Introdução
There are a few reasons why you might want to replace the battery in your Lenovo Yoga 910-13IKB. Over time, batteries degrade and their ability to hold a charge diminishes, resulting in low battery life that might not be enough to get you through the day. In rare cases, it is possible for the battery to expand and push against the chassis and other components of the laptop. For users who wish to replace the battery on their device, Lenovo has made it easy to do so, only requiring a Phillips screwdriver.
O que você precisa
Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
Remove the back panel from the device exposing the components.
For optimal performance, after completing this guide, calibrate your newly installed battery.
9 outras pessoas executaram este guia.
4 comentários
You're right! I fixed the guide to reflect this.
Easy battery replacement on Yoga 910. The repair kit contains a variety of small repair tools and is very nice for the price. Found some small metallic discs when disassembled; they were spacers for the screws in the back casing and superglued them back to the casing before reassembly.
