Ir para o conteúdo principal
Logitech G435 Ear Pads Replacement
  1. Logitech G435 Ear Pads Replacement, Prepare the headset for disassembly: passo 1, imagem 1 %32
    • Power off the headset and unplug all cables.
    Pergunte ao FixBot
    Comentar
  2. Logitech G435 Ear Pads Replacement, Remove the ear pads: passo 2, imagem 1 %32 Logitech G435 Ear Pads Replacement, Remove the ear pads: passo 2, imagem 2 %32 Logitech G435 Ear Pads Replacement, Remove the ear pads: passo 2, imagem 3 %32
    • If you're replacing the headset battery, you only need to remove the left ear pad (the side containing the power button).
    • With one hand, firmly hold an ear cup steady.
    • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
    • Repeat the process to remove the other ear pad.
    Pergunte ao FixBot
    Comentar
  3. Logitech G435 Ear Pads Replacement, Install the ear pad: passo 3, imagem 1 %32 Logitech G435 Ear Pads Replacement, Install the ear pad: passo 3, imagem 2 %32 Logitech G435 Ear Pads Replacement, Install the ear pad: passo 3, imagem 3 %32
    • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
    • Orient the ear pad so the wider part is at the top.
    • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
    • The ear pad has a clear plastic stiffener. This piece should not slip over the ear cup lip.
    Pergunte ao FixBot
    Comentar
  4. Logitech G435 Ear Pads Replacement: passo 4, imagem 1 %32 Logitech G435 Ear Pads Replacement: passo 4, imagem 2 %32
    • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
    • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
    Pergunte ao FixBot
    Comentar
Conclusão
Arthur Shi
Membro desde: 01/03/18
337.641 Reputação
Autoria de 851 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 22
Últimos 7 dias: 113
Últimos 30 dias: 597
Ao todo: 2,011
