Ir para o conteúdo principal
Microsoft Surface Pro X Power Button Cable Replacement
O que você precisa
  1. Microsoft Surface Pro X Power Button Cable Replacement, Open the kickstand: passo 1, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Open the kickstand: passo 1, imagem 2 %32
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X Power Button Cable Replacement, Open the SSD and SIM card door: passo 2, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Open the SSD and SIM card door: passo 2, imagem 2 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD and SIM card door: passo 3, imagem 1 %32
  4. Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD screw: passo 4, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD: passo 5, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD: passo 5, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD: passo 5, imagem 3 %32
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. Microsoft Surface Pro X Power Button Cable Replacement, Tape the screen: passo 6, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Tape the screen: passo 6, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Tape the screen: passo 6, imagem 3 %32
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  7. Microsoft Surface Pro X Power Button Cable Replacement, Apply a suction cup to the screen: passo 7, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Apply a suction cup to the screen: passo 7, imagem 2 %32
    • Wear safety glasses during the screen removal procedure in case the glass shatters while you're working.
    • There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to work slowly and be extremely careful while slicing through the adhesive.
    • Place your tablet on your work surface so that the screen is facing up.
    • Apply a suction cup to the screen next to the right speaker grille.
  8. Microsoft Surface Pro X Power Button Cable Replacement, Secure the tablet: passo 8, imagem 1 %32
    • Place your hand on the screen next to the suction cup to secure the Surface while you lift up the screen.
  9. Microsoft Surface Pro X Power Button Cable Replacement, Create a gap between the screen and frame: passo 9, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Create a gap between the screen and frame: passo 9, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Create a gap between the screen and frame: passo 9, imagem 3 %32
    • Don't insert the opening pick more than 3 mm while cutting through the adhesive on the right, bottom, and left edge.
    • Lift up on the suction cup to create a gap between the screen and the frame.
    • The gap only needs to be wide enough to slide in an opening pick.
    • Insert an opening pick about 2 mm into the gap. Leave the opening pick in the gap to prevent it from resealing.
  10. Microsoft Surface Pro X Power Button Cable Replacement, Cut through the screen adhesive: passo 10, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Cut through the screen adhesive: passo 10, imagem 2 %32
    • Insert a second opening pick into the gap between the screen and the frame.
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  11. Microsoft Surface Pro X Power Button Cable Replacement: passo 11, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 11, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 11, imagem 3 %32
    • Don't insert the pick more than 3 mm while cutting through the screen adhesive on the bottom edge or you may damage delicate components on the screen.
    • Insert a third opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
  12. Microsoft Surface Pro X Power Button Cable Replacement: passo 12, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 12, imagem 2 %32
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  13. Microsoft Surface Pro X Power Button Cable Replacement: passo 13, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 13, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 13, imagem 3 %32
    • Insert a fourth opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  14. Microsoft Surface Pro X Power Button Cable Replacement: passo 14, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 14, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 14, imagem 3 %32
    • Don't insert the opening pick more than 10 mm while cutting through the adhesive on the top edge. Don't insert the pick more than 3 mm near the speaker grille.
    • Insert a fifth opening pick into the top left corner and slide it around the corner toward the top edge.
    • Slide the pick along the top edge of the Surface to cut through the screen adhesive.
  15. Microsoft Surface Pro X Power Button Cable Replacement, Open the Surface: passo 15, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Open the Surface: passo 15, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Open the Surface: passo 15, imagem 3 %32
    • Do not remove the screen yet. It is still connected to the motherboard by the display cable. Keep the screen as close as possible to the Surface's frame to avoid straining the display cable.
    • Avoid hitting the battery with the screen during this procedure. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Lift up the top edge of the screen so that it is at a 30° angle with the frame.
    • If you encounter any resistance, stop and check that all the adhesive is separated. Use an opening pick to cut through any remaining adhesive.
    • Rotate the screen so that its bottom edge is in the middle of the frame. The screen should be perpendicular to the frame.
    • Rotate the screen 90° so that it is facing down. Place the screen on the frame.
  16. Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable shield: passo 16, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable shield: passo 16, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable shield: passo 16, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Insert a tine of a pair of pointed tweezers under the bottom right corner of the display cable shield (where the display cable is oriented down).
    • Lift up the corner to detach it from the screen.
  17. Microsoft Surface Pro X Power Button Cable Replacement: passo 17, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 17, imagem 2 %32
    • Repeat the previous step for the bottom right corner.
  18. Microsoft Surface Pro X Power Button Cable Replacement: passo 18, imagem 1 %32
    • Remove the display cable shield from the screen.
    • If the display cable shield isn't completely detached from the screen, pry up additional areas around the edges of the shield.
  19. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the screen: passo 19, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the screen: passo 19, imagem 2 %32
    • Insert the pointed end of a spudger under the right side of the display cable press connector.
    • Lift up the right side of the press connector to detach it from the display cable socket on the screen.
  20. Microsoft Surface Pro X Power Button Cable Replacement: passo 20, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 20, imagem 2 %32
    • Repeat the previous step on the left side of the display cable connector to fully disconnect it from the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Microsoft Surface Pro X Power Button Cable Replacement, Remove the screen: passo 21, imagem 1 %32
    • Remove the screen from the frame.
  22. Microsoft Surface Pro X Power Button Cable Replacement, Speaker grille information: passo 22, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Speaker grille information: passo 22, imagem 2 %32
    • The left and right speaker grilles may be attached to the Surface's frame or the screen.
    • If you are going to replace a speaker grille that is attached to the frame, follow these steps to remove it:
    • Use an opening pick to cut through the adhesive under the grille.
    • Remove the speaker grille.
    • Repeat for the other speaker grille.
  23. Microsoft Surface Pro X Power Button Cable Replacement: passo 23, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 23, imagem 2 %32
    • If you are going to replace or transfer a speaker grille that is attached to the screen, follow these steps to remove it:
  24. Microsoft Surface Pro X Power Button Cable Replacement, Screen adhesive information: passo 24, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Screen adhesive information: passo 24, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Screen adhesive information: passo 24, imagem 3 %32
    • If you are going to replace the screen adhesive, follow these steps:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the adhesive.
    • Use a cotton swab or the flat end of a spudger to scrape away the adhesive.
    • Use a lint-free cloth or coffee filter to wipe away any remaining adhesive.
    • Allow the surface to dry completely before applying replacement adhesive.
    • Apply new adhesive strips or pre-cut adhesive to the frame where the old screen adhesive was located.
  25. Microsoft Surface Pro X Power Button Cable Replacement, Remove the heat sink sticker: passo 25, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the heat sink sticker: passo 25, imagem 2 %32
    • If you are going to reinstall this sticker during reassembly, try to keep it as intact as possible.
    • Lift up the edge of the heat sink sticker closest to the bottom edge of the Surface.
  26. Microsoft Surface Pro X Power Button Cable Replacement: passo 26, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 26, imagem 2 %32
    • Lift up the center of the sticker.
  27. Microsoft Surface Pro X Power Button Cable Replacement: passo 27, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 27, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 27, imagem 3 %32
    • Lift up one side of the sticker attached to the heat sink.
    • Repeat for the other side. The sticker should now be fully detached.
    • Remove the sticker.
  28. Microsoft Surface Pro X Power Button Cable Replacement, Remove the screw stickers: passo 28, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the screw stickers: passo 28, imagem 2 %32
    • If you are going to reinstall these stickers during reassembly, try to keep them as intact as possible. These stickers can tear easily during removal.
    • Use an opening tool to lift up the edge of one of the small black stickers covering the four screws in the center of the heat sink.
    • You only need to lift the edge enough to grip it with tweezers.
  29. Microsoft Surface Pro X Power Button Cable Replacement: passo 29, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 29, imagem 2 %32
    • Use a pair of blunt tweezers to remove the sticker covering the heat sink screw.
    • Repeat this process for the other three stickers.
  30. Microsoft Surface Pro X Power Button Cable Replacement, Remove the heat sink screws: passo 30, imagem 1 %32
    • Remove the 14 screws securing the heat sink:
    • Eight 2.2 mm T3 Torx screws
    • One 2.0 mm T3 Torx screw
    • One 3.2 mm T3 Torx screw
    • Four 2.5 mm T6 screws
  31. Microsoft Surface Pro X Power Button Cable Replacement, Remove the heat sink: passo 31, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the heat sink: passo 31, imagem 2 %32
    • The heat sink is adhered to the CPU with thermal paste.
    • Insert an opening pick about 2 mm under the heat sink at its bottom edge directly to the left of the display cable.
    • The opening pick should be between the heat sink and the frame surrounding the motherboard.
    • Slide the opening pick to the left toward the heat pipe to detach the heat sink from the CPU.
  32. Microsoft Surface Pro X Power Button Cable Replacement: passo 32, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 32, imagem 2 %32
    • Swing the bottom edge of the heat sink up so that it is at about a 10° angle with the frame.
  33. Microsoft Surface Pro X Power Button Cable Replacement: passo 33, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 33, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 33, imagem 3 %32
  34. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the right speaker: passo 34, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the right speaker: passo 34, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the right speaker's press connector from its socket.
  35. Microsoft Surface Pro X Power Button Cable Replacement, Detach the right speaker's cable: passo 35, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Detach the right speaker's cable: passo 35, imagem 2 %32
    • Use an opening pick to cut through the adhesive under the right speaker's cable and detach it from the frame.
  36. Microsoft Surface Pro X Power Button Cable Replacement, Lift up the foam adhesive: passo 36, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Lift up the foam adhesive: passo 36, imagem 2 %32
    • Use the flat end of a spudger to lift up the foam adhesive covering the right speaker's top right screw.
  37. Microsoft Surface Pro X Power Button Cable Replacement, Remove the right speaker screws: passo 37, imagem 1 %32
    • Remove the two screws securing the right speaker:
    • One 2.2 mm T3 Torx screw
    • One 2.9 mm T6 Torx screw
  38. Microsoft Surface Pro X Power Button Cable Replacement, Remove the right speaker: passo 38, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the right speaker: passo 38, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the right speaker: passo 38, imagem 3 %32
    • Use the flat end of a spudger to lift the cable side of the right speaker enough to grab it with your fingers.
    • Remove the right speaker from the frame.
  39. Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable shield: passo 39, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable shield: passo 39, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable shield: passo 39, imagem 3 %32
    • Take care not to puncture or bend the battery with your tweezers—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • If you are going to reuse this shield, try to avoid excessively bending it during removal.
    • Note that the display cable is oriented down for this shield removal procedure.
    • Insert one tine of a pair of pointed tweezers into a divot on a tab in the top right corner of the display cable shield.
    • Lift up the corner to detach it from the frame.
  40. Microsoft Surface Pro X Power Button Cable Replacement: passo 40, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 40, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 40, imagem 3 %32
    • Slide one tine of a pair of pointed tweezers under the right side of the top edge of the shield to detach it from the frame.
    • Repeat for the left side of the top edge.
  41. Microsoft Surface Pro X Power Button Cable Replacement: passo 41, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 41, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 41, imagem 3 %32
    • Slide one tine of a pair of pointed tweezers under the right side of the top edge of the shield.
    • Lift up the top edge to further detach it from the frame.
  42. Microsoft Surface Pro X Power Button Cable Replacement: passo 42, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 42, imagem 2 %32
    • Slide one tine of a pair of pointed tweezers under the top side of the right edge of the shield.
    • Lift up to detach the top section of the shield from the frame.
    • Repeat for the top side of the left edge.
  43. Microsoft Surface Pro X Power Button Cable Replacement: passo 43, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 43, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers under the right edge of the shield near the top right corner.
    • Lift up to further detach the shield from the frame.
  44. Microsoft Surface Pro X Power Button Cable Replacement: passo 44, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 44, imagem 2 %32
    • Repeat the previous step for the center of the right edge of the shield.
  45. Microsoft Surface Pro X Power Button Cable Replacement: passo 45, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 45, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers under the left edge of the shield near the top left corner.
  46. Microsoft Surface Pro X Power Button Cable Replacement: passo 46, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 46, imagem 2 %32
    • Repeat the previous step for the center of the left edge of the shield.
  47. Microsoft Surface Pro X Power Button Cable Replacement: passo 47, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 47, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers under the right edge of the shield near the bottom right corner.
    • Lift up the right edge to detach the shield from the frame.
  48. Microsoft Surface Pro X Power Button Cable Replacement: passo 48, imagem 1 %32
    • Remove the display cable shield.
    • If the shield isn't completely detached from the frame, pry up additional areas around the edges of the shield.
  49. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the display cable: passo 49, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the display cable: passo 49, imagem 2 %32
    • Use the flat end of a spudger to disconnect the display cable press connector from its socket.
  50. Microsoft Surface Pro X Power Button Cable Replacement, Remove the display cable: passo 50, imagem 1 %32
    • Remove the display cable from the Surface.
  51. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the left speaker: passo 51, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the left speaker: passo 51, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the left speaker's press connector from its socket.
  52. Microsoft Surface Pro X Power Button Cable Replacement, Detach the left speaker's cable: passo 52, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Detach the left speaker's cable: passo 52, imagem 2 %32
    • Use an opening pick to cut through the adhesive under the left speaker's cable and detach it from the frame.
  53. Microsoft Surface Pro X Power Button Cable Replacement, Lift up the foam adhesive: passo 53, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Lift up the foam adhesive: passo 53, imagem 2 %32
    • Use the flat end of a spudger to lift up the foam adhesive covering the left speaker's top left screw.
  54. Microsoft Surface Pro X Power Button Cable Replacement, Remove the left speaker screws: passo 54, imagem 1 %32
    • Remove the three screws securing the left speaker:
    • One 3.0 mm T3 Torx screw
  55. Microsoft Surface Pro X Power Button Cable Replacement, Remove the left speaker: passo 55, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the left speaker: passo 55, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the left speaker: passo 55, imagem 3 %32
    • Use the flat end of a spudger to lift the cable side of the left speaker enough to grab it with your fingers.
    • Remove the left speaker from the frame.
  56. Microsoft Surface Pro X Power Button Cable Replacement, Lift the corner of the shield: passo 56, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Lift the corner of the shield: passo 56, imagem 2 %32
    • Take care not to puncture or bend the battery with any tools while removing the SSD port—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert one tine of a pair of pointed tweezers under the top left corner of the SSD port connector's shield (where the cable is oriented down).
  57. Microsoft Surface Pro X Power Button Cable Replacement, Remove the shield: passo 57, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the shield: passo 57, imagem 2 %32
    • Remove the SSD port connector's shield.
    • If the shield isn't completely detached from the frame, pry up additional areas on the edges of the shield.
  58. Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD port sticker: passo 58, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD port sticker: passo 58, imagem 2 %32
    • Use the pointed end of a spudger to lift up a corner of the black sticker covering the SSD port.
  59. Microsoft Surface Pro X Power Button Cable Replacement: passo 59, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 59, imagem 2 %32
    • Remove the SSD port sticker.
  60. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the SSD port: passo 60, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the SSD port: passo 60, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the SSD port's press connector from its socket.
  61. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the SIM card reader: passo 61, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the SIM card reader: passo 61, imagem 2 %32
    • Use the flat end of a spudger to disconnect the SIM card reader's press connector from its socket.
  62. Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD port screws: passo 62, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the two 2.5 mm screws securing the SSD port.
  63. Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD port: passo 63, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the SSD port: passo 63, imagem 2 %32
    • The SSD port cable is lightly adhered to the frame. If the adhesive is too difficult to cut through, continue to the next step for additional removal instructions.
    • Use an opening pick to cut through the adhesive under the SIM card reader socket.
  64. Microsoft Surface Pro X Power Button Cable Replacement: passo 64, imagem 1 %32
    • If the adhesive under the SIM card reader socket is too difficult to cut through, follow these steps to loosen the adhesive:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the SIM card reader socket to loosen the adhesive underneath.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
  65. Microsoft Surface Pro X Power Button Cable Replacement: passo 65, imagem 1 %32
    • Remove the SSD port from the frame.
    • If there's any alcohol solution remaining in the Surface, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your SSD port.
  66. Microsoft Surface Pro X Power Button Cable Replacement, Remove the foam adhesive: passo 66, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the foam adhesive: passo 66, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the foam adhesive: passo 66, imagem 3 %32
    • Remove the foam adhesive strip from the Surface.
  67. Microsoft Surface Pro X Power Button Cable Replacement, Remove the front camera shield: passo 67, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the front camera shield: passo 67, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers under one corner of the shield covering the front camera connector.
  68. Microsoft Surface Pro X Power Button Cable Replacement: passo 68, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 68, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 68, imagem 3 %32
    • Repeat the previous step for the other three corners of the shield.
  69. Microsoft Surface Pro X Power Button Cable Replacement: passo 69, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 69, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 69, imagem 3 %32
    • Slide one tine of a pair of pointed tweezers under the left edge of the shield to further detach it from the frame.
    • Repeat this for the right edge of the shield.
  70. Microsoft Surface Pro X Power Button Cable Replacement: passo 70, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 70, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 70, imagem 3 %32
    • Slide one tine of a pair of pointed tweezers under the bottom left edge of the shield to further detach it from the frame.
    • Repeat for the bottom right edge.
  71. Microsoft Surface Pro X Power Button Cable Replacement: passo 71, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 71, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers into the divot in one of the tabs on the bottom edge of the shield.
    • You could also insert the tine under the bottom edge of the shield.
    • Lift up the bottom edge to detach it from the frame.
  72. Microsoft Surface Pro X Power Button Cable Replacement: passo 72, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 72, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 72, imagem 3 %32
    • Use a pair of tweezers to lift up the bottom edge of the shield so that it is at a 30° angle with the frame.
    • This will detach the top edge of the shield from the frame.
    • Remove the front camera shield from the frame.
  73. Microsoft Surface Pro X Power Button Cable Replacement, Remove the rear camera shield: passo 73, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the rear camera shield: passo 73, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers under one corner of the shield covering the rear camera connector.
  74. Microsoft Surface Pro X Power Button Cable Replacement: passo 74, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 74, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 74, imagem 3 %32
    • Repeat the previous step for the remaining three corners of the shield.
  75. Microsoft Surface Pro X Power Button Cable Replacement: passo 75, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 75, imagem 2 %32
    • Use a pair of pointed tweezers to lift up the left side of the shield.
  76. Microsoft Surface Pro X Power Button Cable Replacement: passo 76, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 76, imagem 2 %32
    • Slide one tine of a pair of pointed tweezers under the bottom right edge of the shield to fully detach it from the frame.
  77. Microsoft Surface Pro X Power Button Cable Replacement: passo 77, imagem 1 %32
    • Remove the shield covering the rear camera connector.
  78. Microsoft Surface Pro X Power Button Cable Replacement, Remove the camera foam strip: passo 78, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the camera foam strip: passo 78, imagem 2 %32
    • Use a pair of tweezers to remove the foam strip adhered to the front camera, Windows Hello face camera, and left microphone cables.
  79. Microsoft Surface Pro X Power Button Cable Replacement, Remove the Surface Connect port screws: passo 79, imagem 1 %32
    • Use a T6 Torx screwdriver to remove the two 2.8 mm screws securing the Surface Connect port.
  80. Microsoft Surface Pro X Power Button Cable Replacement, Dislodge the Surface Connect port: passo 80, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Dislodge the Surface Connect port: passo 80, imagem 2 %32
    • The Surface Connect port connector can be disconnected before moving the port, but the connector is difficult to reconnect while the port is fully seated. During reassembly, it is easier to reconnect the connector before seating the port into its recess.
    • Use the flat end of a spudger to pry up the left screw tab and dislodge the Surface Connect port from the frame.
    • You only need to lift the port high enough to insert the pointed end of a spudger into the screw tab.
  81. Microsoft Surface Pro X Power Button Cable Replacement, Detach the Surface Connect port: passo 81, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Detach the Surface Connect port: passo 81, imagem 2 %32
    • Insert the pointed end of a spudger into the left screw tab.
    • Push the Surface Connect port toward its connector to detach its magnets from the frame.
    • You only need to push the port enough to detach it from the frame and grab it with your fingers. Don't bend the cable more than necessary.
  82. Microsoft Surface Pro X Power Button Cable Replacement, Move the Surface Connect port: passo 82, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Move the Surface Connect port: passo 82, imagem 2 %32
    • Hold the edges of the Surface Connect port with your fingers.
    • Pull the port away from the edge of the frame and place it on top of the edge.
  83. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the Surface Connect port: passo 83, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the Surface Connect port: passo 83, imagem 2 %32
    • Insert the flat end of a spudger under the foam on top of the Surface Connect port's connector.
    • Lift up on the foam to open the connector's locking tab.
  84. Microsoft Surface Pro X Power Button Cable Replacement: passo 84, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 84, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 84, imagem 3 %32
    • Place the flat end of a spudger under the left edge of the connector's locking tab.
    • While holding the Surface Connect port with your fingers, push the connector out of its socket in the direction of the cable.
    • If this doesn't fully disconnect the connector, repeat this step for the right edge of the locking tab. Alternate between the left and right edge as needed.
  85. Microsoft Surface Pro X Power Button Cable Replacement, Remove the Surface Connect port: passo 85, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the Surface Connect port: passo 85, imagem 2 %32
    • Remove the Surface Connect port from the frame.
    • During reassembly, make sure to fully insert the Surface Connect port connector into its socket. The internal metal edge of the connector should be directly adjacent to the metal edge of the socket.
  86. Microsoft Surface Pro X Power Button Cable Replacement, Remove the USB-C port shield screws: passo 86, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the three 2.9 mm screws securing the first USB-C port shield.
  87. Microsoft Surface Pro X Power Button Cable Replacement, Remove the first USB-C port shield: passo 87, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the first USB-C port shield: passo 87, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the first USB-C port shield: passo 87, imagem 3 %32
    • If you are going to reuse the USB-C port shields, try to avoid excessively bending them during removal.
    • Insert one tine of a pair of pointed tweezers into the gap in the first USB-C port shield next to the screw hole closest to the left speaker.
    • Lift up the shield to detach it from the frame.
  88. Microsoft Surface Pro X Power Button Cable Replacement: passo 88, imagem 1 %32
    • Remove the first USB-C port shield from the frame.
  89. Microsoft Surface Pro X Power Button Cable Replacement, Remove the second USB-C port shield: passo 89, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the second USB-C port shield: passo 89, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the second USB-C port shield: passo 89, imagem 3 %32
    • Don't pry up the USB-C port shield near the battery—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert one tine of a pair of pointed tweezers under one of the shield's corners closest to the left speaker recess.
    • Slide the tine along the edge of the shield to detach the corner from the frame.
  90. Microsoft Surface Pro X Power Button Cable Replacement: passo 90, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 90, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 90, imagem 3 %32
    • Note that the second USB-C port shield may fling off of the frame when you detach it. You can place a finger on the shield to prevent it from flinging.
    • Repeat the previous step for the other corner of the shield closest to the left speaker recess.
    • Continue prying up the edge of the shield closest to the left speaker recess until the shield detaches from the frame.
    • Remove the shield from the frame.
  91. Microsoft Surface Pro X Power Button Cable Replacement, Remove the USB-C port press connector screws: passo 91, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the two 2 mm screws securing the USB-C port press connector.
  92. Microsoft Surface Pro X Power Button Cable Replacement: passo 92, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 92, imagem 2 %32
    • Insert the flat end of a spudger under the long edge of the USB-C port press connector.
    • Rotate the flat end of the spudger to disconnect the press connector from its socket.
  93. Microsoft Surface Pro X Power Button Cable Replacement, Remove the USB-C port screws: passo 93, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the two 2.7 mm screws securing the USB-C port.
  94. Microsoft Surface Pro X Power Button Cable Replacement, Remove the USB-C ports: passo 94, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the USB-C ports: passo 94, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the USB-C ports: passo 94, imagem 3 %32
    • Use a pair of tweezers to grip the USB-C port screw hole tab closest to the left speaker.
    • Lift up the press connector edge of the USB-C ports to detach it from the frame.
    • Remove the USB-C ports from the frame.
  95. Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the sensor bar components: passo 95, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the sensor bar components: passo 95, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Disconnect the sensor bar components: passo 95, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the right microphone press connector from its socket.
    • Disconnect the rear camera.
  96. Microsoft Surface Pro X Power Button Cable Replacement: passo 96, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 96, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 96, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the front camera, the Windows Hello face camera, and the left microphone.
  97. Microsoft Surface Pro X Power Button Cable Replacement, Motherboard shield information: passo 97, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Motherboard shield information: passo 97, imagem 2 %32
    • There are two shields on the motherboard covering screws that secure it to the frame:
    • One square shield to the right of the USB-C port.
    • One rectangular shield to the right of the camera connector sockets.
  98. Microsoft Surface Pro X Power Button Cable Replacement, Remove the two shields: passo 98, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the two shields: passo 98, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the two shields: passo 98, imagem 3 %32
    • Avoid prying near the battery while removing the shields—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Note that the shields may fling off of the frame when you detach them. You can place a finger on the shield to prevent it from flinging.
    • Insert one tine of a pair of pointed tweezers under a corner of the square shield.
    • Continue to pry up additional areas around the edges of the shield until it detaches from the frame.
    • Remove the square shield.
    • If you are going to reuse these shields, try to avoid excessively bending them during removal.
  99. Microsoft Surface Pro X Power Button Cable Replacement: passo 99, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 99, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 99, imagem 3 %32
    • Repeat the previous step to remove the rectangular shield.
  100. Microsoft Surface Pro X Power Button Cable Replacement, Remove the front-facing sensor bar screws: passo 100, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the eight 5.5 mm screws securing the front-facing sensor bar.
  101. Microsoft Surface Pro X Power Button Cable Replacement, Dislodge the front-facing sensor bar: passo 101, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Dislodge the front-facing sensor bar: passo 101, imagem 2 %32
    • Insert the pointed end of a spudger into the gap on the right side of the sensor bar between the rightmost screw hole and the adjacent screw hole.
    • Lift up the right side of the sensor bar to dislodge it from the frame.
    • You only need to lift the sensor bar so that it is loose in the frame. Don't try to remove the front sensor bar—it is still attached to the Surface by a cable that connects under the motherboard.
  102. Microsoft Surface Pro X Power Button Cable Replacement: passo 102, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 102, imagem 2 %32
    • Repeat the previous step for the gap in the sensor bar between the second and third screw hole from the left.
    • This gap is where the sensor bar's cable is located.
  103. Microsoft Surface Pro X Power Button Cable Replacement, Lift the front-facing sensor bar: passo 103, imagem 1 %32
    • The motherboard has spring connectors that fit under the front-facing sensor bar. Lifting the sensor bar makes it easier to remove and replace the motherboard.
    • Lift the sensor bar about 30° out of its recess.
    • Don't push the sensor bar past 90° and don't rotate it horizontally to avoid damaging the cable connecting it to the motherboard.
  104. Microsoft Surface Pro X Power Button Cable Replacement, Remove the motherboard screws: passo 104, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the six 2 mm screws securing the motherboard.
  105. Microsoft Surface Pro X Power Button Cable Replacement, Remove the motherboard: passo 105, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the motherboard: passo 105, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement, Remove the motherboard: passo 105, imagem 3 %32
    • Lift the bottom edge of the motherboard about a half-centimeter above the frame.
    • You only need to lift the motherboard high enough for it to clear the battery as you slide it out.
    • Hold the motherboard on the left and right edge.
  106. Microsoft Surface Pro X Power Button Cable Replacement: passo 106, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 106, imagem 2 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 106, imagem 3 %32
    • Pull the motherboard down toward the bottom edge of the Surface to remove it from the frame.
  107. Microsoft Surface Pro X Power Button Cable Replacement, Detach the power button cable: passo 107, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Detach the power button cable: passo 107, imagem 2 %32
    • The power button cable is lightly adhered to the frame.
    • Use an opening pick to cut through the adhesive on the left side of the bottom edge of the power button cable.
  108. Microsoft Surface Pro X Power Button Cable Replacement: passo 108, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 108, imagem 2 %32
    • Slide the opening pick under the left side of the power button cable to further detach it from the frame.
  109. Microsoft Surface Pro X Power Button Cable Replacement: passo 109, imagem 1 %32
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the power button cable.
  110. Microsoft Surface Pro X Power Button Cable Replacement: passo 110, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 110, imagem 2 %32
    • Lift the power button cable away from the frame.
    • If the power button cable doesn't easily lift away, apply a few more drops of isopropyl alcohol before trying again.
  111. Microsoft Surface Pro X Power Button Cable Replacement, Remove the power button bracket screws: passo 111, imagem 1 %32
    • Use a T3 screwdriver to remove the two 2.4 mm screws securing the power button bracket.
  112. Microsoft Surface Pro X Power Button Cable Replacement, Detach the power button bracket: passo 112, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Detach the power button bracket: passo 112, imagem 2 %32
    • Use a pair of blunt tweezers to pull the left side of the power button bracket straight out of the frame.
  113. Microsoft Surface Pro X Power Button Cable Replacement: passo 113, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 113, imagem 2 %32
    • Repeat the previous step for the right side of the power button bracket.
  114. Microsoft Surface Pro X Power Button Cable Replacement, Remove the power button bracket: passo 114, imagem 1 %32
    • The power button cable is adhered to the power button bracket.
    • Remove the power button bracket from the frame.
  115. Microsoft Surface Pro X Power Button Cable Replacement, Power button cover information: passo 115, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement, Power button cover information: passo 115, imagem 2 %32
    • If the power button cover falls out, make sure it is oriented correctly when you replace it. The left and right tabs on the cover should be angled down.
  116. Microsoft Surface Pro X Power Button Cable Replacement, Remove the power button cable: passo 116, imagem 1 %32
  117. Microsoft Surface Pro X Power Button Cable Replacement: passo 117, imagem 1 %32 Microsoft Surface Pro X Power Button Cable Replacement: passo 117, imagem 2 %32
    • Use an opening pick to cut through the adhesive under the power button cable and detach it from the bracket.
  118. Microsoft Surface Pro X Power Button Cable Replacement: passo 118, imagem 1 %32
    • Only the power button cable remains.
    • If there's any alcohol solution remaining in the Surface or on the bracket, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your power button cable.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
Kyle Smith
Membro desde: 02/01/21
49.457 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 314
