Ir para o conteúdo principal
MacBook Pro 14" Late 2023 (M3) Screen Replacement
O que você precisa
  1. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Prepare your MacBook for disassembly: passo 1, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Prepare your MacBook for disassembly: passo 1, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Prepare your MacBook for disassembly: passo 1, imagem 3 %32
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the lower case: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    FixMat
    $31.41
    • Use a P5 pentalobe driver to remove the eight screws securing the lower case:
    • Four 9.2 mm-long screws along the back edge (near the screen hinge)
    • Four 5 mm-long screws along the front edge (near the trackpad)
  3. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Release the sliding clips: passo 3, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Release the sliding clips: passo 3, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Release the sliding clips: passo 3, imagem 3 %32
    • Sliding clips along the back edge of the MacBook secure the lower case. In this step, you'll shift the lower case away from the hinges to free it from these clips.
    • Insert the flat end of a spudger between the lower case and the right screen hinge.
    • Lever your spudger against the hinge to push the lower case away from it.
    • Repeat for the left hinge.
  4. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Lower case information: passo 4, imagem 1 %32
    • After you've released the sliding clips along the back edge, four remaining clips secure the lower case to the frame:
    • Two clips near the cutouts in the frame
    • Two clips near the middle of the lower case
    • As you release the lower case from the frame, you'll hear and feel a distinct "pop" as each of these four clips release.
  5. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Release the right clips: passo 5, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Release the right clips: passo 5, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Release the right clips: passo 5, imagem 3 %32
    • Don't insert your tool deeper than 1 cm (a little less than half an inch) near the front of the speaker cutouts to avoid damaging the speakers.
    • Insert the flat end of your spudger into the front of the cutout in the right side of the frame.
    • Slide your spudger toward the back of the cutout and pry up to release the two right-side clips.
    • Repeat for the left-side speaker cutout to release the two left-side clips.
  6. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the lower case: passo 6, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the lower case: passo 6, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the lower case: passo 6, imagem 3 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the trackpad connector cover: passo 7, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the trackpad connector cover: passo 7, imagem 2 %32
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm-long screws securing the trackpad connector cover.
  8. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the trackpad connector cover: passo 8, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the trackpad connector cover: passo 8, imagem 2 %32
    • Remove the trackpad connector cover.
  9. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the trackpad: passo 9, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the trackpad: passo 9, imagem 2 %32
    • Use the flat end of your spudger to pry up and disconnect the trackpad press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't force it, since a misaligned connector can bend the pins, and cause permanent damage.
  10. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Move the trackpad cable: passo 10, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Move the trackpad cable: passo 10, imagem 2 %32
    • Light adhesive secures the trackpad cable to the battery board.
    • Peel the trackpad cable from the battery board and move it over the front edge of the MacBook.
    • Be careful not to crease or damage the cable.
  11. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Soften the battery data cable adhesive: passo 11, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Soften the battery data cable adhesive: passo 11, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Soften the battery data cable adhesive: passo 11, imagem 3 %32
    • The battery data cable is adhered to the battery board and logic board. In the next few steps, you'll disconnect it, separate its adhesive, and remove it.
    • Heat an iOpener and place it on the battery data cable for 30 seconds to soften its adhesive.
    • If you don't have an iOpener, you can use a hair dryer to lightly heat the cable. Be careful not to overheat the battery, as doing so is a fire hazard.
  12. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Reveal the battery board ZIF connector: passo 12, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Reveal the battery board ZIF connector: passo 12, imagem 2 %32
    • Use your tweezers to peel back the tape covering the battery data cable ZIF connector on the battery board.
  13. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unlatch the ZIF connector: passo 13, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unlatch the ZIF connector: passo 13, imagem 2 %32
    • Use the point of your spudger to flip up the small locking flap on the battery data cable ZIF connector on the battery board.
  14. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the battery board: passo 14, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the battery board: passo 14, imagem 2 %32
    • Use your tweezers to slide the connector straight out of its socket to disconnect it from the battery board.
  15. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Reveal the logic board battery data ZIF connector: passo 15, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Reveal the logic board battery data ZIF connector: passo 15, imagem 2 %32
    • Use your tweezers to peel back the tape covering the battery data cable ZIF connector on the logic board.
  16. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unlatch the ZIF connector: passo 16, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unlatch the ZIF connector: passo 16, imagem 2 %32
    • Use the point of your spudger to flip up the small locking flap on the logic board battery data ZIF connector.
  17. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the logic board battery data cable: passo 17, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the logic board battery data cable: passo 17, imagem 2 %32
    • Use your tweezers to grip the neck of the cable and slide it straight out of its socket to disconnect it from the logic board.
  18. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Separate the battery data cable adhesive: passo 18, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Separate the battery data cable adhesive: passo 18, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Separate the battery data cable adhesive: passo 18, imagem 3 %32
    • The battery data cable is lightly adhered to the battery board and logic board.
    • Slide the tip of an opening pick between the upper section of the battery data cable and the logic board to separate the adhesive.
    • Slide your pick between the lower section of the cable and the silver wide-head screw to separate the remaining adhesive.
  19. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the battery data cable: passo 19, imagem 1 %32
    • Remove the battery data cable.
  20. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the battery connector: passo 20, imagem 1 %32
    • Use a 5IP Torx Plus driver to remove the 3.9 mm-long wide-head screw securing the main battery connector.
  21. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the main power connector: passo 21, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the main power connector: passo 21, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the main power connector: passo 21, imagem 3 %32
    • Use the flat end of your spudger to lift the main battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent breaking it.
    • For added safety, place a non-conductive barrier, such as a piece of a playing card, between the connector and board.
  22. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the antenna cables: passo 22, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the antenna cables: passo 22, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the antenna cables: passo 22, imagem 3 %32
    • Use your 3IP Torx Plus driver to remove the three 2.1 mm-long screws securing the antenna connector cover and bracket.
    • Remove the cover.
  23. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the antenna bar: passo 23, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the antenna bar: passo 23, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the antenna bar: passo 23, imagem 3 %32
    $3.99
    • Insert one arm of your angled tweezers under the metal neck of one of the antenna connectors and gently lift up to disconnect it.
    • Lift only on the metal sections of the connectors. Don't lift the cables themselves.
    • Repeat for the other two antenna connectors.
    • To reconnect antenna cables like these, hold each one in place over its socket and press down with the flat end of your spudger until the connector snaps into place.
  24. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the antenna bar: passo 24, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the antenna bar: passo 24, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the antenna bar: passo 24, imagem 3 %32
    • Use a P2 pentalobe driver to remove the nine 1.6 mm-long screws securing the antenna bar.
    • During reassembly, don't overtighten these screws—ensure they thread in properly, then tighten only until they're snug.
    • Use your 5IP Torx Plus driver to remove the six remaining screws securing the antenna bar:
    • Four 3.2 mm-long screws
    • Two 7.5 mm-long screws
  25. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the antenna bar: passo 25, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the antenna bar: passo 25, imagem 2 %32
    • Remove the antenna bar.
  26. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the screen connector covers: passo 26, imagem 1 %32
    • Use your 3IP Torx Plus driver to remove the four 2.1 mm-long screws securing both screen connector covers.
  27. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the screen connector covers: passo 27, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the screen connector covers: passo 27, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the screen connector covers: passo 27, imagem 3 %32
    • Remove both screen connector covers.
  28. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the screen: passo 28, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the screen: passo 28, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the screen: passo 28, imagem 3 %32
    • Use the flat end of your spudger to pry up and disconnect the three screen press connectors.
  29. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Free the left screen-cable bracket: passo 29, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Free the left screen-cable bracket: passo 29, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Free the left screen-cable bracket: passo 29, imagem 3 %32
    • Use the point of your spudger to pry up the small metal tab on the left screen-cable bracket to unclip it from the frame.
    • Grab the bracket and lift the cables out of their recess in the frame.
  30. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the cable buffer: passo 30, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the cable buffer: passo 30, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the cable buffer: passo 30, imagem 3 %32
    • Black plastic cable buffers help route the screen cables over the frame.
    • Remove the left cable buffer from the frame.
    • The cable buffer might stay stuck in the metal bracket. If so, remove it from the bracket.
  31. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Free the right screen-cable bracket: passo 31, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Free the right screen-cable bracket: passo 31, imagem 2 %32
    • Pry up and free the right screen-cable bracket from the frame, just as you did with the left cables.
    • Remove the cable buffer.
  32. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Screen cable reassembly information: passo 32, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Screen cable reassembly information: passo 32, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Screen cable reassembly information: passo 32, imagem 3 %32
    • During reassembly:
    • Insert the cable buffer into the metal bracket with the buffer's alignment pegs pointing toward the MacBook and closest to the cable's press connector.
    • Align the cable buffer's pegs with its holes in the frame.
    • Press the cable bracket onto the frame, so its metal tabs clip into place.
  33. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the lid angle sensor connector cover: passo 33, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the lid angle sensor connector cover: passo 33, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the lid angle sensor connector cover: passo 33, imagem 3 %32
    • Use your 3IP Torx Plus driver to remove the two 2.1 mm-long screws securing the lid angle sensor connector cover.
    • Remove the cover.
  34. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the lid angle sensor: passo 34, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Disconnect the lid angle sensor: passo 34, imagem 2 %32
    • Use the point of your spudger to pry up and disconnect the lid angle sensor press connector.
  35. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the hinge covers: passo 35, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Unfasten the hinge covers: passo 35, imagem 2 %32
    • Use your 5IP Torx Plus driver to remove the two 2.5 mm‑long screws securing each hinge cover (four screws in total).
  36. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the hinge covers: passo 36, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the hinge covers: passo 36, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the hinge covers: passo 36, imagem 3 %32
    • Use tweezers or your fingers to slide each hinge cover away from the back edge and lift straight up to remove them.
  37. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Loosen the screen hinges: passo 37, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Loosen the screen hinges: passo 37, imagem 2 %32
    • Use a 8IP Torx Plus driver to slightly loosen the six screws securing the screen hinges.
    • Don't remove these screws just yet.
  38. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Open your screen: passo 38, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Open your screen: passo 38, imagem 2 %32
    • Make sure there aren't any cable covers, screws, or other small components that might fall out of your MacBook when you open it.
    • Grab the body of your MacBook and open it to a 90-degree angle.
  39. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Protect your screen: passo 39, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Protect your screen: passo 39, imagem 2 %32
    • If you plan on reusing your screen, apply a couple strips of tape to the lower corners of it to prevent scratches from the frame during removal.
  40. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Lay down the MacBook: passo 40, imagem 1 %32
    • Place a soft cloth on the edge of a table or your work surface.
    • Lay your MacBook keyboard-side down on the edge of your work surface with the screen hanging straight down.
    • Make sure your MacBook doesn't tip over while you work.
  41. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Fully open the screen: passo 41, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Fully open the screen: passo 41, imagem 2 %32
    • Keep the main body secured against your work surface and open the screen as far as it will go.
    • Keep your screen supported with one hand for the next two steps.
  42. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the hinge screws: passo 42, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the hinge screws: passo 42, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the hinge screws: passo 42, imagem 3 %32
    • Use your 8IP Torx Plus driver to remove the six 5.2 mm-long screws securing the screen hinges.
  43. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Lower the screen: passo 43, imagem 1 %32
    • Slowly begin to close the screen so it hangs straight down again.
  44. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the screen: passo 44, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the screen: passo 44, imagem 2 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Remove the screen: passo 44, imagem 3 %32
    • Lift the left hinge up and out of its recess in the frame.
    • Be careful not to touch the hinge to any connectors or components on the logic board.
    • Repeat for the right hinge.
    • Remove the screen.
  45. MacBook Pro 14" Late 2023 (M3) Screen Replacement, Reassembly information: passo 45, imagem 1 %32 MacBook Pro 14" Late 2023 (M3) Screen Replacement, Reassembly information: passo 45, imagem 2 %32
    • During reassembly, follow these instructions to align your screen hinges:
    • If you have blue threadlocker, apply a drop to each screw's threads to prevent them from loosening over time.
    • Install the hinge screws without fully tightening them. Center the hinges and check for gaps or rubbing on either side.
    • Fully tighten the hinge screws.
    • If your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
Conclusão
3 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
95.626 Reputação
Autoria de 466 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 15.795 guias
3Comentários do guia
Thank you Clay I followed your guide and was able to do the repair I did my repair through the Apple Self Service Program I ended up with no screen artifacts. Check out the video I made MacBook Pro M3 2023 A2918 Screen Replacement
Mark D Schlossman - Responder
So is the Apple system configuration process software? or is a phone call to Apple support for them to do the configuration? Or is it a phone home type of process.
Lawrence -
Visual Artifact issue fixed for OS 15.2+, I believe. Ordered a 3rd party screen that was compatible with Sequoia 15.2 and above with no visual artifacts and no system configuration needed.
scentaur - Responder
Comentar
Visualizações:
Últimas 24 horas: 25
Últimos 7 dias: 137
Últimos 30 dias: 505
Ao todo: 8,945
