out of its socket.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Pergunte ao FixBot
      Comentar
    1. Microsoft Surface Pro X Screen Replacement, Tape the screen: passo 6, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Tape the screen: passo 6, imagem 2 %32 Microsoft Surface Pro X Screen Replacement, Tape the screen: passo 6, imagem 3 %32
      • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
      • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
      • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface Pro X Screen Replacement, Apply a suction cup to the screen: passo 7, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Apply a suction cup to the screen: passo 7, imagem 2 %32
      • Wear safety glasses during the screen removal procedure in case the glass shatters while you're working.
      • There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to work slowly and be extremely careful while slicing through the adhesive.
      • Place your tablet on your work surface so that the screen is facing up.
      • Apply a suction cup to the screen next to the right speaker grille.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Surface Pro X Screen Replacement, Secure the tablet: passo 8, imagem 1 %32
      • Place your hand on the screen next to the suction cup to secure the Surface while you lift up the screen.
      Pergunte ao FixBot
      Comentar
    4. Microsoft Surface Pro X Screen Replacement, Create a gap between the screen and frame: passo 9, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Create a gap between the screen and frame: passo 9, imagem 2 %32 Microsoft Surface Pro X Screen Replacement, Create a gap between the screen and frame: passo 9, imagem 3 %32
      • Don't insert the opening pick more than 3 mm while cutting through the adhesive on the right, bottom, and left edge.
      • Lift up on the suction cup to create a gap between the screen and the frame.
      • The gap only needs to be wide enough to slide in an opening pick.
      • Insert an opening pick about 2 mm into the gap. Leave the opening pick in the gap to prevent it from resealing.
      Pergunte ao FixBot
      Comentar
    5. Microsoft Surface Pro X Screen Replacement, Cut through the screen adhesive: passo 10, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Cut through the screen adhesive: passo 10, imagem 2 %32
      • Insert a second opening pick into the gap between the screen and the frame.
      • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
      • Leave this opening pick in the right edge to prevent the adhesive from resealing.
      Pergunte ao FixBot
      Comentar
    6. Microsoft Surface Pro X Screen Replacement: passo 11, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 11, imagem 2 %32 Microsoft Surface Pro X Screen Replacement: passo 11, imagem 3 %32
      • Don't insert the pick more than 3 mm while cutting through the screen adhesive on the bottom edge or you may damage delicate components on the screen.
      • Insert a third opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
      Pergunte ao FixBot
      Comentar
    7. Microsoft Surface Pro X Screen Replacement: passo 12, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 12, imagem 2 %32
      • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
      • Leave this pick in the bottom edge to prevent the adhesive from resealing.
      Pergunte ao FixBot
      Comentar
    8. Microsoft Surface Pro X Screen Replacement: passo 13, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 13, imagem 2 %32 Microsoft Surface Pro X Screen Replacement: passo 13, imagem 3 %32
      • Insert a fourth opening pick into the bottom left corner and slide it around the corner toward the left edge.
      • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
      • Leave this pick in the left edge to prevent the adhesive from resealing.
      Pergunte ao FixBot
      Comentar
    9. Microsoft Surface Pro X Screen Replacement: passo 14, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 14, imagem 2 %32 Microsoft Surface Pro X Screen Replacement: passo 14, imagem 3 %32
      • Don't insert the opening pick more than 10 mm while cutting through the adhesive on the top edge. Don't insert the pick more than 3 mm near the speaker grille.
      • Insert a fifth opening pick into the top left corner and slide it around the corner toward the top edge.
      • Slide the pick along the top edge of the Surface to cut through the screen adhesive.
      Pergunte ao FixBot
      Comentar
    10. Microsoft Surface Pro X Screen Replacement, Open the Surface: passo 15, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Open the Surface: passo 15, imagem 2 %32 Microsoft Surface Pro X Screen Replacement, Open the Surface: passo 15, imagem 3 %32
      • Do not remove the screen yet. It is still connected to the motherboard by the display cable. Keep the screen as close as possible to the Surface's frame to avoid straining the display cable.
      • Avoid hitting the battery with the screen during this procedure. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
      • Lift up the top edge of the screen so that it is at a 30° angle with the frame.
      • If you encounter any resistance, stop and check that all the adhesive is separated. Use an opening pick to cut through any remaining adhesive.
      • Rotate the screen so that its bottom edge is in the middle of the frame. The screen should be perpendicular to the frame.
      • Rotate the screen 90° so that it is facing down. Place the screen on the frame.
      Pergunte ao FixBot
      Comentar
    1. Microsoft Surface Pro X Screen Replacement, Remove the display cable shield: passo 16, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Remove the display cable shield: passo 16, imagem 2 %32 Microsoft Surface Pro X Screen Replacement, Remove the display cable shield: passo 16, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Insert a tine of a pair of pointed tweezers under the bottom right corner of the display cable shield (where the display cable is oriented down).
      • Lift up the corner to detach it from the screen.
      Pergunte ao FixBot
      Comentar
    2. Microsoft Surface Pro X Screen Replacement: passo 17, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 17, imagem 2 %32
      • Repeat the previous step for the bottom right corner.
      Pergunte ao FixBot
      Comentar
    3. Microsoft Surface Pro X Screen Replacement: passo 18, imagem 1 %32
      • Remove the display cable shield from the screen.
      • If the display cable shield isn't completely detached from the screen, pry up additional areas around the edges of the shield.
      Pergunte ao FixBot
      Comentar
    4. Microsoft Surface Pro X Screen Replacement, Disconnect the screen: passo 19, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Disconnect the screen: passo 19, imagem 2 %32
      • Insert the pointed end of a spudger under the right side of the display cable press connector.
      • Lift up the right side of the press connector to detach it from the display cable socket on the screen.
      Pergunte ao FixBot
      Comentar
    5. Microsoft Surface Pro X Screen Replacement: passo 20, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 20, imagem 2 %32
      • Repeat the previous step on the left side of the display cable connector to fully disconnect it from the screen.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Pergunte ao FixBot
      Comentar
    6. Microsoft Surface Pro X Screen Replacement, Remove the screen: passo 21, imagem 1 %32
      • Remove the screen from the frame.
      Pergunte ao FixBot
      Comentar
    7. Microsoft Surface Pro X Screen Replacement, Speaker grille information: passo 22, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Speaker grille information: passo 22, imagem 2 %32
      • The left and right speaker grilles may be attached to the Surface's frame or the screen.
      • If you are going to replace a speaker grille that is attached to the frame, follow these steps to remove it:
      • Use an opening pick to cut through the adhesive under the grille.
      • Remove the speaker grille.
      • Repeat for the other speaker grille.
      Pergunte ao FixBot
      Comentar
    8. Microsoft Surface Pro X Screen Replacement: passo 23, imagem 1 %32 Microsoft Surface Pro X Screen Replacement: passo 23, imagem 2 %32
      • If you are going to replace or transfer a speaker grille that is attached to the screen, follow these steps to remove it:
      Pergunte ao FixBot
      Comentar
    9. Microsoft Surface Pro X Screen Replacement, Screen adhesive information: passo 24, imagem 1 %32 Microsoft Surface Pro X Screen Replacement, Screen adhesive information: passo 24, imagem 2 %32 Microsoft Surface Pro X Screen Replacement, Screen adhesive information: passo 24, imagem 3 %32
      • If you are going to replace the screen adhesive, follow these steps:
      • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the adhesive.
      • Use a cotton swab or the flat end of a spudger to scrape away the adhesive.
      • Use a lint-free cloth or coffee filter to wipe away any remaining adhesive.
      • Allow the surface to dry completely before applying replacement adhesive.
      • Apply new adhesive strips or pre-cut adhesive to the frame where the old screen adhesive was located.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
6 outras pessoas executaram este guia.
Kyle Smith
Membro desde: 02/01/21
52.586 Reputação
Autoria de 124 guias
2Comentários do guia
Tried using suction cup to start lifting the screen. No joy. Cannot seem to create a space to insert plastic pik. Can I safely use heat to soften the glue?
Art Ellison - Responder Compartilhar
Re: my comment. Gave up on the method listed in the repair guide. Much too difficult. Instead I used my heat gun (had it on hand from repairing other touch screens) and it worked so much faster. You need to actually know how to use it, though. Heat must be just right to soften the double-sided tape used to install it. Using this method, there is little chance of cracking the screen.
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 77
Últimos 30 dias: 159
Ao todo: 9,732
