Ir para o conteúdo principal
Display issues on MacBook Pro 14" M1 - Shadows on Screen
Hi, I replaced the logic board on my macbook pro 14 M1 and now it shows shadows on the top side of the screen besides the notch. I tried with different displays and same problem. Does anyone have the same issue?
Esta é uma boa pergunta?
Pontuação 10
1 comentário
Its fixed for me with the last update. Just me?
por
Adicionar um comentário
14 respostas
Solução escolhida
These new MacBooks have mini LED type displays, and have more dimming zones (small areas where the backlight can be regulated independent of other areas). I am thinking it's possible there's something up with the backlight related to the new board.
I am not super familiar with the boards on these because they are so new and I would be much more likely to think this is related to the display. But if it is occurring with different displays, that seems to rule that out. I suppose its possible there's something to this related to pairing to the logic board, as Apple is wont to do. But I have no practical evidence for that.
UPDATE 10/22/2022:
In light of some info coming in now that Apple's Self Repair is live for MacBooks, it appears this is related to "Calibration" performed by Apple. Basically, the screen (and Lid Angle Sensor) are paired to the logic board, which enables whatever Mini-LED magic the display is doing. So if your display and logic board are not paired together with Apple's software, you're likely to get this issue.
I continue to be perplexed as to why this serialized pairing is necessary for proper function, but that's a whole different discussion.
UPDATE 11/26/2022:
As info continues to come in about repairing these models, here's the latest on what the independent repair community is finding. The TCON Board on these is underneath the bezel at the bottom of the display rather than attached to the cables dangling from the screen.
If you're replacing the display and not using Apple's Self Repair program where System Configuration is accessible, there are two ICs (Integrated Circuits, or more commonly - chips) that need to be transplanted from the original TCON board to the new one to maintain the configuration. This not really a viable fix for most DIYers, since it requires the skills and tools desolder and solder BGA components, but it's how people outside Apple's authorized repair ecosystem are resolving this issue. I will try and find some pictures for reference, but I don't have any of these in my spare parts bin yet.
UPDATE 12/13/2024: The release of macOS Sequoia 15.2 has resolved this issue as long as the screen is an authentic Apple display. The swapping of the integrated circuits is no longer necessary to remove these artifacts. If they are present on your device after a screen replacement, be certain that it is running at least this version of the operating system.
Esta resposta foi útil?
Pontuação 16
14 comentários:
@danj Oh! Seems to support this hypothesis. Thanks for pointing that out. I am willing to bet this is an issue with something on the board related to the backlight dimming zones, since they seem to be of uniform size.
I actually didn't even realize these new displays don't have a T-CON board attached until I looked at the schematics for this post and then I had to derail myself from going down a rabbit hole because I have actual work to do today Haha.
I only worked on a small handful of these before my day job lost our AASP status and I didn't even think about this because I was looking for liquid damage on all of those. But this is going to be my afternoon project once I finish this wiki page I've been working on.
por
I have the exact same issue on my macbook pro 14"
can you tell me how i can fix it.
por
Hello, I've got exactly the same issue.
I bought my Macbook as a used one and this issue came with it. However, it has only 6 cycle counts on the battery. I am doubting that the display was ever changed, as it looks like a new one, no marks on the screws, still under Apple's warranty, hardware support etc. My questions is that an AASP would repair this under Apple warrranty? Is it possible that the screen was never changed and this issue appeared on its original screen?
Thanks and I much appreciate your response. Kind regards, Mark.
por
@Mark Toro I would wager this is still the issue. If you bought it used and it is still under warranty I would question why it was sold in the first place. If it was under warranty, why wouldn't the original owner have taken it to Apple themselves?
Have you opened up the machine? Or the screw assessment is based on exterior screws?
I don't work in AASP land anymore so I don't have the experience to tell you for sure, it's probably possible if there is a failure of the TCON board. It's still worth taking it to Apple, or an AASP. But I will caution that they may refuse service. The diagnostics they run may tell them that it can't verify the screen's authenticity. In which case they should do additional investigation. But they may not depending on the person. Worst case scenario you can replace the display yourself under Apples Self Repair program. But it's wouldn't be covered by warranty. And the part is not cheap.
por
Exibir mais 9 comentários
I bought display (including lid sensor) at selfservicerepair.com (SPOT) and replaced it. After replacement, I found these artifacts. There was information in the order: after installation, contact support and complete the system configuration. Following the support instructions, I turned off the macbook, then turned it on to the diagnostic state (pressed the power button for 10 seconds until the disk and gear icons appeared). After that, I pressed the command+d, this launched the diagnostic process. As far as I understand, at this moment, support remotely connects to the MacBook and calibrates the lid sensor. When the progress bar passed about 30%, support asked to close the lid. Apparently magic happened at that moment. After a couple of minutes, the macbook made a power-up sound, I opened the lid, chose to restart, and booted up in normal mode. After entering, the artifacts disappeared. There is a chat transcript with support. I can upload if anyone is interested
Pontuação 6
20 comentários:
do you contact with Apple Support or selfservicerepair.com support?
por
@i.wawuwe - Unless you buy the Apple sold display using the new self repair offering you can’t access the needed software tool from there severs. So replacing display’s either used or otherwise other than directly from Apple is presently not possible!
por
@i.wawuwe selfservicerepair.com. And asked also could they provide calibration service in case if I’d bought display from 3rd party seller (eBay, etc). The answer was “no”
por
@oxydester - Apple now offers self service repair on this system so when you order the replacement display you will then gain access to the special calibration tool it will only work with the display Apple sells via the internet on this series which has controllable local dimming zones.
por
Has anyone ELSE (who is NOT using Apple's Self Repair Program) confirmed this method of calibration that @oxydester posted? Did it fix the distorted colors/shading/shapes on your LCD? Thanks in advance.
por
Exibir mais 15 comentários
hello everyone, I also suffered from the artifact problem for a long time following a screen change.....but!! after updating to version 15.2 beta the problem disappeared! (true tone didn't come back though)
UPDATE after 2 hours : So it's not perfect, there are still some small lighting bugs depending on the content displayed, but it's much better than before and there's no longer this horrible artifact at the top of the screen... let's hope that Apple continues in this direction and authorizes complete calibration with the return of true tone.
before / after update on 15.2 beta
Update 12/11 : do not revert to stable version… I thought maybe the update had reset or done something to the screen chip but not
UPDATE 4/10 : macOS 26 has fully configured the screen in the repair assistant : True Tone works, no more low-light artifact
Pontuação 4
7 comentários:
Thank you for posting this, it works!
por
This is a great find. Updated to 15.2 beta and artifacts are gone.
I wish there was a similar fix for screen angle detector calibration.
por
@bellekci So for my part it's a transplant of a motherboard from a new chassis (therefore new angle detector) and well during the update to 15.1 when I started the diagnostic mode, it gave me suggested the calibration (it asks you to close the screen until you hear the start gong)... maybe I was lucky
por
I am at 15.2 as you suggested and I tried the diagnostic mode afterwards and got no session found.
por
@bellekci I believe that like on iPhone, it is impossible to configure a part in beta version... for my part it was in stable version 15.1, and the procedure was launched just before it displayed "waiting for a session"
I haven't tried it yet but I would like to return to a stable version but I'm afraid that the artifact will be back....
Update : do not revert to stable version…
por
Exibir mais 2 comentários
I got same issues on my Macbook Pro 14"
Pontuação 3
3 comentários:
Eljohn - the artifacts would be along the top in rectangular form. Your images don’t show that. What you maybe seeing is a shadow area along the sides if I follow what you are seeing. This is a different issue. Often times it’s the dispersion sheets curling from heat or wetness (humidity).
por
I've same problem that Eljon faced. I don't if that's normal? please explain
Shadow on the edges
por
@m.m709 - The issue is the light dispersion sheets curling from heat or wetness (humidity).
Visit an Apple Store to see if they will do a warranty exception if you haven’t caused excessive heat to humidity to your system. Don’t hold your breath 😩
por
Hi
I have the same exact issue - which happened after replacing the screen of my MacBook Pro 2021 - Is there any solution? or advice on how to fix this issue ?
Thanks
Pontuação 2
1 comentário:
@mohaalshawamreh no solution if you bought it somewhere other than selfservicerepair.com
por
GUYYYYSSS
Today 11/12/2024
Update to the latest MacOS Sequoia 15.2 Beta 3 and you will have NO ARTIFACTS AT ALL
I bought from ebay an Macbook 2021 M1 Max with this issue and i updated it to this version i all the artifacts disappeared
Before installing the update
PS: on 15.1 i still had the artifacts, just on the 15.2 Beta 3 the artifacts were gone
After
Update 07/07/2025
i decided to update to de developer Beta of Tahoe and
TRUE TONE CAME BACK!!!!
Pontuação 2
2 comentários:
Hey Carlos, which exact Macbook model do you own? And did u use a 3rd party screen or original screen?
por
@arjuncrasto Hi Arjun, i have a 14´ Macbook pro M1 Max, bought it from ebay, with the defective screen(with the LCD issue) i just updated it and now it is brand new
por
I have the same problem with a 14” MacBook Pro. I changed the screen with another original the same problem in the apple document they say that a configuration system is needed.
Pontuação 1
3 comentários:
It's true system configuration is necessary after the repair. Actually for all MacBook Pro models 2018 and newer when the display is replaced and Airs I think 2019 and newer (for some reason I think the 2018 is exempt even though it has a T2 chip).
This could in theory explain an issue with installing another screen without running system config. But I think I have also seen this issue on the original screen no replacement.
por
To clarify, the 2018/20 MacBook Pro systems can use used displays as they hold the calibration setting within the display. You can’t use virgin displays outside of Apple supplied units as you need access to the calibration tool.
The newer M 14”/16” series and onward uses a newer display technology with local dimming. These require calibration and you can’t use used displays as Apple now serializes the display to the given systems main logic board.
And lastly, the newer M series 13” and Air are serialized displays so you can’t use used displays either.
por
just read somewhere camera linked as well ,hits just keep on coming,
por
not touched my m1 macbook pro 14 or changed anything to display, I do get those exact shadows on screen. I am out of warranty by 1months and can someone suggest what I should now?
Pontuação 0
1 comentário:
@vindkadtt - I would still give Apple a try. They often slide on a month.
Even if it’s not covered you have no choice ☹️Apple has made repairs much harder.
por
Do you know if it's possible to come to the authorised apple service and pay them to calibrate the self-replaced screen from eBay? I don't care about the warranty terms any more or anything else like this, it's all gone. I just wish to get rid of these artefacts. I have already invested in this "new" used replacement so much money that I don't care about paying some extra for calibration...but if I need to buy the official replacement again just to avoid these shady things, that makes it economically not reasonable at all...will just adapt how to live with these until better days.
Update (02/06/2023)
By the way, changing the desktop wallpaper to solid black helps not to see these on the desktop. It's visible a bit in the browser window and so on, but that's already a bit better.
Pontuação 0
2 comentários:
Sadly, Apple monitors the serial numbers entered, the AASP would risk losing there status and as they violated the contract they could be sued!
So no, they won’t do it.
por
if you buy two macbooks in store, swap screeens and ask selfservice to calibrate, they will tell you that these are not verified apple parts. no joke, i actually checked that.
por
Does anyone know if this applies to the 16" 2021 as well?
Pontuação 0
3 comentários:
The 2021 16” also offers local dimming zones as such you can’t swap out the display assembly without calibration! To get access to the tool you need to buy the part directly from Apple.
Here’s a good article on it: In Apple's 2021 MacBook Pros, Mini-LED Panels Come Into the (Bright) Light
por
if you swap 16" screen there will be no artifacts, but no true tone. if you swap LCD only, to keep TrueTone you need to move Parade + SPI or transfer display SN from old SPI to new one.
por
Hi, are saying that if you replace the 16 inch model screen you only lose true and not have artefacts issues? Is that true? I though it affects all models regardless
por
This is the second time the screen has been replaced under warranty
Pontuação 0
2 comentários:
@liortahan - Without more details this doesn’t offer anything!
Why was the display replaced before? What does it need to be replaced again?
You show a bit of the diagnostic screen which doesn’t tell us what are the failing error codes so we could even try to look them up in English as we don’t speak Thai (if I guessed correctly).
por
There is nothing wrong with your screen, mine looks the same. If you look at angle the edges always look blue, even straight on the edges are slightly darker. It's just as a result of the backlight.
por
This happened to me twice. The first time it went away on it's own. This most recent time I had updated to 14.7.2, but also had my laptop fall off the couch, so I didn't know what it could have been. After seeing similar issues online, I figured it must be software related.
I updated to 15.2 (reluctantly!) and it's now fixed. I updated my computer the other day, and I did it with my computer connected to an external display and with the laptop closed, so I wonder if that might have contributed to this happening! It appears that the calibration process might happen during software updates, and maybe if your lid it closed while you update, the calibration process doesn't happen properly.
Pontuação 0
Greetings, how are you? Does the system update also work for a board with a donated screen? It really had an impeccable chassis and I was able to get a motherboard, but as soon as it tries to start, it restarts and you can't see the backlight, then I searched and saw about the integrated ones that have to be changed, but now reading this about the operating system it gives me a a little hope, but I don't know if this update also requests donated screens, thank you.
Pontuação 0
@flannelist
In the photo below, the board and components that as far as I see need to be transferred from the old board to the new one.
Pontuação -1
6 comentários:
@oxydester - This is clearly way to advanced a project for most people. Without the proper tools and skills you’ll end up with two dead displays😟
While I’m not happy with Apples lockdown approach we have really no options. They paint them selves as Green, yet reuse of displays from dead logic board systems is not possible to save one from two.
por
@danj - There is an option to return the damaged display for a partial refund.
p.s. fortunately we have skill to replace chips. Now are waiting for someone who will agree to this
por
@oxydester - Sorry Apple doesn’t offer a refund for the old display. They do take the parts back for disposal. This is their effort of prevent refurbishment by other parties. All they do is grind all of the parts down no reuse of any kind!
Even the best skilled person will have a bad day so in the long haul it’s not worth it unless you do quite a few a day to keep the skills sharp.
por
@danj sorry, I messed up. Not apple. Selfservicerepair.com. I bought display from them and they offer refund in case of return old display.
por
@oxydester - That’s Apples self repair program. The rebate is not that much when you compare with an Apple depot repair cost. Sadly it’s the only game in town 😩
I do recommend that approach as being the smarter!
por
Exibir mais 1 comentário
Adicionar a sua resposta
Irving Rodriguez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 131
Últimos 30 dias: 616
Ao todo: 26,040
