Ir para o conteúdo principal
MacBook Air 13" Early 2014 Heat Sink Replacement
O que você precisa
  1. MacBook Air 13" Early 2014 Heat Sink Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
    allison - Responder
    Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
    bwgvanderveer - Responder
    I thought I could replace my 256 Gb SSD with 512? regards
    ola m - Responder
    Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
    andrew - Responder
    It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
    Larry Smith - Responder
    tell a model that was not inferior to the speed of the one in the laptop.
    Thank you
    ilyabuhov - Responder
    Do i need to order tools separately to replace the battery i just ordered?
    anne uhlir - Responder
    im looking for a Logic Board for a
    Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
    Any help is appreciated.
    Jamie Comstock - Responder
    P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
    William Skinner - Responder
    I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
    eric -
    Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
    Dennis Eaton - Responder
    My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
    Pennny Beach - Responder
    The supplied kit and instructions worked perfectly!
    Nikolay Andreev - Responder
    Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
    joemoog - Responder
    Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
    Merci pour votre aide.
    chicco33 - Responder
    oui, vous aurez besoin d’un adaptateur, pour completez le changement.
    Dan -
    The tool kit should include tweezers for re-inserting the battery connector.
    Andre Clement - Responder
    P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
    michaelquinnell - Responder
    Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
    Thomas Lewis - Responder
    To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
    Pentalobe 1.2(mm)
    also
    P4 = 0.8
    P6 = 1.5
    Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
    nijafe -
    I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
    Sean Love - Responder
    Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
    John Brennand - Responder
    Just installed on a MacBookAir6,2 (13-inch, Early 2014).
    Was very easy.
    New iFixit battery looks great so far:
    Full Charge Capacity (mAh): 4922 -> 7333
    Jonathan Cross - Responder
    can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
    hawk_lpc -
    Screw P5 Pentalobe 1.2
    Mario Verlent - Responder
    Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
    Joel Sebastian - Responder
    Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
    Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
    Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
    Donald Niamath - Responder
    Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
    Amir Zaidi - Responder
    Thank you very much for the guilde. My MBA2011 had reborn !
    Billy Wong - Responder
    Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
    See great advice: Electrostatic Discharge
    Fletcher Cole - Responder
    … und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
    ... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
    Blatt - Responder
    Fot All People ha ing trouble finding their SSD
    DONT PRESS CMD +R + POWER
    instead press
    OPTION+CMD+R +POWER
    I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
    Albert - Responder
    IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
    This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
    Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
    Good luck. - Eric J.
    ECJohansen - Responder
    On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
    Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
    Rich Garella - Responder
    shrhh - Responder
    Is it possible to change an upper case with a german keyboard for an english one?
    Rogerio Pefi - Responder
    if you are intending to change it to British layout you don't need to change the keyboard at all, just the keys, buy either a set of a1466 key caps ( I assume you have a 2017 MacBook Air?) or a cheap a1466 keyboard (can even be a broken one), remove the keys that are different and replace them with the other keycaps, and then set the macbook's language to British and you are set
    Kai Mcpherson -
  2. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
    Jeannie Crowley - Responder
    To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
    nijafe -
    When closing this back up make sure that the antenna cable is tucked away neatly
    Gabriel - Responder
    So this is a legit back cover for MacBook Air?
    ASHANTI SMITH - Responder
    What about disconnecting the battery?
    Luke - Responder
    I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
    Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
    Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
    Lance Berc - Responder
    As noted by others, be a bit careful removing the lower case. There is an oblong black plastic locator very near the center of the lower case. Unless you gently pry the bottom cover pretty much straight up, you will break the ends off of the locater.
    BobY - Responder
    Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
    Nexus - Responder
    The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
    The driver for the screws inside the case are named, as "T5".
    Jim Henderson - Responder
  3. MacBook Air 13" Early 2014 Heat Sink Replacement, Battery Connector: passo 3, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement, Battery Connector: passo 3, imagem 2 %32
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
    after disconnect the battery, press and hold 5*10 seconds the powerbutton on your keyboard to unload the capacitors
    Marcel - Responder
    how does a person put the battery connector back in?- that is the only thing i’m afraid of touching after putting new fan in.
    a smith - Responder
    I found it was possible to put the battery connector back in as the last step, however having gone through that and found it to be a little challenging, I would actually recommend attaching the battery connector before screwing back in the bracket. That way you’ll put a lot less stress on the connector cable.
    Kevin Epstein -
    When you are plugging the connector back in, make sure to give it some extra pressure to make sure it is all the way in. It may look like it’s in but needs to be pushed harder!
    Connor Dougherty - Responder
    After disconnecting the power, you may skip directly to step 18. I don’t know why someone would think it necessary to disconnect all the other stuff. There is no need whatsoever to do so. The more things you disconnect, the more things you risk damaging. Many of the parts in steps 4 through 17 are quite delicate, and easy damaged.
    The screw in step 18 is easily accessed without removing even the rubber gasket. Regarding step 18, only remove the screw. (This screw is rather long, with long threads.)
    It’s helpful to take photographs of this area before removing the screw, so you’ll know what it’s supposed to look like when you put it back together.
    AnnoniMoose - Responder
    There are only 16 steps in this repair process. I wonder whether you are commenting on a different repair.
    Gyandev -
    What if your battery doesn’t have that clear tab?
    Carla Tisdale - Responder
    Yep, exactly the issue that I have
    Martin Adams -
    Unscrew the battery first, then let the cable flex out a little. Use a spudger or small pick to push the connector out from the board.
    Nathan -
    Where can i buy the battery connector?
    Bernie-Khay Dabu - Responder
    Macbook air 2015 battery connector where can I purchase?
    Connector socket came off, can I just glue it into place?
    Lisa Mac - Responder
  4. MacBook Air 13" Early 2014 Heat Sink Replacement, I/O Board Cable: passo 4, imagem 1 %32
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
    When putting this back together, be careful you don’t flip I/O board cable. It will fit, but the computer will not work. You’ll know it’s wrong if it covers the fan.
    Tito Jankowski - Responder
  5. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 5, imagem 1 %32
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
    the instructions should really indicate you’re only disconnecting one end of the cable. you disconnect the other end in step 6.
    Tom O'Leary - Responder
    Bonjour,quand je retire la nappe de la carte E/S , l’éclairage de l’écran s’affiche mais quand je remets la nappe de la carte E/S ,j’ai un écran noir.J’attends votre réponse.Cordialement.
    Halston Halston - Responder
    I literally did this wrong just like you warned not to! Very easy to do…
    Edward Mills - Responder
    I watched the video twice and went really slowly through steps and it works!!! It was a little scary but we got through it! Thanks so much!!
    Alexae Visel - Responder
  6. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 6, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 6, imagem 2 %32
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
    pour le remontage
    de mon coté tout c’est bien passé, il faut juste bien vérifier la nappe de la carte E/S soit à l’endroit, car sinon l’ordinateur refuse de démarrer ( se référer à la photo du coup )
    matthiasf40 - Responder
    A client was careless and used a fingernail to pry up the cable in one pull. It pulled the socket right off the logic board.
    w98fxr - Responder
  7. MacBook Air 13" Early 2014 Heat Sink Replacement, Fan: passo 7, imagem 1 %32
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    I did not find it necessary to loosed the retainer flap, unplug the ribbon cable from it's socket, or remove the fan. After removing the fan screws in Step 9, the fan was loose enough that it can be slightly moved to the side. I felt that loosening the retaining flap and removing the fan adds unnecessary potential to damage something. To the contrary, if you bump the fan while it's plugged in, you might damage the ribbon cable.
    Michael Kruger - Responder
    My retaining flap broke instantly when lifting up with the spudger. Is that normal or possible to fix?
    Cameron Lawrence - Responder
    Similar problem, but with the microphone flap. Did you manage to fix it or get it back in?
    Edwin -
    I've performed many repairs on 13" MacBook Airs ('MBA's), including two heat sink compound 're-dos' just today (on a 2014 13" and a 2015 13").
    It is not necessary to remove the I/O Board to take out the heatsink. And I've done it both ways - its way easier if you leave the I/O board in place. Here's why: removing the I/O board requires dis -and re-connecting two extremely delicate connectors as well as several cables that are really tricky to get back in place, all critical connections. If you aren't experienced with this kind of work, its taxing.
    Instead, once you remove the flat I/O cable, remove the 3 screws holding in the fan and the two hinge screws securing the antenna cable guide. Now the screw securing the tip of the 'radiator' end of the heat sink will be pretty easy to access. The detached fan can moved (and you don't need /want to move it much!) to disengage the rubber shroud where it goes under the fan and gently guide the 'radiator' out.
    clinton - Responder
  8. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 8, imagem 1 %32
    • Peel the rubber gasket off the adhesive on the top of the fan.
    In my case the adhesive had already come undone through normal use.
    lol same thing for me.
    h_man08 - Responder
  9. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 9, imagem 1 %32
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
    I found it easier to do step 11 before this one.
    maccentric - Responder
    During reassembly don’t forget the ribbon cable.
    Rhiannon Orizaga - Responder
  10. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 10, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 10, imagem 2 %32
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
    It is a lot easier to insert the flat ribbon in its socket before placing the fan back in place. BUT DO NOT YET FLIP BACK the retaining flap, until you have seated and screwed the fan. This way in case you pull on the fan by mistake, the flat ribbon is free to come out, otherwise you may tear it.
    Rany - Responder
    I did not find it necessary to remove the fan or unplug the ribbon cable from it's socket. After removing the fan screws, the fan was loose enough that it can be slightly moved to the side. I felt that loosening the retaining flap and removing the fan adds unnecessary potential to damage something. To the contrary, if you bump the fan while it's plugged in, you might damage the ribbon cable.
    If you are careful with the ribbon cable, there is no need to remove it, the fan will swing out of the way enough. I applied a small amount of sticky tape over the connector to keep it in place, just in case!
    Damian Holland - Responder
  11. MacBook Air 13" Early 2014 Heat Sink Replacement, I/O Board: passo 11, imagem 1 %32
    • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
    It requires a somewhat concerning amount of force. I mean, be careful, but I pulled just slightly more than I was comfortable with (for the first time)
    Elijah Kennedy - Responder
  12. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 12, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 12, imagem 2 %32
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    Steps 12 through 16 are not really necessary; you can easily de-route the necessary cables without removing the I/O board. Likewise with reassembly.
  13. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 13, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 13, imagem 2 %32
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    When following these steps in the reverse order to reassemble the machine, I found it much easier to insert the ribbon cable before inserting the I/O board into it's place and installing the screw (Step 14). This adds potential for any sudden movement to damage the ribbon cable, so gentle care must be exercised.
    Tried doing both ways when reassembling but the ribbon cable is so crimped that it won’t feed through the socket anymore. Not sure how to get it through else replace cable or run without a microphone.
    Reynold Gonsalves - Responder
    I managed to get the little flap out when trying to push it back in. Now I can’t get the microphone to work…
    Edwin - Responder
    I removed it And I can’t get it to stay connected now that I am putting it back together? How does it stick to the gold part???
    jelainec1 - Responder
    This was an extremely sensitive part to remove. The sticky bit didn’t seem to want to let go, and there isn’t really anywhere to ‘grab’ the cable from the ZIF socket. Ended up using the sticky ‘cover’ portion. Just be carefully wiggling and cajoling the cable free. (2013 model)
    Thomas Keats - Responder
  14. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 14, imagem 1 %32
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    I also noticed that the ribbon cable has a “tab” of extra ribbon above it that was hard to see in the pictures.
    This comment was extremely helpful as the connection on the cable end is difficult to see. The tab is for pulling the connector into place.
    jheller105 -
  15. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 15, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 15, imagem 2 %32
    • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
  16. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 16, imagem 1 %32
    • Lift the I/O board from the logic board side and pull it free from the upper case.
    • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
    I didn't actually need to remove the IO board, it's enough to remove the screw to let it loose. Therefore also step 12 and 13 are useless.
    Emilio - Responder
    THANK YOU. Was able to push the camera cable under the io board without removing it.
    samdaman91 -
    OAT YEAH! Followed this guide to replace my Macbook Air 2014 I/O board step-by-step (thx Jeff Suovanen and contributors) with no probs…workie workie now! FYI it had stopped charging…I tried a new charger, new battery, and finally this I/O board…
    Just take your time and make sure you have the torx screw + adapter bits and spudger as they do not come with the I/O board (I had them leftover from a previous iFixit battery swap).
    Kent O - Responder
    When replacing the I/O board, be careful to gently lift the microphone ribbon cable out of the way. If you forget, you’ll have to remove the I/O board to get at it again…
    VikingShips - Responder
  17. MacBook Air 13" Early 2014 Heat Sink Replacement, Heat Sink: passo 17, imagem 1 %32
    • Remove the two 4.9 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
    Do i need a security torx for this one or will a regular T8 do?
    boop. - Responder
  18. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 18, imagem 1 %32
    • Push the antenna cable retainer out of the way and remove the single 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
  19. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 19, imagem 1 %32
    • Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
  20. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 20, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 20, imagem 2 %32
    • If the heat sink seems to be stuck to the logic board after removing all five screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
    • Remove the heat sink from the logic board.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  21. MacBook Air 13" Early 2014 Heat Sink Replacement: passo 21, imagem 1 %32 MacBook Air 13" Early 2014 Heat Sink Replacement: passo 21, imagem 2 %32
    • When reassembling your device, attach the gasket to the heat sink as shown.
    • The tail of the gasket should fit into the notch in the heat sink, it should not end up underneath the heat sink tab that will rest on the logic board.
    • Be sure the small post molded into the rubber gasket mates with the hole cut into the upper right corner of the logic board.
    Removing old thermal paste should be done carefully with a cotton swab and 100% isopropyl alcohol. Pure alcohol evaporates quickly, reducing the risk of residue. Applying thermal paste is kind of an art. You want to apply a single drop to square components, and a thin line to longer rectangular components. The thermal paste should be centered, so that it spreads out by itself, to cover the surfaces. Do not attempt to spread the paste by hand. Instead, let it spread out on its own, under the pressure of the heat sink. You can try watching a YouTube video to see how this is done.
Conclusão
13 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
439.286 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.416 guias
Um comentário
Ho fatto tutto il procedimento con il fiato sospeso e alla fine ero convinto di aver rotto qualcosa ma non era vero. Tutto è andato bene la laptop non è esplosa. Io dovevo solo rimuovere il heatsink per sostituire la pasta termica, Dio mio quante viti da smontare, pensavo di arrivare direttamente e scoperchiare la CPU. Grazie.
Andres Valdevit - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 34
Últimos 30 dias: 68
Duração total: 16,330
