Ir para o conteúdo principal
Meta Quest 2 Head Strap Replacement
  1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: passo 1, imagem 1 %32 Meta Quest 2 Head Strap Replacement, Remove the facial interface: passo 1, imagem 2 %32
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
    Pergunte ao FixBot
    Comentar
  2. Meta Quest 2 Head Strap Replacement: passo 2, imagem 1 %32 Meta Quest 2 Head Strap Replacement: passo 2, imagem 2 %32
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
    Pergunte ao FixBot
    Comentar
  3. Meta Quest 2 Head Strap Replacement: passo 3, imagem 1 %32
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
    Pergunte ao FixBot
    Comentar
  4. Meta Quest 2 Head Strap Replacement, Unclip the side straps: passo 4, imagem 1 %32 Meta Quest 2 Head Strap Replacement, Unclip the side straps: passo 4, imagem 2 %32 Meta Quest 2 Head Strap Replacement, Unclip the side straps: passo 4, imagem 3 %32
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
    Pergunte ao FixBot
    Comentar
  5. Meta Quest 2 Head Strap Replacement: passo 5, imagem 1 %32 Meta Quest 2 Head Strap Replacement: passo 5, imagem 2 %32
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
    Pergunte ao FixBot
    Comentar
  6. Meta Quest 2 Head Strap Replacement, Remove the top strap: passo 6, imagem 1 %32 Meta Quest 2 Head Strap Replacement, Remove the top strap: passo 6, imagem 2 %32
    • Separate the hook and loop strip on the top strap.
    Pergunte ao FixBot
    Comentar
  7. Meta Quest 2 Head Strap Replacement, Remove the head strap: passo 7, imagem 1 %32 Meta Quest 2 Head Strap Replacement, Remove the head strap: passo 7, imagem 2 %32
    • Unthread the top strap from its bracket.
    • Remove the head strap.
    Pergunte ao FixBot
    Comentar
Conclusão
18 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
337.774 Reputação
Autoria de 851 guias
1Comentário do guia
Merci pour ce tuto qui m'a permis de nettoyer la sangle. En revanche comme elle s'est décollée de ses deux supports, il a fallu la recoller.
Max Grammare - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 232
Últimos 30 dias: 767
Ao todo: 48,073
