Ir para o conteúdo principal
Microsoft Surface Pro X Front Camera Replacement
O que você precisa
  1. Microsoft Surface Pro X Front Camera Replacement, Open the kickstand: passo 1, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Open the kickstand: passo 1, imagem 2 %32
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X Front Camera Replacement, Open the SSD and SIM card door: passo 2, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Open the SSD and SIM card door: passo 2, imagem 2 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X Front Camera Replacement, Remove the SSD and SIM card door: passo 3, imagem 1 %32
  4. Microsoft Surface Pro X Front Camera Replacement, Remove the SSD screw: passo 4, imagem 1 %32
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X Front Camera Replacement, Remove the SSD: passo 5, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the SSD: passo 5, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the SSD: passo 5, imagem 3 %32
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. Microsoft Surface Pro X Front Camera Replacement, Tape the screen: passo 6, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Tape the screen: passo 6, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Tape the screen: passo 6, imagem 3 %32
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    • Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  7. Microsoft Surface Pro X Front Camera Replacement, Apply a suction cup to the screen: passo 7, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Apply a suction cup to the screen: passo 7, imagem 2 %32
    • Wear safety glasses during the screen removal procedure in case the glass shatters while you're working.
    • There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to work slowly and be extremely careful while slicing through the adhesive.
    • Place your tablet on your work surface so that the screen is facing up.
    • Apply a suction cup to the screen next to the right speaker grille.
  8. Microsoft Surface Pro X Front Camera Replacement, Secure the tablet: passo 8, imagem 1 %32
    • Place your hand on the screen next to the suction cup to secure the Surface while you lift up the screen.
  9. Microsoft Surface Pro X Front Camera Replacement, Create a gap between the screen and frame: passo 9, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Create a gap between the screen and frame: passo 9, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Create a gap between the screen and frame: passo 9, imagem 3 %32
    • Don't insert the opening pick more than 3 mm while cutting through the adhesive on the right, bottom, and left edge.
    • Lift up on the suction cup to create a gap between the screen and the frame.
    • The gap only needs to be wide enough to slide in an opening pick.
    • Insert an opening pick about 2 mm into the gap. Leave the opening pick in the gap to prevent it from resealing.
  10. Microsoft Surface Pro X Front Camera Replacement, Cut through the screen adhesive: passo 10, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Cut through the screen adhesive: passo 10, imagem 2 %32
    • Insert a second opening pick into the gap between the screen and the frame.
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  11. Microsoft Surface Pro X Front Camera Replacement: passo 11, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 11, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 11, imagem 3 %32
    • Don't insert the pick more than 3 mm while cutting through the screen adhesive on the bottom edge or you may damage delicate components on the screen.
    • Insert a third opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
  12. Microsoft Surface Pro X Front Camera Replacement: passo 12, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 12, imagem 2 %32
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  13. Microsoft Surface Pro X Front Camera Replacement: passo 13, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 13, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 13, imagem 3 %32
    • Insert a fourth opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  14. Microsoft Surface Pro X Front Camera Replacement: passo 14, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 14, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 14, imagem 3 %32
    • Don't insert the opening pick more than 10 mm while cutting through the adhesive on the top edge. Don't insert the pick more than 3 mm near the speaker grille.
    • Insert a fifth opening pick into the top left corner and slide it around the corner toward the top edge.
    • Slide the pick along the top edge of the Surface to cut through the screen adhesive.
  15. Microsoft Surface Pro X Front Camera Replacement, Open the Surface: passo 15, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Open the Surface: passo 15, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Open the Surface: passo 15, imagem 3 %32
    • Do not remove the screen yet. It is still connected to the motherboard by the display cable. Keep the screen as close as possible to the Surface's frame to avoid straining the display cable.
    • Avoid hitting the battery with the screen during this procedure. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Lift up the top edge of the screen so that it is at a 30° angle with the frame.
    • If you encounter any resistance, stop and check that all the adhesive is separated. Use an opening pick to cut through any remaining adhesive.
    • Rotate the screen so that its bottom edge is in the middle of the frame. The screen should be perpendicular to the frame.
    • Rotate the screen 90° so that it is facing down. Place the screen on the frame.
  16. Microsoft Surface Pro X Front Camera Replacement, Remove the display cable shield: passo 16, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the display cable shield: passo 16, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the display cable shield: passo 16, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Insert a tine of a pair of pointed tweezers under the bottom right corner of the display cable shield (where the display cable is oriented down).
    • Lift up the corner to detach it from the screen.
  17. Microsoft Surface Pro X Front Camera Replacement: passo 17, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 17, imagem 2 %32
    • Repeat the previous step for the bottom right corner.
  18. Microsoft Surface Pro X Front Camera Replacement: passo 18, imagem 1 %32
    • Remove the display cable shield from the screen.
    • If the display cable shield isn't completely detached from the screen, pry up additional areas around the edges of the shield.
  19. Microsoft Surface Pro X Front Camera Replacement, Disconnect the screen: passo 19, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Disconnect the screen: passo 19, imagem 2 %32
    • Insert the pointed end of a spudger under the right side of the display cable press connector.
    • Lift up the right side of the press connector to detach it from the display cable socket on the screen.
  20. Microsoft Surface Pro X Front Camera Replacement: passo 20, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 20, imagem 2 %32
    • Repeat the previous step on the left side of the display cable connector to fully disconnect it from the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Microsoft Surface Pro X Front Camera Replacement, Remove the screen: passo 21, imagem 1 %32
    • Remove the screen from the frame.
  22. Microsoft Surface Pro X Front Camera Replacement, Speaker grille information: passo 22, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Speaker grille information: passo 22, imagem 2 %32
    • The left and right speaker grilles may be attached to the Surface's frame or the screen.
    • If you are going to replace a speaker grille that is attached to the frame, follow these steps to remove it:
    • Use an opening pick to cut through the adhesive under the grille.
    • Remove the speaker grille.
    • Repeat for the other speaker grille.
  23. Microsoft Surface Pro X Front Camera Replacement: passo 23, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 23, imagem 2 %32
    • If you are going to replace or transfer a speaker grille that is attached to the screen, follow these steps to remove it:
  24. Microsoft Surface Pro X Front Camera Replacement, Screen adhesive information: passo 24, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Screen adhesive information: passo 24, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Screen adhesive information: passo 24, imagem 3 %32
    • If you are going to replace the screen adhesive, follow these steps:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the adhesive.
    • Use a cotton swab or the flat end of a spudger to scrape away the adhesive.
    • Use a lint-free cloth or coffee filter to wipe away any remaining adhesive.
    • Allow the surface to dry completely before applying replacement adhesive.
    • Apply new adhesive strips or pre-cut adhesive to the frame where the old screen adhesive was located.
  25. Microsoft Surface Pro X Front Camera Replacement, Remove the heat sink sticker: passo 25, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the heat sink sticker: passo 25, imagem 2 %32
    • If you are going to reinstall this sticker during reassembly, try to keep it as intact as possible.
    • Lift up the edge of the heat sink sticker closest to the bottom edge of the Surface.
  26. Microsoft Surface Pro X Front Camera Replacement: passo 26, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 26, imagem 2 %32
    • Lift up the center of the sticker.
  27. Microsoft Surface Pro X Front Camera Replacement: passo 27, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 27, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 27, imagem 3 %32
    • Lift up one side of the sticker attached to the heat sink.
    • Repeat for the other side. The sticker should now be fully detached.
    • Remove the sticker.
  28. Microsoft Surface Pro X Front Camera Replacement, Remove the screw stickers: passo 28, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the screw stickers: passo 28, imagem 2 %32
    • If you are going to reinstall these stickers during reassembly, try to keep them as intact as possible. These stickers can tear easily during removal.
    • Use an opening tool to lift up the edge of one of the small black stickers covering the four screws in the center of the heat sink.
    • You only need to lift the edge enough to grip it with tweezers.
  29. Microsoft Surface Pro X Front Camera Replacement: passo 29, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 29, imagem 2 %32
    • Use a pair of blunt tweezers to remove the sticker covering the heat sink screw.
    • Repeat this process for the other three stickers.
  30. Microsoft Surface Pro X Front Camera Replacement, Remove the heat sink screws: passo 30, imagem 1 %32
    • Remove the 14 screws securing the heat sink:
    • Eight 2.2 mm T3 Torx screws
    • One 2.0 mm T3 Torx screw
    • One 3.2 mm T3 Torx screw
    • Four 2.5 mm T6 screws
  31. Microsoft Surface Pro X Front Camera Replacement, Remove the heat sink: passo 31, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the heat sink: passo 31, imagem 2 %32
    • The heat sink is adhered to the CPU with thermal paste.
    • Insert an opening pick about 2 mm under the heat sink at its bottom edge directly to the left of the display cable.
    • The opening pick should be between the heat sink and the frame surrounding the motherboard.
    • Slide the opening pick to the left toward the heat pipe to detach the heat sink from the CPU.
  32. Microsoft Surface Pro X Front Camera Replacement: passo 32, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 32, imagem 2 %32
    • Swing the bottom edge of the heat sink up so that it is at about a 10° angle with the frame.
  33. Microsoft Surface Pro X Front Camera Replacement: passo 33, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 33, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 33, imagem 3 %32
  34. Microsoft Surface Pro X Front Camera Replacement, Remove the foam adhesive: passo 34, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the foam adhesive: passo 34, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the foam adhesive: passo 34, imagem 3 %32
    • Remove the foam adhesive strip from the Surface.
  35. Microsoft Surface Pro X Front Camera Replacement, Remove the front camera shield: passo 35, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the front camera shield: passo 35, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers under one corner of the shield covering the front camera connector.
    • Lift up the corner to detach it from the frame.
    • If you are going to reuse this shield, try to avoid excessively bending it during removal.
  36. Microsoft Surface Pro X Front Camera Replacement: passo 36, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 36, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 36, imagem 3 %32
    • Repeat the previous step for the other three corners of the shield.
  37. Microsoft Surface Pro X Front Camera Replacement: passo 37, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 37, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 37, imagem 3 %32
    • Slide one tine of a pair of pointed tweezers under the left edge of the shield to further detach it from the frame.
    • Repeat this for the right edge of the shield.
  38. Microsoft Surface Pro X Front Camera Replacement: passo 38, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 38, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 38, imagem 3 %32
    • Slide one tine of a pair of pointed tweezers under the bottom left edge of the shield to further detach it from the frame.
    • Repeat for the bottom right edge.
  39. Microsoft Surface Pro X Front Camera Replacement: passo 39, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 39, imagem 2 %32
    • Insert one tine of a pair of pointed tweezers into the divot in one of the tabs on the bottom edge of the shield.
    • You could also insert the tine under the bottom edge of the shield.
    • Lift up the bottom edge to detach it from the frame.
  40. Microsoft Surface Pro X Front Camera Replacement: passo 40, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 40, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement: passo 40, imagem 3 %32
    • Use a pair of tweezers to lift up the bottom edge of the shield so that it is at a 30° angle with the frame.
    • This will detach the top edge of the shield from the frame.
    • Remove the front camera shield from the frame.
  41. Microsoft Surface Pro X Front Camera Replacement, Remove the camera foam strip: passo 41, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the camera foam strip: passo 41, imagem 2 %32
    • Use a pair of tweezers to remove the foam strip adhered to the front camera, Windows Hello face camera, and left microphone cables.
  42. Microsoft Surface Pro X Front Camera Replacement, Disconnect the front camera: passo 42, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Disconnect the front camera: passo 42, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the front camera press connector from its socket.
  43. Microsoft Surface Pro X Front Camera Replacement, Remove the front-facing sensor bar screws: passo 43, imagem 1 %32
    • Depending on what component you are repairing, different shields on the motherboard may be removed at this point. For example, the shield covering the rear-facing camera connector has been removed in this step's image.
    • Use a T3 Torx screwdriver to remove the eight 5.5 mm screws securing the front-facing sensor bar.
  44. Microsoft Surface Pro X Front Camera Replacement, Dislodge the front-facing sensor bar: passo 44, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Dislodge the front-facing sensor bar: passo 44, imagem 2 %32
    • Insert the pointed end of a spudger into the gap on the right side of the sensor bar between the rightmost screw hole and the adjacent screw hole.
    • Lift up the right side of the sensor bar to dislodge it from the frame.
    • You only need to lift the sensor bar so that it is loose in the frame. Don't try to remove the front sensor bar—it is still attached to the Surface by a cable that connects under the motherboard.
  45. Microsoft Surface Pro X Front Camera Replacement: passo 45, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 45, imagem 2 %32
    • Repeat the last step for the gap in the sensor bar between the second and third screw hole from the left.
    • This gap is where the sensor bar's cable is located.
  46. Microsoft Surface Pro X Front Camera Replacement, Lift the front-facing sensor bar: passo 46, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Lift the front-facing sensor bar: passo 46, imagem 2 %32
    • Lift the sensor bar 90° so that it's perpendicular to the frame.
    • Don't push the sensor bar past 90° and don't rotate it horizontally to avoid damaging the cable connecting it to the motherboard.
  47. Microsoft Surface Pro X Front Camera Replacement, Detach the front camera: passo 47, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Detach the front camera: passo 47, imagem 2 %32
    • The front camera is secured to the frame with light adhesive.
    • Insert the pointed end of a spudger under the top left corner of the front camera.
    • Lift the front camera up to detach it from the frame.
  48. Microsoft Surface Pro X Front Camera Replacement: passo 48, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement: passo 48, imagem 2 %32
    • Insert an opening pick under the top edge of the front camera.
    • Slide the opening pick under the front camera toward its connector to cut through the adhesive.
    • If the adhesive is too difficult to cut through, follow these steps:
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the left edge of the front camera.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
    • Use an opening pick to cut through the adhesive under the front camera.
    • Only apply as much isopropyl alcohol as needed while removing the front camera. Isopropyl alcohol may permanently obscure the front and rear camera lenses, causing blurry photos.
  49. Microsoft Surface Pro X Front Camera Replacement, Remove the front camera: passo 49, imagem 1 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the front camera: passo 49, imagem 2 %32 Microsoft Surface Pro X Front Camera Replacement, Remove the front camera: passo 49, imagem 3 %32
    • Use a pair of blunt tweezers to lift and remove the front camera.
    • During reassembly, make sure to insert the peg on the frame into the hole in the front camera cable.
    • The peg is located to the right of the front camera.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro X Answers community for help.
Kyle Smith
Membro desde: 02/01/21
49.220 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 466
