Ir para o conteúdo principal
MacBook Pro 15" Touch Bar 2019 Screen Replacement
O que você precisa
  1. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Disable Auto Boot: passo 1, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Disable Auto Boot: passo 1, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Disable Auto Boot: passo 1, imagem 3 %32
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - Responder
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - Responder
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - Responder
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - Responder
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - Responder
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - Responder
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - Responder
    Not able to do that with damaged screen
    richardjgreen - Responder
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - Responder
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - Responder
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - Responder
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - Responder
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - Responder
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - Responder
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - Responder
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - Responder
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - Responder
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - Responder
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - Responder
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - Responder
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - Responder
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - Responder
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - Responder
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - Responder
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - Responder
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
    Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
    Jack - Responder
  2. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Lower Case: passo 2, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Lower Case: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 4.7 mm screws
    • Two 6.6 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    I miss a printable template to leave the screws and removed parts on it for future identification when reassembly, linked maybe with the location in the Macbook, or with the number of the step.
    Juan Ignacio Fernández García - Responder
  3. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 3, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 3, imagem 2 %32
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
    Throw away this suction cup and get another. It just doesn't work! Luckily I had one that does work in my tool kit.
    Greek Taylor - Responder
  4. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 4, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 4, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 4, imagem 3 %32
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 5, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 5, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 5, imagem 3 %32
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 6, imagem 1 %32
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 7, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 7, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 7, imagem 3 %32
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    With the amount of force needed to carefully pull the back panel out, this caused the back panel to scratch the battery. I don't see or hear any expansion, but this still has me concerned.
    gladgura - Responder
    this step must require a lot of force. I tried to pull it with the plastic hookie thing from the ifixit set by hooking it in one of the screw holes — the tip of the hookie thing broke.
    Oleksii Toldaiev - Responder
    The amount of force required for removing the bottom cover is absolutely ridiculous. Almost feels like i'm about to push my MacBook towards the wall the second it comes off.
    Be careful, I ended up breaking 2 grounding pins on the motherboard last time I tried opening my computer up.
    techtalkf - Responder
    PLEASE DON'T PULL!!!
    Instead just gently push with plastic pick from the other side (where vents outputs are) towards the center... Cover will very easily open that way.
    I hope iFixit will correct this step.
    Kamil Roman - Responder
    Came here to share exactly this.
    Robert -
    That's definitely how this step should be done. Thanks!
    VovS -
    If someone has a photo to share regarding this comment, it might be very useful. Thanks.
    Mark Cohen -
    I used a screwdriver at 45 degrees angle and pushed the cover from the hinges, it worked really smooth. I had it close to the corners.
    Martin Lundgren - Responder
    Yeah, definitely don't pull; if you do, wear protective gloves. Mine was stuck so strongly that I just cut my palm quite deep.
    Kirill Chernov (PowerDoge) - Responder
    You would think ifixit would investigate why the last step required them to pull with great force to remove the bottom case lid as the solution.
    It's counter-intuitive to use an excessive method to remove a part.
    There's always an easier way. It's frustrating because you can't see inside.
    Cary B - Responder
    Using the iFixit opening Tool in the hinge opening required close to no force to open.
    Anders Markstrom - Responder
    Ah... after attempting to 'pull' this rear cover off, to no avail, I tried to coax the cover off with a nylon pry tool. MUCH better! iFixIt will do well to amend it's recommendation to 'pull' this cover in any way. All I wanted to do was a little house cleaning and exorcize the dust bunnies that took up residence in my MBP's fans. Today is much quieter. Thank you all for pointing out the obvious.
    P.C. - Responder
  8. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 8, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 8, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 8, imagem 3 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    If I had it all to do over, again, I would blow out the dust with compressed air at this point. During the disassembly, I kept encountering little dust bunnies, and I was very worried that one would get caught in one of the connectors when I plugged everything back up (which wouldn’t get discovered until I put it all back together and tried out all of the components).
    Joe Emenaker - Responder
  9. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Battery Connector: passo 9, imagem 1 %32
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
    • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
    i need a ziff connector flap for step 10
    Gregg Gorin - Responder
  10. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 10, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 10, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 10, imagem 3 %32
    • Peel back any tape covering the battery board data cable connector.
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  11. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 11, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 11, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 12, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 12, imagem 2 %32
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
  13. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 13, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 13, imagem 2 %32
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to install this cable backwards or upside-down. When installed correctly, the white liquid indicator sticker should face up, positioned directly over the battery power connector screw.
    Bonjour, super Tuto, petite question elle sert a quoi cette nappe , et quesqui se passe si elle est pas branché ?
    Jorgio -aigleBrun- - Responder
  14. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 14, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 14, imagem 2 %32
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 15, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 15, imagem 2 %32
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
    Put a little bit of insulating tape over the terminal to be safe.
    Brian Tibbels - Responder
    Agreed - once this is back in place, the system is energized, you run the risk of creating little sparks or worse if metal objects such as cover brackets accidentally touch areas of the logic board.
    bkbkbk - Responder
  16. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Screen: passo 16, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Screen: passo 16, imagem 2 %32
    • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
    • Remove the display board flex cover.
    T3 or T4? I almost damage the screw trying with the T3.
    Christian Polychroniadis - Responder
    I’d say T4 as T3 was definitely too small
    David Smith -
    T3 worked fine!
    Martin - Responder
  17. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 17, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 17, imagem 2 %32
    • Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
    • Remove the display board cable connector bracket.
    Step requires T4 Torx instead of T3 Torx.
    Banana - Responder
    I damaged the screw trying to use a T3. Now I am screwed.
    markshain - Responder
  18. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 18, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 18, imagem 2 %32
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  19. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 19, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 19, imagem 2 %32
    • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
  20. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 20, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 20, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 20, imagem 3 %32
    • Remove both hinge covers.
  21. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 21, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 21, imagem 2 %32
    • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
  22. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 22, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 22, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 22, imagem 3 %32
    • Disconnect all three antenna cables by prying each one straight up from its socket.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  23. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 23, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 23, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 23, imagem 3 %32
    • Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
    • Before reinstalling these screws:
    • Make sure the display board flex cable lies on top of the board, not trapped underneath.
    When reassembling, I found that I had to press in on the outer edge of the antenna (top edge when looking at the picture) at the midpoint between the left 8 screws and the right 8 screws as I screwed the display board screws in. I found that the outside antenna edge would otherwise rub against the display halfway through opening it making a pop sound. Installing this way fixed the problem.
    Robert Scheid - Responder
  24. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 24, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 24, imagem 2 %32
    • Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly.
    I’m having difficulty removing the screws. I’m not sure if the p2 screwdriver is defective but I am now stuck at this step.
    Sonia Carrillo-Ramirez - Responder
    i can only seem to get 2/3 of the screws out
    Leif - Responder
    After giving up, someone else got them all out in about 10 sec using the Apple pentalope screwdriver, specific to Apple.
    Leif - Responder
    The 4 of Pentalobe5 screws in the middle between the two sets of 8 screws also need to be removed.
    pboyle - Responder
    Oooops, wrong, those are 4 of T5 screws in the middle
    pboyle - Responder
    Ok, wrong again. Step 23 is this set of 4 of T5s.
    The step that is missing is removing the set of 4 of T3s that hold the display flexes and springs.
    Sorry about the mess of corrections.
    pboyle - Responder
    We had 4 MBP's that I removed the displays from. On this step, I stripped a 'middle' screw on each side.
    On the second one, I also noticed the middle screws didn't exactly want to easily come loose as I worked my way down the row.
    I wound up putting all screws back in, loosened then tightened the screw on the opposite end, then removed the two in the middle (without issue), then an outside screw going back and forth, until I just had one on each end. Since I had already removed and replaced them, they came out without issue.
    I used this method on the remaining 2 MBP's and had no further issues.
    YMMV and it may not even be necessary. Just seemed removing the screws from end to end put enough pressure on the remaining ones that they were harder to remove. Whereas a patterned removal seemed to resolve that 'issue'.
    fozman2 - Responder
  25. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 25, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 25, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 25, imagem 3 %32
    • Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro.
    • Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
  26. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 26, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 26, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 26, imagem 3 %32
    • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  27. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 27, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 27, imagem 2 %32
    • Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
    Used a T4 here.
    PCICS - Responder
    T4 for me (MBP 2018 15’)
    stephane - Responder
  28. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 28, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 28, imagem 2 %32
    • Use a T8 Torx driver to remove two 4.9 mm screws from each hinge (four screws total).
    • Each hinge has a third screw, which you should leave in place for now.
  29. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 29, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 29, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 29, imagem 3 %32
    • During reassembly, first install the hinge screws without tightening them. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
    • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
    • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
  30. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 30, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 30, imagem 2 %32
    • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
    • Fully open the screen and stand your MacBook Pro up on one side.
  31. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 31, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 31, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 31, imagem 3 %32
    • Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
  32. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 32, imagem 1 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 32, imagem 2 %32 MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 32, imagem 3 %32
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
  33. MacBook Pro 15" Touch Bar 2019 Screen Replacement: passo 33, imagem 1 %32
    • Remove the screen.
Conclusão
17 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
428.122 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
8 comentários
This is such a noob question but how do I marked that”I did this repair”.
Andres Torres - Responder
Do you have a link to a Apple Screen?
Paul - Responder
wo bekommt man denn einen MacBook pro 15 zoll 2019 Display her?
drumma15 - Responder
I followed all of these steps to replace my display and when I put it all back together my Mac would only turn on when it was plugged into the wall. So the new display works fine but it doesn’t seem to recognize the battery at all. Has anyone run into this problem and know what the issue might be?
Jason - Responder
Jason - did you plug the battery connector and cable back in correctly?
Kevin Gill - Responder
I need anew battery connector mine i missing one end maybe …
my screen was replaced by a dealer and I found missing screws and the battery board data cable was glued so hard with a piece of tape when I pulled it out one side showed connection wires the other was nothing ,what don I do when I get a new one (if i can get one?..,,,
Robert Reser - Responder
i am confused by the direction and how difficult such a simple step can stop me cold the battery connector is very fragile and i was not prepared for the outcome
i need help what can i do next. Thanks
Robert Reser
Can this model MacBook Pro 2019 A1990 work as a headless Mac
KrazyKaleb - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 131
Últimos 30 dias: 500
Duração total: 47,921
