Ir para o conteúdo principal
Lenovo Yoga 910-13IKB Battery Replacement
O que você precisa
  1. Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Battery Replacement, Battery: passo 2, imagem 1 %32
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Battery Replacement: passo 3, imagem 1 %32 Lenovo Yoga 910-13IKB Battery Replacement: passo 3, imagem 2 %32 Lenovo Yoga 910-13IKB Battery Replacement: passo 3, imagem 3 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
9 outras pessoas executaram este guia.
Pablo Gonzalez
Membro desde: 01/23/20
538 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S1-G5, White Winter 2020 Membro de Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
Membros da 4
Autoria de 14 guias
4 comentários
Step 3-6 are redundant to simply change the battery, correct?
oslodave - Responder
You're right! I fixed the guide to reflect this.
Arthur Shi -
Maybe I haven't seen many battery connectors, but this is one of the most annoying to reinsert.
Noah - Responder
Easy battery replacement on Yoga 910. The repair kit contains a variety of small repair tools and is very nice for the price. Found some small metallic discs when disassembled; they were spacers for the screws in the back casing and superglued them back to the casing before reassembly.
InfamousB - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 29
Últimos 30 dias: 146
Duração total: 10,768
